NoDents Samba Member
Posted: Fri Feb 09, 2018 9:01 pm Post subject: Speaking of POR15..... |
Is it just me or is the quart POR15 can the most impossible to open... and then close properly?
Maybe I'm just a looser and can't do it right. I have had 2 cans and have had issues with both. At $50 a pop..... just saying. |
Onceler Samba Member
Posted: Thu Feb 15, 2018 9:09 am Post subject: Re: Speaking of POR15..... |
I gave up on POR15 when I found I can buy a gallon of Kirker DTM 2k epoxy for not much more money including activator _________________ 1972 Karmann Ghia |
CiderGuy Samba Member
Joined: December 23, 2013 Posts: 1351 Location: Bucks County, Pa
Posted: Fri Feb 16, 2018 6:11 am Post subject: Re: Speaking of POR15..... |
Onceler wrote: |
I gave up on POR15 when I found I can buy a gallon of Kirker DTM 2k epoxy for not much more money including activator |
That's great, but what are real users reviews ? Does it last, how long has it been around, and used in auto restoration? _________________ ----------------------
Cars Currently Owned:
1970 Karmann Ghia Coupe
1973 Karmann Ghia Coupe - Project car for sale
1970 Karmann Ghia Convertible (Body off restoration)
Timing is everything |
catahoula lou Samba Member
Joined: August 30, 2008 Posts: 594 Location: south of Silver Springs, NV
Posted: Fri Feb 16, 2018 8:15 am Post subject: Re: Speaking of POR15..... |
I had the same problem with the original can. You can either go to a paint shop and buy a similar-sized new can that you can open/close without difficulty (buy a paint can key too), or use a mason jar (they seal best as they are used to preserve canned fruits).
Just in case, I triple-bag my POR15 with gallon-sized Ziplocks to reduce loss of volatiles. _________________ 1 great wife
2 Catahoula Leopard Dogs (Mahogany Star and Spartan) - RIP Lucy, Braveheart, & Dusty!
1 1959 mango green Ragtop Bug (the "Mango")
1 1958 pantina red Lowlight Ghia (the "Chili Pepper")
Still looking for:
(1) My Dad's 1955 356 (he raced it amateur-class at Riverside and other courses during 1950s),
(2) My parent's black 1955 hardtop bug (CA license plate FWC 201 or FWG 201), and
(3) My parent's agave green 1957 ragtop bug (CA license plate LFK 734). |
Posted: Fri Feb 16, 2018 8:18 am Post subject: Re: Speaking of POR15..... |
OK, good to know it's not just me. |
Posted: Fri Feb 16, 2018 4:33 pm Post subject: Re: Speaking of POR15..... |
Just make damn sure to keep the POR15 from getting into the can lid groove, as it will act like epoxy and glue the lid onto the can
Best,
Thom _________________ 1 great wife
Still looking for:
Posted: Sat Feb 17, 2018 11:06 pm Post subject: Re: Speaking of POR15..... |
CiderGuy wrote: |
Onceler wrote: |
That's great, but what are real users reviews ? Does it last, how long has it been around, and used in auto restoration? |
Basically, 1k products (rustoleum, por15) are for lawn furniture and 2k products are for automotive refinishing _________________ 1972 Karmann Ghia |
vwkirb Samba Member
Joined: January 16, 2007 Posts: 812 Location: Athens, GA
Posted: Thu Feb 22, 2018 7:04 am Post subject: Re: Speaking of POR15..... |
POR-15 is a 2k product.
It is a polyurethane, specifically a moisture curing polyurethane. Once it is exposed to atmospheric moisture it starts curing, so opening the can pretty much sets its life.
Here is a trick i used, use saran wrap on over the top of the open can, and purge the can with argon before closing it. It will greatly increase the lifespan once its been open.
If you don't have Argon for welding (I don't) you can buy some bloxygen.
https://www.amazon.com/Bloxygen-Grams-Finish-Preserver-Spray/dp/B0002088O8 _________________ Andrew Kirby |
Posted: Thu Feb 22, 2018 7:10 pm Post subject: Re: Speaking of POR15..... |
I just know I've had adhesion problems with it before, yeah probably a prep issue, but I've never had any adhesion problems with epoxy primer+activator. It needs top coated for uv protection but so does por15. For the topcoat? Rust oleum (yeah I'm cheap) _________________ 1972 Karmann Ghia |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16754 Location: State College, PA
Posted: Fri Feb 23, 2018 6:21 am Post subject: Re: Speaking of POR15..... |
FYI - there are several different size cans of POR. Small ones cost a lot per ounce, but better than throwing away a 1/2 quart....I bought a 6 pack of pints for small stuff and quarts for big. Pretty much just figure out how much I need to sue and grab the correct size can. _________________ D-Dubya Manx clone - 63 Short pan,1914.
