RossM96 Samba Member
Joined: September 25, 2017 Posts: 33 Location: San Diego
Posted: Sat Feb 24, 2018 3:41 pm Post subject: Dropped Distributor spring |
Hi everyone, I dropped the distributor so we spring in the hole on the sidewall of the distributor drive shaft cylinder. I don’t believe it went straight down. Is there any way to possibly find the spring without disassembling the engine? Also where does the side hole go and is a loose spring an actual issue?
Thanks! _________________ 1972 Baywindow
2000cc |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76939 Location: Sneaking up behind you
Posted: Sat Feb 24, 2018 3:49 pm Post subject: Re: Dropped Distributor spring |
Quote: |
1972 Baywindow
2000cc |
Type 4? _________________ Glenn
Member #1009
#BlueSquare |
Posted: Sat Feb 24, 2018 3:58 pm Post subject: Re: Dropped Distributor spring |
Yes TYpe 4, sorry. _________________ 1972 Baywindow
2000cc |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51150 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sat Feb 24, 2018 4:11 pm Post subject: Re: Dropped Distributor spring |
Best not to leave it in there, the cam gear well is somewhat enclosed and may direct it into the gear. Time to go fishing with a magnet on a bendy stick, you may also reach it via the taco plate. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sat Feb 24, 2018 4:13 pm Post subject: Re: Dropped Distributor spring |
A magnet and wire have been what I’ve been trying,no luck so far but I’ll keep trying. What is the taco plate? _________________ 1972 Baywindow
2000cc |
Posted: Sat Feb 24, 2018 4:16 pm Post subject: Re: Dropped Distributor spring |
~3" diameter disc on the bottom of the sump at the right rear, it's attached with 2 10mm headed bolts. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sat Feb 24, 2018 4:18 pm Post subject: Re: Dropped Distributor spring |
I Was looking at that. I’ll give it a try! _________________ 1972 Baywindow
2000cc |
Posted: Sat Feb 24, 2018 4:23 pm Post subject: Re: Dropped Distributor spring |
Drain the oil first _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sat Feb 24, 2018 4:44 pm Post subject: Re: Dropped Distributor spring |
No luck in the taco plate. I’m going to keep trying. _________________ 1972 Baywindow
2000cc |
KentABQ Samba Member
Joined: September 11, 2016 Posts: 2406 Location: Albuquerque NM
Posted: Sat Feb 24, 2018 5:03 pm Post subject: Re: Dropped Distributor spring |
Don't over torque the bolt installing the taco plate.
Only 9 ft-lb.
Or you'll be buying a new engine block. _________________ -Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!" ---WildIdea
Bus ownership via emoticons:
---williamM |
Posted: Sat Feb 24, 2018 5:11 pm Post subject: Re: Dropped Distributor spring |
That applies to the strainer plate that's in the middle and further forward. The M6 bolts on the taco are 5' lb (60" lb).
Here's an idea of where you are exploring in case your X-ray vision is failing
Слава Україні! |
Posted: Sat Feb 24, 2018 5:42 pm Post subject: Re: Dropped Distributor spring |
Thanks for the specs, the bolts are back in now. No spring found. _________________ 1972 Baywindow
2000cc |
Posted: Mon Feb 26, 2018 12:10 am Post subject: Re: Dropped Distributor spring |
After about 8 hours of fishing through the hole, the taco plate, around the strainer, and the case relief plate (plug next to the oil filter, a bit bigger than a quarter), I still don’t have that spring. Is it possible to remove the oil pump without dropping the motor?
This spring is little and nothing like losing a washer in the case, is it certain death to my motor if it isn’t found/removed? I want to do it right, especially if it’s absolutely critical but the labor alone of splitting/rebuilding my case will be huge.
I’m being loaned some sort of borescope this week, maybe I’ll get lucky. I’ll be trying a smaller magnetic stick too. _________________ 1972 Baywindow
2000cc |
Posted: Mon Feb 26, 2018 12:20 am Post subject: Re: Dropped Distributor spring |
Also for what it’s worth, this morning before round 2 of fishing I rotated the engine by hand one pulley revolution in each direction several times hoping to get the spring to fall off the cam gear and onto the sump plate if it were resting on the gear. No good there either, and no binding or indication of the spring being on the gear.
Are there resting places for the spring to be below the gears but above the sump? _________________ 1972 Baywindow
2000cc |
curtp07 Samba Member
Posted: Mon Feb 26, 2018 5:01 am Post subject: Re: Dropped Distributor spring |
Oh man! This has always been a fear of mine...hope you get it! _________________ Subaru |
SGKent Samba Member
Posted: Mon Feb 26, 2018 9:48 am Post subject: Re: Dropped Distributor spring |
time for a video camera with a small camera head. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
tommu Samba Member
Posted: Mon Feb 26, 2018 3:43 pm Post subject: Re: Dropped Distributor spring |
Something like this might work:
https://www.amazon.com/Best-Sellers-Industrial-Scientific-Endoscopes/zgbs/industrial/8297406011
There will be some useful pictures on this here forum, like this:
Do you have a compressor? If all else fails you could try blowing some air in there to move the spring. It's light and everything around the gears and case is so goopy it can hang out anywhere in the vicinity. you could always wash some oil down there in the hope it'll take the spring with it to the sump.
If the spring has reached the sump I'd expect it to get washed to the oil strainer. You could try filling that with oil too to see if it washes down?
You can, in theory, remove the pump without splitting the case. It might not want to move so be careful not to break an ear off it with a pry bar!
Good luck.
(Edit: better photo of Mr Kent's fine engine) _________________ |
SGKent Samba Member
Posted: Mon Feb 26, 2018 4:14 pm Post subject: Re: Dropped Distributor spring |
I haven't had the distributor out in awhile but I don't recall a relief where the spring can fall in, as long as the gear is in. Did this happen when the gear was out? Is it possible it went somewhere else?
SGKent Samba Member
Posted: Mon Feb 26, 2018 4:21 pm Post subject: Re: Dropped Distributor spring |
tommu wrote: |
Good luck.
(Edit: better photo of Mr Kent's fine engine) |
off Internet:
Posted: Mon Feb 26, 2018 5:30 pm Post subject: Re: Dropped Distributor spring |
Tommu, an air compressor and passing oil through are other things I tried, but no luck! Nice to know someone else is thinking of the same ideas though, thanks for offering advice! I’ll probably try again next weekend when I’m back with my bus, it’s all I can do until I give in and split the case.
SGKent, the hole would be in the 12 o’clock position on your distributor hole photo. The gear was in when I lost the spring. I was having trouble getting the distributor shaft to mate up with the drive gear so I used a magnet to lift the driveshaft and spring out of the motor to make sure it even fit my new distributor. I then put the shaft back in the hole, then was putting the spring back onto the driveshaft but it kept falling sideways. When I was trying to reorient it the spring went into the hole on the sidewall, about the size of a dime with its lower edge about flush with the top of the distributor drive shaft.
Thanks for your help! _________________ 1972 Baywindow
2000cc |
