mike_the_engineer Samba Member
Posted: Fri Feb 09, 2018 5:28 pm Post subject: Meyers Manx Rear Bumper Question |
I just bought a rear bumper for my buggy from Meyers Manx, but I'm not sure how the lower bracket is supposed to attach. The instructions say that I'm supposed to attach it to the rear fork, where the transmission cradle is, but the bracket doesn't fit that location.
This is the mounting bracket that came with it...
And this is my rear fork. Notice how the bracket has two holes, but the mounting location only has one bolt. There is a raised lip that surrounds the bolt, and there doesn't appear to be any way to use it without cutting out that gusset. So either I have the wrong bracket, the wrong transmission mount, or there is another solution that I'm not seeing. Anybody know what the problem is?
FYI - This is the bumper I'm talking about. Thanks!
_________________ 1970 Beetle Convertible |
clonebug Samba Member
Joined: January 29, 2005 Posts: 4027 Location: NW Washington
Posted: Fri Feb 09, 2018 5:37 pm Post subject: Re: Meyers Manx Rear Bumper Question |
You can use washers as a spacer to clear that bracket on the trans mount or else grind that section down until you have the clearance......I myself would use a couple washers for a spacer to clear it......make sure your bolts are still long enough if you space it out to clear.
Once you have it fitted you can cut the other side of the mount tube off or else leave it there in case you want to mount a skid plate or something. _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
AMAC1680 Samba Member
Joined: April 09, 2015 Posts: 300 Location: Jacksonville Fl/Mantoloking NJ
Posted: Sat Feb 10, 2018 5:48 am Post subject: Re: Meyers Manx Rear Bumper Question |
I’d also shim it out.
I think the assumption is most buggies use a different trans mount.
AMAC _________________ www.SEGS4VETS.org |
Posted: Sat Feb 10, 2018 12:44 pm Post subject: Re: Meyers Manx Rear Bumper Question |
Great idea. I'll try that. Thanks for your help! _________________ 1970 Beetle Convertible |
joescoolcustoms Samba Member
Posted: Thu Feb 15, 2018 8:00 pm Post subject: Re: Meyers Manx Rear Bumper Question |
Be careful shimming it. You may pull the bolt out far enough that very little thread may remain in the trans support forks.
The transaxle mount you have is not a stock unit. The stock unit did not have the lower cupped lip which allowed the bottom bumper bracket support to just slip under the large bolt and re-tighten. I would suggest cutting the outside cupped lip off of the bolt area to retain as much threaded engagement in the trans support forks as possible. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
Posted: Thu Feb 15, 2018 8:30 pm Post subject: Re: Meyers Manx Rear Bumper Question |
Another option is to figure out where it needs to be, and just weld the tube mounts on the rear trans mount.
On a Manxter I built, when doing the Subaru engine and transaxle conversion, I had to heavily modify the rear bumper mounts. The Subaru trans mount is funky looking and I had to modify it for the deep race oil pan, and then for the bumper. Because it was a custom Turbo set up, the rear bumper had to be shifted back about 4 inches to clear the turbo.
In this picture, you can see the SS bumper tube and the welded lower mount. Buggies are custom, you can customize your own mounting system too.
