fassty v8 Samba Member
Joined: November 17, 2017 Posts: 67 Location: LANCASHIRE
Posted: Wed Dec 27, 2017 2:31 pm Post subject: Re: v8 fassty |
little bit more done today.
got the body of the chassis.
once the body was off i could mock it up at ride height with the wheels on to see how it looked.
then it was time to add some braces to the shell before cutting out the bulkhead, front inner wings and the entire rear inner section.
and heres what were left with.
im afaid theres not much left. |
Air_Cooled_Nut Samba Member
Joined: March 27, 2004 Posts: 3040 Location: Portland, Oregon
Posted: Wed Dec 27, 2017 8:29 pm Post subject: Re: v8 fassty |
fassty v8 wrote: |
Agreed. Might as well used a fiberglass body _________________ Toby http://www.aircoolednut.com/
Did I mention that I'm an original Darksider?
'72 VW Squareback, 2007cc, GB 5-speed, rag top; '76 VW Riviera Penthouse Sundowner 2.0L; 2015 Audi S5 Cabby w/Stage II APR; '06 Ducati Sport Classic 1000; '14 Ducati Diavel Strada
The First Invasion |
oxsign Samba Member
Joined: February 19, 2006 Posts: 607 Location: Sanford, FL
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22410 Location: Kimball, Mi
Posted: Thu Dec 28, 2017 1:07 pm Post subject: Re: v8 fassty |
Air_Cooled_Nut wrote: |
fassty v8 wrote: |
Agreed. Might as well used a fiberglass body |
Or better yet a rusty one. You would have cut most of that out anyway.
Hopefully you saved the pieces to sell to other VW people. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Thu Dec 28, 2017 1:28 pm Post subject: Re: v8 fassty |
yes all the good bits of the shell have been sold on to save other type3,s
the shell is only this good because i repaired it 7 years ago as it was a complete rust bucket, i replaced the whole front end and the entire bottom 6" off the shell.
the shell is a 72 with a 67 front clip welded on and shell fitted with all early panels |
LOW N SLOW66 Samba Member
Joined: March 03, 2013 Posts: 71 Location: Billings, Montana
Posted: Thu Dec 28, 2017 10:20 pm Post subject: Re: v8 fassty |
Man, You should have played it up! Said it started out as a rust free barn find with like 30 original miles on it although you would probably have a bounty on your head if you did that _________________ "Donnie, you're out of your element!" |
Posted: Fri Dec 29, 2017 10:28 am Post subject: Re: v8 fassty |
fassty v8 wrote: |
Well, at least you already replaced the rusty bits, before you cut the rest away. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Thu Jan 04, 2018 2:50 pm Post subject: Re: v8 fassty |
as im going to use a supercharger set up of a jaguar xjr i ordered all the bits and they all came this week and i just had to bolt it all together.
i love the look of this set up, its going to look killer under the bonnet of the fassty.
on with building the chassis jig tomorrow so should be able to start building very soon. |
Posted: Sat Jan 06, 2018 1:58 pm Post subject: Re: v8 fassty |
finally got to finnish up the jig which the fassty will be built on today.
it can be moved around on the castors and when building it can be leveled up on the adjustable feet. more than happy with the way it came out. should be able to get on with the chassis this week. |
Posted: Tue Jan 09, 2018 3:24 pm Post subject: Re: v8 fassty |
on with the chassis this week. started on the rear kick ups, welded them up and set them up at ride height with a wheel to make sure its all as i wanted.
Posted: Fri Jan 12, 2018 11:44 am Post subject: Re: v8 fassty |
got the rear chassis section welded up today.
gearbox also arrived today.
bell housing needs taking off so it can be machined to fit the roversd1 flywheel. i also will be making an adaptor plate to mate the mazda rx8 gearbox to the rover v8 engine so if anyone is intereseted just give me a shout. |
OhHerrooo Samba Member
Joined: September 12, 2010 Posts: 1291 Location: Costa Mesa, CA
Posted: Fri Jan 12, 2018 12:24 pm Post subject: Re: v8 fassty |
fassty v8 wrote: |
Now that looks like progress. Nice. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Fri Feb 02, 2018 10:06 am Post subject: Re: v8 fassty |
this turned up today.
all powder coated up it looks the part. |
Posted: Mon Feb 19, 2018 12:41 pm Post subject: Re: v8 fassty |
finally got the fassty body on the chassis jig,
before i centre it up and fix it to the chassis jig at ride height i need to stretch the front wings about 6" so i can start to sort the front end of the chassis. stretching the front wings will give me that pro mod look im after and also give me a bit more room in the engine bay.
did a quick sketch of what im after.
Jason37 Samba Member
Posted: Mon Feb 19, 2018 8:35 pm Post subject: Re: v8 fassty |
Can’t wait to see the next round of pics! |
vwfye Samba Member
Posted: Mon Feb 19, 2018 10:48 pm Post subject: Re: v8 fassty |
Not that I matter, but i like it _________________ 64 No'back Speedster "Pearl"
1980s Sand Dragster "The Plunger"
LME "Little Giant Killer 3" |
Posted: Tue Feb 20, 2018 8:57 am Post subject: Re: v8 fassty |
Jason37 wrote: |
Agreed. This one is about to get real interesting. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Tue Feb 20, 2018 3:41 pm Post subject: Re: v8 fassty |
got one of the front wings stretched tonight. once i had worked out how i was going to do it i just cut it, made some filler panels and tacked them in place.
with the wing mocked up on the shell with the wheels.
really like how it looks. |
