shagginwagon83 Samba Member
Joined: February 07, 2016 Posts: 3796 Location: VA/TN
Posted: Fri Feb 16, 2018 11:51 am Post subject: Re: Go Westy ABS Door Panels |
Pingora wrote: |
since you shouldn't put it inside the front door panels.
Why is that? _________________ Brandon
Instagram @joannthevan |
SCM Samba Member
Joined: January 26, 2011 Posts: 3115 Location: Bozeman MT
Posted: Fri Feb 16, 2018 2:03 pm Post subject: Re: Go Westy ABS Door Panels |
shagginwagon83 wrote: |
Pingora wrote: |
Why is that? |
It can hold moisture up against the sheet metal and promote rust. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
Posted: Fri Feb 16, 2018 2:15 pm Post subject: Re: Go Westy ABS Door Panels |
Even with dynamat type material? I thought about sound deadening my doors...but now I might not. _________________ Brandon
elizer Samba Member
Joined: May 02, 2016 Posts: 1462 Location: Northern Virginia
Posted: Fri Feb 16, 2018 2:29 pm Post subject: Re: Go Westy ABS Door Panels |
Pingora that looks great... How do you roll down the window? |
VicVan Samba Member
Joined: July 01, 2015 Posts: 1840 Location: Vancouver Island, BC
Posted: Fri Feb 16, 2018 4:08 pm Post subject: Re: Go Westy ABS Door Panels |
I'm guessing window electric switches installed in the center of the dashboard. Definitely what I'll be doing when I install ABS panels. _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
mtnride1 Samba Member
Joined: March 30, 2011 Posts: 194 Location: la quinta, CA
Posted: Fri Feb 16, 2018 4:21 pm Post subject: Re: Go Westy ABS Door Panels |
Mine are in suede with embossed VW emblem _________________ 87 westy 2wd (NED) |
Pingora Samba Member
Joined: September 10, 2017 Posts: 50 Location: Portland
Posted: Mon Feb 19, 2018 5:34 pm Post subject: Re: Go Westy ABS Door Panels |
Oh yeah, for moisture reasons. But I did put some fatmat type stuff just to lower the bonginess, I don't think that's anything to worry about. _________________ 1990 Vanagon Carat
2002 Suby 2.5 Mizu Bokusa
17" wheels, 26.5" diameter tires |
Corwyn Samba Member
Joined: December 29, 2009 Posts: 2237 Location: Olympia, Washington
Posted: Fri May 28, 2021 6:19 pm Post subject: Re: Go Westy ABS Door Panels |
I just got my panels and foam tape. Does the tape go on over the mounting holes - that's how GW shows it. _________________ '90 White Westy ("The Longship")
FAS Gen V 2.0
The Annual Baja Rally
~ Captain Ron ~ |
