blues412002 Samba Member
Joined: March 07, 2002 Posts: 79 Location: Parkville, MO
Posted: Wed Feb 14, 2018 8:30 pm Post subject: Empi hpmx carbs |
I have a ‘74 Westy with dual Empi HPMX carbs. Are these copies of, for example, Webers or Dellortos or are they a proprietary design? _________________ Tim Osburn
1956 Euro ragtop beetle (Ebon)
1974 Westy hardtop camper (Tullio)
2017 Tiguan (Sport II)
http://ralphspoilsportmotors.com |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76945 Location: Sneaking up behind you
Posted: Wed Feb 14, 2018 8:31 pm Post subject: Re: Empi hpmx carbs |
blues412002 wrote: |
I have a ‘74 Westy with dual Empi HPMX carbs. Are these copies of, for example, Webers or Dellortos or are they a proprietary design? |
Weber IDF copies. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Thu Feb 15, 2018 7:37 am Post subject: Re: Empi hpmx carbs |
so, to continue to my real questions, this is a dual carb setup. The right carb is all dirty, nasty, the left is clean, pristine. The right carb backfires a lot. What could be happening here? Do I need to readjust completely from scratch? I am somewhat familiar with syncing the carbs and have attempted it before, but I may have screwed things up. _________________ Tim Osburn
Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2269 Location: Detroit, Michigan
Posted: Thu Feb 15, 2018 9:47 am Post subject: Re: Empi hpmx carbs |
so, to continue to my real questions, this is a dual carb setup. The right carb is all dirty, nasty, the left is clean, pristine. The right carb backfires a lot. What could be happening here? Do I need to readjust completely from scratch? I am somewhat familiar with syncing the carbs and have attempted it before, but I may have screwed things up. |
Question:
The right carb backfires a lot. What could be happening here? |
Answer:
The right carb is all dirty, nasty |
_________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
Posted: Thu Feb 15, 2018 1:05 pm Post subject: Re: Empi hpmx carbs |
OK, they shall be cleansed. However, the thing called the auxiliary venturi, just below the air horn, has caked on grime and crap. It is also loose, as the others are not. How would one half of the carb be affected and not the other half? Sorry for seeming so stupid on these things, but I'm no mechanic. _________________ Tim Osburn
