Exhaust/Heater Box holes
Page: Previous  1, 2, 3, 4
JimmieH Premium Member
JimmieH is offline
PostPosted: Tue Feb 13, 2018 3:06 pm    Post subject: Re: Exhaust/Heater Box holes Reply with quote
That is an EGR pipe. It was used on some '74 and possibly earlier models. It would only connect to a late model EGR with a custom fabricated pipe. Seems like there might be more heat from a connection that close to the head. I don't know how this would affect the diaphram in a late model EGR valve.
1978 Transporter 2.0 FI
Goach2
Goach2 is offline
PostPosted: Tue Feb 13, 2018 6:42 pm    Post subject: Re: Exhaust/Heater Box holes Reply with quote
Does and adapter exist to go from the '77 EGR to this one?
1977 FI Westfalia
JimmieH is offline
PostPosted: Wed Feb 14, 2018 4:38 am    Post subject: Re: Exhaust/Heater Box holes Reply with quote
No. You would have to make one.
Goach2
Goach2 is offline
PostPosted: Wed Feb 14, 2018 6:05 am    Post subject: Re: Exhaust/Heater Box holes Reply with quote
JimmieH - Did you eliminate yours?
1977 FI Westfalia
Goach2
Goach2 is offline
PostPosted: Wed Feb 14, 2018 8:28 am    Post subject: Re: Exhaust/Heater Box holes Reply with quote
Looking at the tins I need to replace to swap the exhaust, I can't seem to find these two in the manual:
Can anyone confirm where these go? There's a reference to having to remove the heads to put some in, in this forum:
https://www.thesamba.com/vw/forum/viewtopic.php?t=375847
I hope that's not the case!
1977 FI Westfalia
Wildthings
Wildthings is offline
PostPosted: Wed Feb 14, 2018 10:27 am    Post subject: Re: Exhaust/Heater Box holes Reply with quote
I the first tin you show is the lower front left tin for a 75-78 FI'd rig, while the second tin you show is the lower front right tin for a 72-74 carbureted rig. For the lower front right tin, you can get the equivalent tin for a FI'd 411/412 (and maybe a '79) which will not have the hole in it.
Either of these tins can be easily removed and replaced with the engine in place.
Goach2
Goach2 is offline
PostPosted: Wed Feb 14, 2018 11:15 am    Post subject: Re: Exhaust/Heater Box holes Reply with quote
So it sounds like my '77 might already have the first tin on it? These pics are from the kit that GS offers to convert late bays to the '72-'74 ones. For the second, I'm assuming the hole isn't necessary then?
Any chance anyone has seen a pic or diagram of these in place? I can't seem to find them anywhere. you'd think they would be in the manual...
1977 FI Westfalia
lil-jinx
lil-jinx is offline
PostPosted: Wed Feb 14, 2018 11:36 am    Post subject: Re: Exhaust/Heater Box holes Reply with quote
This may help
https://www.thesamba.com/vw/forum/viewtopic.php?p=7758607#7758607
1968 Dune Buggy
1974 parts bus
Wildthings
PostPosted: Wed Feb 14, 2018 11:51 am    Post subject: Re: Exhaust/Heater Box holes Reply with quote
The lower front left tin shown may be correct, not easy to tell with the stamp over it. This is another view.
Goach2
Goach2 is offline
PostPosted: Wed Feb 14, 2018 1:44 pm    Post subject: Re: Exhaust/Heater Box holes Reply with quote
Well, I just picked these up. I'll have to circle-back once I get them all cleaned up and ready to install. On that note, do tins require high-heat paint? Or will Rustoleum suffice?
1977 FI Westfalia
Wildthings
PostPosted: Wed Feb 14, 2018 1:52 pm    Post subject: Re: Exhaust/Heater Box holes Reply with quote
Rustoleum seems to work. I had a set powder coated but have never gone through the hassle of installing them. Look nice in their box full of tissue paper and bubble wrap though. Wink
Goach2
Goach2 is offline
PostPosted: Fri Feb 16, 2018 8:55 am    Post subject: Re: Exhaust/Heater Box holes Reply with quote
One more piece of tin to remove. Is it just me, or are these Phillip's-head screws the worst? I've already drilled out 4 and have one more to go...
1977 FI Westfalia
BUSBOSS
BUSBOSS is offline
PostPosted: Fri Feb 16, 2018 10:25 am    Post subject: Re: Exhaust/Heater Box holes Reply with quote
It's just you. Wink
This is your friend.
https://i.redditmedia.com/rHqPgkzgEntt_yhkdyzGAJSQ...282ddfa27b
All the redemption I can offer, girl, is beneath this dirty hood
1976 Westfalia
1970 Karmann Ghia Convertible
(sold - but not forgotten)
Wildthings
PostPosted: Fri Feb 16, 2018 10:44 am    Post subject: Re: Exhaust/Heater Box holes Reply with quote
I have replaced many of the screws in my tin with washer head hex screws, which makes removal of a rusty screw much easier. You can even get washer head hex screws which will also accept a Phillips screwdriver.
Goach2
Goach2 is offline
PostPosted: Mon Feb 26, 2018 9:22 am    Post subject: Re: Exhaust/Heater Box holes Reply with quote
Making good progress. One thing that was recently suggested to me, which I hadn't heard before, was that the copper gaskets for the exhaust ports have to be heat-treated before installation.
Is everyone in agreement on this?
Thanks!
1977 FI Westfalia
BUSBOSS
BUSBOSS is offline
PostPosted: Mon Feb 26, 2018 10:58 am    Post subject: Re: Exhaust/Heater Box holes Reply with quote
Yes. Annealed!
Read more here:
http://www.ratwell.com/technical/Exhaust.html
1976 Westfalia
Hoody
Hoody is offline
PostPosted: Mon Feb 26, 2018 10:42 pm    Post subject: Re: Exhaust/Heater Box holes Reply with quote
Are Phillips head screws the worst? Well you need to consider they have been in there for 40 years, you have dissimilar metals, and the heads are probably rusted. I went with Ratwell’s suggestion of black anodized stainless Phillips head screws. The part number is on his website. Finding the correct anodized stainless washer was a chore. Had to buy a box of 100. So if you go this route let me know. I have extras. Stainless reacts less than regular steel does with aluminum. I anti-seized every screw for future removal. Most people use the cheese head screws. But they were not my choice. Before you attempt to secure the heater boxes you should check out Clatter’s “cheap junk” engine build. Around the middle of it he addresses a very important aspect of the sealing process. He’s the only person that I have seen document this. And it’s extremely important. However you choose to make the tops of the pipes flat...you will be taking off material. You need to then remove material from the mounting flanges. Get a micrometer and make sure that that the distance is equal. Other wise they will not seal properly. And mock it up several times to make sure. Hope this helps.
Goach2
Goach2 is offline
PostPosted: Wed Feb 28, 2018 11:17 am    Post subject: Re: Exhaust/Heater Box holes Reply with quote
Thanks Hoody/BUSBOSS,
So much for bolt-on and go!
1977 FI Westfalia
Page 4 of 4
