dhaavers Samba Member
Joined: March 19, 2010 Posts: 7757 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Fri Aug 11, 2017 5:09 am Post subject: Re: Manual Transmission Drain Plug - metal |
Indeed. _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
shagginwagon83 Samba Member
Joined: February 07, 2016 Posts: 3803 Location: VA/TN
Posted: Thu Feb 22, 2018 5:22 pm Post subject: Re: Manual Transmission Drain Plug - metal |
How's my plug?
_________________ Brandon
Instagram @joannthevan |
Posted: Thu Feb 22, 2018 8:41 pm Post subject: Re: Manual Transmission Drain Plug - metal |
Cute!
How many miles since last drain...???
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Posted: Thu Feb 22, 2018 9:18 pm Post subject: Re: Manual Transmission Drain Plug - metal |
dhaavers wrote: |
Cute!
- Dave |
Unknown! But the drain plug and the fill plug came out pretty easily. I'm going to put in some cheap 75w-90 weight oil and run it for like 500 miles. Then drain it then put in my RedLine 75w-90 _________________ Brandon
Syncro Jael Samba Member
Posted: Fri Feb 23, 2018 7:18 am Post subject: Re: Manual Transmission Drain Plug - metal |
shagginwagon83 wrote: |
dhaavers wrote: |
Cute!
- Dave |
Unknown! But the drain plug and the fill plug came out pretty easily. I'm going to put in some cheap 75w-90 weight oil and run it for like 500 miles. Then drain it then put in my RedLine 75w-90 |
That looks pretty good if it has thousands of miles of use.
You are sure about putting in Redline as your gear oil of choice? _________________ 1987 Syncro Westfalia Hightop - NAHT
Subaru EJ25 Forged Frankenmotor, Triple Knob.
Jael = (Mountain Goat) |
Posted: Fri Feb 23, 2018 7:35 am Post subject: Re: Manual Transmission Drain Plug - metal |
Syncro Jael wrote: |
dhaavers wrote: |
Cute!
- Dave |
You are sure about putting in Redline as your gear oil of choice? |
It has at least 7k miles on this manual transmission. No I'm not sure if you're questioning my choice! I will explain myself. I didn't go with Swepco because I heard that it takes a while for oil to warm up. I went with Redline 75W-90 because GoWesty recommends them. I already bought the Redline too . I have a hard time finding 2nd gear when cold. Double clutching helps. Once warmed up it works great.
Dammit. I'm just going to use the Redline for my 'flush' oil. I'll switch it out in 5k miles I guess _________________ Brandon
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
Posted: Fri Feb 23, 2018 8:39 am Post subject: Re: Manual Transmission Drain Plug - metal |
It's got my vote for "Best Tranny Plug of the Year" ! _________________ This free advice is worth exactly what you paid for it.
Sodo Samba Member
Joined: July 06, 2007 Posts: 9618 Location: Western WA
Posted: Fri Feb 23, 2018 1:41 pm Post subject: Re: Manual Transmission Drain Plug - metal |
The only thing good about that hairdo is the particles are all really small. Which suggests that theres could be some life remaining. But make no mistake, you waited far too long, and suffered losses in running your trans with that much metal in your lubricant. From what I read, you don’t know the miles but it’s more than 7,000? However If thats “7,000 miles since last change” that trans is going out SOON.
WRT Redline.... any clean oil you can find anywhere is hundreds of times better than that oil. I think you should flush soon (with any two clean oils) & get ‘clean’ to allow a valid assessment after a few thousand. _________________
....KTMs, GasGas, SPOT mtb |
Posted: Fri Feb 23, 2018 2:11 pm Post subject: Re: Manual Transmission Drain Plug - metal |
Sodo wrote: |
WRT Redline.... any clean oil you can find anywhere is hundreds of times better than that oil. I think you should flush soon (with any two clean oils) & get ‘clean’ to allow a valid assessment after a few thousand. |
I put 7K miles on the van since I have owned it. I'm not sure before when it was changed. Yeah I'll run the Redline oil for 5k miles then post back? I know Redline is overkill for 5k miles, but I already bought it. Is that too short/too long? I plan to swap to Swepco. _________________ Brandon
Sodo Samba Member
Posted: Fri Feb 23, 2018 2:21 pm Post subject: Re: Manual Transmission Drain Plug - metal |
I’d do the quick flush (200, 500 mi?). If it comes out clean after the flush then go 5000 and look again. Ya gotta get to a clean baseline condition or the magnet can’t tell you anything. Of course it can tell you if yer fooked but what you want is to know is.... if you’re GOOD.
I think you need Swepco for big engines. What yours? _________________
Posted: Fri Feb 23, 2018 2:24 pm Post subject: Re: Manual Transmission Drain Plug - metal |
Sodo wrote: |
I think you need Swepco for big engines. What yours? |
I have stock 1.9 engine with stock transmission. I'll buy some 80w-90 cheap stuff and do a quick flush - 500 miles.
Should I just stick with the RedLine after? I mean if I recall, in the winter I bought the redline because Swepco 'warms up' after 10 miles. _________________ Brandon
Paulbeard Samba Member
Posted: Fri Feb 23, 2018 6:52 pm Post subject: Re: Manual Transmission Drain Plug - metal |
How's your linkage? Wouldn't all the gears be hard to find in the cold, not just one? Cold here too (been at or below freezing all week) and I don't find Swepco to be very different to what was in there, whatever vintage it was. _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
Formerly -> Steward of a 73 Super Beetle (Beater) and 67 Beetle 1300 (Little Max) both names by POs
— dhaavers |
Posted: Fri Feb 23, 2018 8:41 pm Post subject: Re: Manual Transmission Drain Plug - metal |
Paulbeard wrote: |
How's your linkage? Wouldn't all the gears be hard to find in the cold, not just one? Cold here too (been at or below freezing all week) and I don't find Swepco to be very different to what was in there, whatever vintage it was. |
Yeah it's bad. I have a cracked boot. I'll go ahead and buy the shift linkage kit from Van Cafe. I changed the oil. I put the fill plug back in once it started oozing out. Should I have waited till it stopped oozing ? _________________ Brandon
Posted: Fri Feb 23, 2018 9:49 pm Post subject: Re: Manual Transmission Drain Plug - metal |
Yeah it's bad. I have a cracked boot. I'll go ahead and buy the shift linkage kit from Van Cafe. I changed the oil. I put the fill plug back in once it started oozing out. Should I have waited till it stopped oozing ? |
As for filling? I went with this… _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
— dhaavers |
metropoj Samba Member
Posted: Thu Apr 04, 2019 5:05 am Post subject: Re: Manual Transmission Drain Plug - metal |
I figure this is probably the best place for posting some pics of my drain plug ...
Any thoughts on this ? I think it looks OK, not like some of the xmas trees I've seen in the pics !
Unknown condition and mileage used late model tranny installed 28,000 kms ago, filled with Mobil 1 75W90 synthetic. This is about 3-4 years of driving
The plug when I pulled it 'cold' was very 'goopy' at the tip.
I ended up taking the magnet and dipping it into varsol to try and clean off the goop but keep the metal particles in tact .... didn't work that great. I then used my finger to smush away the goopy oil and then let the magnet pkc up all of the metal bits from my finger, as shown in the last pic ...
I am wondering to fill it again with this same oil, or something similar in Synthetics (or dino) I haven't decided ..
I'm thinking it's got some life left, it likes a little grind into 2nd when cold.
I want to check out my hyd clutch system next, everything else in the clutch system was brand new 28,000 kms ago ... _________________ John.
86 TiiCo powered Westy. |
mellowslow Samba Member
Joined: July 31, 2009 Posts: 278 Location: Vacationland
Posted: Sun Jul 14, 2019 6:39 am Post subject: Re: Manual Transmission Drain Plug - metal |
Approx 20K with Swepco 201 in the box
_________________ '87 WBWE FAS Gen V |
Sodo Samba Member
Posted: Sun Jul 14, 2019 9:06 am Post subject: Re: Manual Transmission Drain Plug - metal |
You have “some” clean space on your magnet. Thats a really good sign. And no big parts.
Id fill it with FLAPS gear oil ($16) and drive it a few hundred miles, then drain it hot & fast, with the front wheels about 10-12” higher than the rear. Then put in your next batch of Swepco. Then NEXT time you’ll know your magnet is showing “new” trash only. Ir gives you a better idea what’s currently happening in the trans. And you’re not pre-polluting your new specialty oil at mile-one with old metal trash.
Old transmissions (and rebuilts, which include many hi-miles used parts) require more frequent maintenance than the original trans, which was 100% new and built in a clean-room of super-clean parts. An OEM built trans is a different unit than a rebuilt, it can go 90,000 miles on its oil cuz there is no pre-trash, no “older parts” are putting metal trash into your lubricant. You are wise to check at 20,000 miles.
Think if some fellow defied the mfrs recommendations that the oil doesn’t need changing. And replaced the lubricant every 30k miles. That would be a nicely preserved trans, with gears in perfect condition. But its too late now, the trannies all gave their 90k miles of “trouble-free lifetime” and owners were satisfied. Perhaps not with their head gaskets though.
Seeing how much metal is circulating in your lubricant at 20k, don’t you kinda wish you checked 5,000 miles ago? Luckily you can do this maintenance yourself -lots of Van Owners can’t.
What engine do you have? _________________
Posted: Sun Jul 14, 2019 11:49 am Post subject: Re: Manual Transmission Drain Plug - metal |
Sodo wrote: |
Id fill it with FLAPS gear oil ($16) and drive it a few hundred miles, then drain it hot & fast, with the front wheels about 10-12” higher than the rear. Then put in your next batch of Swepco. Then NEXT time you’ll know you’re magnets showing “new” trash only. And you’re not pre-polluting your new specialty oil with old metal.
What engine do you have? |
Volkswagen of Mexico built AEG code 2.0l with a tuned ECU. Installed with zero mileage out of the crate.
Wow post up data to benefit the list and get a complimentary visual analysis! Many thanks.
Yes, a longer stretch for the change interval. The 201 showed close to original blue color and really didn't seem broken down or contaminated. Guess I could have done worse. _________________ '87 WBWE FAS Gen V |
Sodo Samba Member
Posted: Sun Jul 14, 2019 12:34 pm Post subject: Re: Manual Transmission Drain Plug - metal on plug |
So you’re running about 135HP?
And drive “mellowslow”?
Sounds like a good plan.
You could probably “settle” that nice clear Swepco for a few months then decant the purified oil off the top & run it again.
My oil was perfect green & clear until I did a 3,000 mile trip at 80mph then it turned dark (15,000mi). I have a 173 HP Subaru. I have an elaborate trans cooling system and my trans never gets hotter than 143*F. I suppose the cooling raises the HP capacity of the trans some, but not enough to stand 80mph continuous.
I won’t be doing that again. My new speed is 70. _________________
Posted: Sun Jul 14, 2019 12:44 pm Post subject: Re: Manual Transmission Drain Plug - metal on plug |
Sodo wrote: |
Is an AEG that much more grunty than an ABA? Maybe the tuned ECU has a role but out of the crate they are both 115 hp. _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
— dhaavers |
