73Nick Samba Member
Joined: July 24, 2016 Posts: 16 Location: Sarasota,Florida
Posted: Sun Feb 25, 2018 7:56 pm Post subject: Type 4 Motor in My THING |
So I bought a THING 6 months ago.
I did some research and found out the motor that is in it is a Type 4 flat that out of a 72 Transporter.
The question I have is, will the THING stock transmission hold up to this motor? When I drive it, it seems the trans is slipping. From 2nd to 4th. Once u shift and get in to the gas the car had no pull, just high rpm's. |
CraigInPA Samba Member
Joined: March 09, 2011 Posts: 212 Location: Norristown, PA
Posted: Mon Feb 26, 2018 6:54 am Post subject: Re: Type 4 Motor in My THING |
Sounds like you need a new clutch... |
73Nick Samba Member
Posted: Mon Feb 26, 2018 6:07 pm Post subject: Re: Type 4 Motor in My THING |
CraigInPA wrote: |
That's what I was think, just needed some reassurance.
Is it possible that when the engine swap was done that the clutch for the Type 1 1600 could have been installed on the Type 4 engine? Or would it not even bolt up. |
Posted: Wed Feb 28, 2018 10:32 am Post subject: Re: Type 4 Motor in My THING |
73Nick wrote: |
CraigInPA wrote: |
Have you checked your clutch adjustment?
Not at all sure of the clutch options, you may has either a 210 or 215 clutch, I would think either would work fine with the right throwout bearing and guide. Don't think you could have the larger 228mm clutch as the engine and tranny probably would not have mated and the Thing starter would not have worked if they did. |
RWK Samba Member
Posted: Thu Mar 01, 2018 6:08 pm Post subject: Re: Type 4 Motor in My THING |
I had a T4 in my baja, 30 years ago, but had a KEP converted T1 flywheel/clutch, didn't think T4 flywheel/clutch would work? but yes clutch slippage. _________________ 73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530 |
RWK Samba Member
Posted: Thu Mar 01, 2018 6:39 pm Post subject: Re: Type 4 Motor in My THING |
Never mind my last reply, I had an auto stick motor, so went with a T1 flywheel vs. T4 it was cheaper and T1s are forged vs. cast I was told. _________________ 73 Type 181
63 Type 113
73Nick Samba Member
Posted: Fri Mar 09, 2018 7:19 pm Post subject: Re: Type 4 Motor in My THING |
Wildthings wrote: |
73Nick wrote: |
CraigInPA wrote: |
You where correct sir. The clutch had no freeplay. Readjusted clutch cable and problem solved. |
