Rich99 Samba Member
Joined: March 29, 2008 Posts: 22 Location: Portsmouth, UK
Posted: Mon Feb 12, 2018 1:46 pm Post subject: 69.5 Convertible Roof has shrunk |
I have the issue that the Haartz canvas roof has shrunk in the time it has taken to carry out the resto. My local trim shop, who have admitted to never having done one before says it is junk and needs to be replaced.
Does anyone know if there is a way to stretch out the canvas and would need to be some considerable stretch, probably 2" in total? I have heard of applying boiling water to towels and placing them on the roof and massaging it back. Has anyone ever heard of this or better yet, tried it? Apart from the cost involved, the hood itself is mint, no rips, tears or discolouration.
If I do need to replace the roof, who does the best quality replacement? TMI, Sewfine, any strong opinions? If you are in the UK, can you recommend a stockist as VW Heritage are showing a six week order time and I was hoping to get it done for Volks World (I'm an optimist).
Thanks in advance! |
c21darrel Samba Member
malley56 Samba Member
Joined: January 29, 2006 Posts: 255 Location: Martinsville, VA
Posted: Mon Feb 12, 2018 5:59 pm Post subject: Re: 69.5 Convertible Roof has shrunk |
What Darrell said... Plus it's probably not shrank 2 inches. It just needs to stretch that far.
I found a clothes steamer worked great with a full heavy bucket for weight on the header bow. Wait till a nice warm sunny day and pull it outside.. |
Rich99 Samba Member
Posted: Tue Feb 13, 2018 12:39 am Post subject: Re: 69.5 Convertible Roof has shrunk |
Thanks for the replies guys, I will give it a go. The only flaw in the answers is this sunny day thing. I live in England so what exactly is that again? |
kman Samba Member
Joined: November 04, 2005 Posts: 739 Location: Michigan
swavananda Samba Member
Joined: February 14, 2009 Posts: 889 Location: Can o' Scruz
Posted: Tue Feb 13, 2018 6:44 am Post subject: Re: 69.5 Convertible Roof has shrunk |
kman wrote: |
You may have to adjust the cables. |
Since this is the late 69, you can get a little more play by loosening the rear lip cable and pulling out a bit more fabric from the recess. With top up, get access by removing the Phillips screws that’s securing the headliner to the frame just next to the door glass . This will open a flap enough to work on the cables tension . This is what you’re looking for. The 10mm jam nuts.
You may then have to loosen the cable around the rear window opening as well. |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32638 Location: Reading Pennsylvania
The aussie Trimmer Samba Member
Joined: July 05, 2006 Posts: 385 Location: Western Australia
Posted: Tue Feb 13, 2018 9:38 pm Post subject: Re: 69.5 Convertible Roof has shrunk |
That's right Dave; you should never leave the top down for any length of time.
Drop the top down and enjoy the clean air; but when you return the car to the garage, the top must be locked in the up position.
If you can't lock the top in the locked position; wet the top and place a weight "carefully" on the header bow and park it in the sun until it stretches into the locked. This may take a few tries to get it to close.
And next time; don't leave the top down overnight, especially if it's wet or humid. _________________ Cheers,
Kev.
Drive with your lights on (Be aware be seen) help others GIVE Blood |
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 3916 Location: In Molinya Orbit
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13958 Location: Southampton U.K.
paul_round Samba Member
Posted: Wed Feb 14, 2018 3:30 am Post subject: Re: 69.5 Convertible Roof has shrunk |
I can certainly attest to the top shrinking if left down to long. Mine has on occasions been down for several weeks at a time and was a real struggle to fasten up afterwards, I even had to resort to my son lying on top of it! |
Rich99 Samba Member
Posted: Wed Feb 14, 2018 4:20 pm Post subject: Re: 69.5 Convertible Roof has shrunk |
With the added ventilation and the ability of the water to ingress at lots of different points, the BBC weather app has been very handy John. Mine has been out twice, one of which was to the trimmers.
Unfortunately, I'm not sure it was down quite so much as off! I am going to try the fix and see what happens but the gaps in the two bottom rear quarters of the are massive but perhaps coaxing the material backwards as well as forwards may help somewhat. Nothing lost for having a go!
Posted: Thu Feb 15, 2018 1:05 am Post subject: Re: 69.5 Convertible Roof has shrunk |
Rich99 wrote: |
Unfortunately, I'm not sure it was down quite so much as off! I am going to try the fix and see what happens but the gaps in the two bottom rear quarters of the are massive but perhaps coaxing the material backwards as well as forwards may help somewhat. Nothing lost for having a go! |
Might want to get advice from another trimmer on whether your hood can be saved. Give "Wessex Car Trimmers" a call here in Southampton Rich...long established and well respected. Always good to have a second opinion: http://www.wessex-cartrimming.co.uk/car-trimming _________________ John.
Rich99 Samba Member
Posted: Sat Feb 17, 2018 3:06 pm Post subject: Re: 69.5 Convertible Roof has shrunk |
Thanks John, I will give them a call during the week.
The car was registered in October 69, hence my calling it a 69.5 but yes, a 1970 model year. |
Posted: Sat Feb 17, 2018 8:51 pm Post subject: Re: 69.5 Convertible Roof has shrunk |
On a side note, it looks like the head lights are protruding a good 10mm out from where they should be. You should address this with the shop ASAP. Otherwise looks nice . |
Rich99 Samba Member
Posted: Sun Feb 18, 2018 2:53 am Post subject: Re: 69.5 Convertible Roof has shrunk |
swavananda wrote: |
Thank you. I will get them to check but have a feeling it is to do with the angulation required for them to pass our MOT and the car being left hand drive. |
NOVA Airhead Samba Member
Joined: July 20, 2005 Posts: 5221 Location: Richmond, VA
Posted: Sun Feb 18, 2018 9:47 am Post subject: Re: 69.5 Convertible Roof has shrunk |
I would try stretching it a bit. Direct sunlight is your best bet but until you can get that I would suggest backing the J hooks where the top latches to the header out as far as possible. If you can get that hooked then leave it sit for a few days. Turn them in a little very few days, hook and see if that helps. _________________ Ghia Owner Emeritus |
