1993 Eurovan Rear Smoke?
Forum Index -> Eurovan Share: Facebook Twitter
Mattwynn88
Mattwynn88 is offline
PostPosted: Tue Feb 20, 2018 4:49 pm    Post subject: 1993 Eurovan Rear Smoke? Reply with quote
Hey everyone.
Iím currently working on my friends van. I donít know much about euro vans but I know some basics. He has been telling me there is exhaust coming from the rear heater behind the passenger seat. Is this normal? If not what are some things I can look at to fix it!
Any advice is appreciated thanks!
streamr
streamr is offline
PostPosted: Thu Feb 22, 2018 5:04 am    Post subject: Re: 1993 Eurovan Rear Smoke? Reply with quote
Well, I wouldn't think exhaust coming into the vehicle is normal, hope he's driving with the windows down. I would check under the van to see where the exhaust leak is. It's working its way in somehow so I would look for cracks, rust holes, open seams, etc. Good luck.
'02 Weekender
Abscate Premium Member
Abscate is offline
PostPosted: Thu Feb 22, 2018 7:03 am    Post subject: Re: 1993 Eurovan Rear Smoke? Reply with quote
He's got steam coming from a broken heat rear exchanger, gazing into my crystal ball. Ask him if the smoke has a sweet odour. Thats French for smell
.ssS!
Mattwynn88
PostPosted: Fri Feb 23, 2018 8:23 pm    Post subject: Re: 1993 Eurovan Rear Smoke? Reply with quote
Thanks for the reply! It does have a little sweet odor smell to it. When you say rear exchanger is the the heater core youíre talking about?
Abscate is offline
PostPosted: Fri Feb 23, 2018 9:00 pm    Post subject: Re: 1993 Eurovan Rear Smoke? Reply with quote
Correct, rear heater core
.ssS!
Mattwynn88
PostPosted: Sat Feb 24, 2018 5:24 am    Post subject: Re: 1993 Eurovan Rear Smoke? Reply with quote
Is it possible for it to leak up to the floor?
Abscate is offline
PostPosted: Sat Feb 24, 2018 5:27 am    Post subject: Re: 1993 Eurovan Rear Smoke? Reply with quote
Probably if it is spritzing? The cooling system is under pressure so coolant could spray up, I guess. That pressure is important for your engine so I would explore and fix that asap
.ssS!
Mattwynn88
PostPosted: Sun Feb 25, 2018 1:09 pm    Post subject: Re: 1993 Eurovan Rear Smoke? Reply with quote
Rad thank you! I will check that and see! Thanks for your help!
Reply to topic    Forum Index -> Eurovan All times are Mountain Standard Time/Pacific Daylight Savings Time
