calvinater Samba Member
Joined: September 06, 2014 Posts: 3327 Location: 802 The Pointless Forrest
Posted: Fri Feb 23, 2018 9:20 am Post subject: odd endplay |
mock up stage, endplay with no shims is.026, do i need to have flywheel snout turned? or can i get some really thin shims from somewhere? _________________ "Albatross"!
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Fri Feb 23, 2018 9:28 am Post subject: Re: odd endplat |
is that inches or mm's? Don't you want .006"? |
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4856 Location: sanger ca
Posted: Fri Feb 23, 2018 9:39 am Post subject: Re: odd endplat |
Cut flywheel and use thicker shims. _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
mark tucker Samba Member
Posted: Fri Feb 23, 2018 12:59 pm Post subject: Re: odd endplat |
BUTT first!!! if it's a aftermarket crank it may have a bigger raidi(fillet) and the main bearing may not be clearance enough for it keeping the crank from acctuly contacting the thrust serface of the bearing. if it is just clearance the bearing in a lathe...or it will burn up the bearing&crank&kill the case too. |
SRP1 Samba Member
Posted: Fri Feb 23, 2018 3:02 pm Post subject: Re: odd endplat |
[quote="mark tucker"]BUTT first!!! if it's a aftermarket crank it may have a bigger raidi(fillet) and the main bearing may not be clearance enough for it keeping the crank from acctuly contacting the thrust serface of the bearing. if it is just clearance the bearing in a lathe...or it will burn up the bearing&crank&kill the case too.[/quote]
Bingo! 👍 |
Danwvw Samba Member
Posted: Fri Feb 23, 2018 3:15 pm Post subject: Re: odd endplay |
calvinater wrote: |
mock up stage, endplay with no shims is.026, do i need to have flywheel snout turned? or can i get some really thin shims from somewhere? |
You may have a bearing wrong without shims there should be about 1mm of play. 39 Thousandths of an inch. (Note! if the distributor drive gear is installed it could be jammed causing it.)
Correct #4 Main Bearing Placement:
_________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
modok Samba Member
Joined: October 30, 2009 Posts: 26781 Location: Colorado Springs
Posted: Fri Feb 23, 2018 5:25 pm Post subject: Re: odd endplay |
don't check end play with no shims.
Check with two shims, or before putting the case together. |
RWK Samba Member
Posted: Sat Feb 24, 2018 6:48 am Post subject: Re: odd endplay |
Don't know if its been thrust cut, but mic thrust surface 3 places both case half's, seen some case's out here from bad thrust cut, 001-.002.
As above check radius, start with the basics, be careful if you have flywheel cut, no run-out between crank surface and thrust surface allowed! _________________ 73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530 |
Posted: Sat Feb 24, 2018 7:12 am Post subject: Re: odd endplay |
case is not together still in mockup stage working on clearancing at the moment
it seems two of the counter weights are less than .040" from the cam lobes yikes ! Whats minimum acceptable clearance here?
between #3 and #1 at #3 rod cap, and #4 and center main at #4 rod cap _________________ "Albatross"! |
