Peloquin guts
Christopher Schimke
PostPosted: Sat Feb 10, 2018 10:37 pm    Post subject: Peloquin guts Reply with quote
No, sorry, not pelican guts, Peloquin torque biasing differential guts. I had to take mine apart to clean it out after a R&P grenaded. I found it quite interesting so I thought I would share the glorious guts.
Christopher
Alaskaberrys Premium Member
Alaskaberrys is offline
PostPosted: Sat Feb 10, 2018 10:43 pm    Post subject: Re: Peloquin guts Reply with quote
Dang, that looks impressive! I take it it survived the grenading? Looks pretty intact.
E1
E1 is offline
PostPosted: Sat Feb 10, 2018 11:25 pm    Post subject: Re: Peloquin guts Reply with quote
Thanks for posting this, Chris.
I have a question... about six weeks ago we got stuck in deep gravel. I had to work the clutch pretty hard in getting out -- though within reason and briefly -- and have smelled asbestos ever since.
Is there anything in a Peloquin that might produce this smell?
I think I overheated the clutch a skosh, as I do have minor chatter that *seems* to be getting better. I suspect I may have slightly warped the pressure plate, though everything seems to work okay save for mild chatter if not at the perfect rev upon pedal release... but I'm asking in being able to eliminate a damaged Peloquin as the offending issue.
It and the clutch and the transaxle rebuild all have less than 10K, so I'm a bit nervous...
Sorry for the stray, please let me know. Cool
I drive by the seat of my pants but then get behind on my steering
1984 Westy-Ferrari firing at 33% capacity
gears
gears is offline
PostPosted: Sun Feb 11, 2018 6:52 am    Post subject: Re: Peloquin guts Reply with quote
No, your smell is purely clutch.
I'll post up some photos of Gary's Syncro version TBD later today. It's slightly different than the 2WD one Christopher shows. Both are very nice quality IMO .. FAR better Quality control than Quaife or some of the other brand TBDs.
For the heck of it, here's an inside pic of our GT Type 1 swingaxle TBD: https://www.thesamba.com/vw/gallery/pix/1744118.jpg
aka Pablo, Geary
9.36 @ 146 in '86
'90 Syncro Westy SVX
'87 Syncro GL 2.5
Needed: Stock 14" x 6" Syncro steel rim
Gnarlodious
Gnarlodious is offline
PostPosted: Sun Feb 11, 2018 8:28 am    Post subject: Re: Peloquin guts Reply with quote
Thaks for that, now I know what’s back there.
Vanagon ’83 diesel AAZ w/Giles injection, 5spd 4.57R&P+TBD.
E1
E1 is offline
PostPosted: Sun Feb 11, 2018 9:56 am    Post subject: Re: Peloquin guts Reply with quote
Thanks Paul.
gears
gears is offline
PostPosted: Mon Feb 12, 2018 4:37 pm    Post subject: Re: Peloquin guts Reply with quote
To compare the 2WD and 4WD Vanagon versions, here's Gary Peloquin's Syncro TBD:
To accommodate the full locking feature, "shorty" gears were required ..
aka Pablo, Geary
9.36 @ 146 in '86
'87 Syncro GL 2.5
DanHoug
DanHoug is offline
PostPosted: Mon Feb 12, 2018 5:28 pm    Post subject: Re: Peloquin guts Reply with quote
how the heck do designers figure this stuff out? i mean, seriously, my brain just does not envision this stuff from scratch. i'm awed.
-dan
gears
gears is offline
PostPosted: Mon Feb 12, 2018 5:51 pm    Post subject: Re: Peloquin guts Reply with quote
CAD programs ..
aka Pablo, Geary
9.36 @ 146 in '86
'87 Syncro GL 2.5
DanHoug
DanHoug is offline
PostPosted: Tue Feb 13, 2018 11:56 am    Post subject: Re: Peloquin guts Reply with quote
i guess it is sorta just a SUN planetary gear only with helical cut gears. i can get that but just the ability to design and cut a helical gear alone blows me away. lots of smart people out there.
-dan
Turbod16v
Turbod16v is offline
PostPosted: Tue Feb 13, 2018 12:48 pm    Post subject: Re: Peloquin guts Reply with quote
I swear by Peloquin products!
I have had a Quaife differential and Peloquin in similar type HP and Geared GTI's i owned at the same time.
The Peloquin always engaged smoother and sooner/faster and provided better traction! The one in my drag car is going on 14 years old..never missed a beat!
plus Gary! he handles anything no questions asked! good guy!
1987 GTI 16V
Turbocharged 2.0 16v 315whp
82k original miles
Ownded since 1995
1983 vanagon "rust"falia
1.6 diesel with factory 5spd
future 2.0 aba with turbo.
Working with 70's-90's era vw's for 20+ years and full of useless information.
bobbyblack
bobbyblack is offline
PostPosted: Tue Feb 13, 2018 1:54 pm    Post subject: Re: Peloquin guts Reply with quote
E1 wrote:
I think I overheated the clutch a skosh, as I do have minor chatter that *seems* to be getting better. I suspect I may have slightly warped the pressure plate, ...
Hey E1... the possibility of cracks in the face of your flywheel are significant with the kind of behavior you mentioned, and the smell it made. Sorry, BTDT
Hope you find out that it is either fine, OR that it is cracked and you replace it BEFORE it bites you where the sun don't shine. Engine or trans out to take a look, your choice.
-bobby
'87 Westy 'Flossie','83.5 Standard 'ZoomBus','74 Karmann Ghia, '65 Split Deluxe 'Henry', '63 Notch
tristessa
tristessa is offline
PostPosted: Tue Feb 13, 2018 4:04 pm    Post subject: Re: Peloquin guts Reply with quote
Since we're on the subject of TBD's, would this style of diff -- either Peloquin or Quaife -- be unhappy running "backward" long-term? Asking because of the reverse-rotation 1.8t /012 5-speed combination.
Though I do notice only Quaife seems to list a TBD for that transaxle...
Gnarlodious
PostPosted: Tue Feb 13, 2018 5:43 pm    Post subject: Re: Peloquin guts Reply with quote
It doesn’t run, so it can’t “run backwards”. It is like a differential gear in the sense that it only does anything when both wheels are rotating at different speeds. In all straight-ahead driving the unit is totally passive. In reverse gear it behaves just like in forward.
Jake de Villiers
Jake de Villiers is offline
PostPosted: Wed Feb 14, 2018 11:38 am    Post subject: Re: Peloquin guts Reply with quote
Damn, those things are beautiful!
'84 Vanagon GL 1.9 WBX
www.crescentbeachguitar.com
www.thebassspa.com
gears
gears is offline
PostPosted: Wed Feb 14, 2018 11:51 am    Post subject: Re: Peloquin guts Reply with quote
tristessa, not only can a TBD be run in reverse, but the internal gears (which have complimentary angles) can be swapped side-to-side.
(.. and as one customer shared, you can stuff one of these diffs down your pants to really impress your honey on Valentine's ;^)
aka Pablo, Geary
9.36 @ 146 in '86
'87 Syncro GL 2.5
Christopher Schimke
PostPosted: Wed Feb 14, 2018 12:12 pm    Post subject: Re: Peloquin guts Reply with quote
Or...you could just put your diff in a box.
Christopher
OddN
OddN is offline
PostPosted: Wed Feb 14, 2018 12:41 pm    Post subject: Re: Peloquin guts Reply with quote
Its a fascinating piece of engineering. And I do not fully understand the principle though.
I believe they both (Peloquin and Quaife) originates from the Torsen (Torque Sensing) diff developed by the Gleason Company in the late fifties?
1991 VW Multivan syncro 1,9 TD
ejimmi
ejimmi is offline
PostPosted: Wed Feb 14, 2018 2:55 pm    Post subject: Re: Peloquin guts Reply with quote
Laughing
Sodo
Sodo is offline
PostPosted: Wed Feb 14, 2018 5:21 pm    Post subject: Re: Peloquin guts Reply with quote
The simplicity makes it difficult to understand. You are probably thinking it's more complicated. Think "simple" and you will understand it.
I don't know if this translates to Norwenglish. If You could see me waving my arms you would understand, I'm certain! Wink
The cylindrical worms rattle around in holes (bores). If everything is loosey-goosey they allow the L & R axles to "work it out". Any funny-business and the cylinders (lots of them all at the same time !) rub against the sides of the hole they're in - and it locks. And there is the natural friction of worm gears too. And the natural friction of back-driving lots of worm gears, it all adds up to "LOCK".
Hope that helps. Rolling Eyes
One difference is - I don't think the Peloquin does much to "divide torque" like a Torsen would. It simply "locks". It's kind of like the Syncro vacuum-operated locker in that way, either "locked" or "not" but automatic. Wink
This is why people "suggest" the Peloquin may not work well on glare ice. But my Peloquin seemed to be fine on ice. But there are lots of different ice conditions out there, flat roads, side slopes, water on ice, dry cold ice on and on and on. I've never seen a valid comparison test - which would be a very difficult test dependent on weather conditions and drivers and tires and eqpt, and on and on and on. So all we have is speculation currently.
EJ25, Peloquin diff, locker, transaxle oil cooler/filtration system
....KTMs, GasGas, and a Stumpjumper
One apple every 8 hours will keep 3 doctors away - B Kliban
