Bad_Decisions Samba Member
Posted: Tue Feb 13, 2018 8:38 pm Post subject: Mystery Transmission |
So I went to a local swap meet and picked up a new (to me) transmission and it has writing on the side of the case. I asked the seller what it meant and he said he didn't know. It says NEW 11/96 11,188. My guess is that its "New" and 11,188 is the milage, but I have no clue what 11/96 could be. I'm no expert on VW transmissions and I'm sure someone on the samba is. So what could it mean?
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76902 Location: Sneaking up behind you
Posted: Tue Feb 13, 2018 8:43 pm Post subject: Re: Mystery Transmission |
Looks like a 73-79 SSC (Single Side cover) 4 speed. _________________ Glenn
Member #1009
#BlueSquare |
mukluk Samba Member
Joined: October 18, 2012 Posts: 7023 Location: Clyde, TX
Posted: Tue Feb 13, 2018 9:40 pm Post subject: Re: Mystery Transmission |
Could be that trans was installed "new" into a car in November of 1996 when it had 11,188 miles showing on the odometer, possibly marked as such by the shop that installed it in case the car came back for warranty coverage. Without being able to talk to whomever wrote on the trans, it's all just guessing as to what exactly it means. _________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Tue Feb 13, 2018 10:55 pm Post subject: Re: Mystery Transmission |
Glenn wrote: |
Looks like a 73-79 SSC (Single Side cover) 4 speed. |
I know what it is, I was just curious about the writing on the side
mukluk wrote: |
Could be that trans was installed "new" into a car in November of 1996 when it had 11,188 miles showing on the odometer, possibly marked as such by the shop that installed it in case the car came back for warranty coverage. Without being able to talk to whomever wrote on the trans, it's all just guessing as to what exactly it means. |
Huh, I haven't thought about that, this seems like a great explanation. |
ricaroo Samba Member
Posted: Wed Feb 14, 2018 5:27 am Post subject: Re: Mystery Transmission |
Maybe rebuilt 11/96 and only has 11,188 miles on it
Just saying _________________ 1971 Standard Beetle 2 dr Sedan 1600dp |
busman78 Samba Member
Joined: August 17, 2004 Posts: 4520 Location: Oklahoma City, OK
Posted: Wed Feb 14, 2018 5:45 am Post subject: Re: Mystery Transmission |
or 111,188 miles, which is more logical being twenty years old when tagged. |
2bugtony Samba Member
Joined: July 02, 2005 Posts: 345 Location: Sherman Wv
Posted: Wed Feb 14, 2018 5:49 am Post subject: Re: Mystery Transmission |
it looks to me like Junk yard writing. It was pulled out of the car at the junk yard
11/96 and 11188 miles on trans. I have seen this with parts I have bought at the Junk Yard |
Bill T. Samba Member
Joined: February 14, 2018 Posts: 68 Location: Flagstaff
Posted: Wed Feb 14, 2018 10:32 am Post subject: Re: Mystery Transmission |
Hi. Not to hijack this thread, but can anyone identify these two VW transmissions? I've read Daniel G.'s "Transmissions for Dummies" article and I still don't know what these are. I bought a lot of VW stuff from a nice guy who told me that these were "high torque bus transmissions" intended for Baja builds. So, what are they?
Thanks for the help. I'm new to VW's |
BIGMIKEY Samba Member
Joined: September 24, 2007 Posts: 1104 Location: North East Pennsylvania
Posted: Wed Feb 14, 2018 2:59 pm Post subject: Re: Mystery Transmission |
Glenn wrote: |
I wrote the final drive ratio, Odometer reading, and installation date on this trans. So it could be that.
Wouldn't a single side cover have no side cover on that side?
Mike T _________________ BIGMIKEY
Deserter Series 1 project.
https://www.thesamba.com/vw/forum/viewtopic.php?t=787047&highlight=
1973 Beetle Driver, Marina Blue. |
mukluk Samba Member
Posted: Wed Feb 14, 2018 3:40 pm Post subject: Re: Mystery Transmission |
Bill T. wrote: |
The first one at least is definitely a transaxle out of a split windshield bus, I'm sure someone will correct me if wrong, but I'd say 1961-1967. The identifier is the reduction gear box mounted at the end of each axle tube. I can't say for certain the second trans is also the same or not since I can't see the ends of the swingaxle tubes. _________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Wed Feb 14, 2018 6:03 pm Post subject: Re: Mystery Transmission |
Thanks for the reply regarding the transmission. I will get the identifiers off of them next week when I go on another parts run. I met a guy with a mountain of VW parts, two cars, engines, and trannies. So, me not knowing anything about VW's, what's the most logical thing to do?? I bought it all. I originally went to talk w him about an engine for a 78 Super Beetle that I am rebuilding and now I own a half truckload of parts.
So, extra dumb question, but what is a transaxle from a split window bus used for other than making a split window bus go forward and reverse!😂 _________________ '78 Super Beetle Convertible
'72 Triumph TR6 |
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Wed Feb 14, 2018 6:32 pm Post subject: Re: Mystery Transmission |
Really I wouldn't identify a transmission by what's bolted to it. Look for the numbers stamped into the case. It will tell you what they started out as anyway. |
mukluk Samba Member
Posted: Wed Feb 14, 2018 6:55 pm Post subject: Re: Mystery Transmission |
Bill T. wrote: |
So, extra dumb question, but what is a transaxle from a split window bus used for other than making a split window bus go forward and reverse!😂 |
The RGB trans setups from old busses were popular for a while in buggies and bajas due to the extra gear reduction provided by the gear boxes at the axle tube ends -- they help overcome the added weight and resistance encountered when installing oversize tires. An added bonus is the RGB setup also provides a few extra inches of ground clearance, useful when one is driving on uneven, rocky, or rutted terrain. You can bip on over to the HBB-Offroad section of the forum to do some more reading on the subject if you wish.
https://www.thesamba.com/vw/forum/viewforum.php?f=9 _________________ 1960 Ragtop w/Semaphores "Inga" |
