'72-74 Turn signal repair Plastic indicator cancel part vendor
Page: 1, 2, 3  Next
nilza
nilza is offline
PostPosted: Fri Feb 02, 2018 4:10 am    Post subject: '72-74 Turn signal repair Plastic indicator cancel part vendor Reply with quote
just an FYI for those with '72-74 indicator problems
Cheap for a couple of bucks, means you may be able to fix those old indicator stalks
https://www.shapeways.com/product/43HKBQHEM/indica...arketplace
The little hammer can be busted too
https://www.shapeways.com/product/4245BL4JY/flash-cancel-hammer?optionId=64604212
Sorry guys I messed up the link the first time
Thank you
edited subject title so it would be easier to search for.
Tcash
still floating around the web somewhere
mygreenbus
mygreenbus is offline
PostPosted: Fri Feb 02, 2018 4:17 am    Post subject: Re: just an FYI for those with '72-74 indicator problems Reply with quote
How may we ask?
'72 Bus
alman72
alman72 is offline
PostPosted: Fri Feb 02, 2018 4:28 am    Post subject: Re: just an FYI for those with '72-74 indicator problems Reply with quote
My guess is that Nilza will 3d print the part in the switch box that cracks. If that is the case, we will need a good write up/pics of the inside of one of these evil bastards. I tried to open a broken one, and a mini explosion of parts went all over, with no hope of me putting them back where they belonged. maybe I opened it upside down, and they wanted to pop out, I don't know. that's why we would need a write up
nilza
nilza is offline
PostPosted: Fri Feb 02, 2018 5:04 am    Post subject: Re: just an FYI for those with '72-74 indicator problems Reply with quote
Sorry guys I messed up the link the first time,
They are indeed a pain to fix, at least if you are game to give it a go you can get hold of the parts for a few bucks now.
vwwestyman
vwwestyman is offline
PostPosted: Fri Feb 02, 2018 8:00 am    Post subject: Re: just an FYI for those with '72-74 indicator problems Reply with quote
Oh baby, that would be great!!
Do you only need one to fix it? Because I plan to order right away!
Dave Cook
Stuartzickefoose wrote:
I'm gonna punch vwwestyman then shake his hand when I meet him.
notchboy wrote:
Ill just punch you in the face. Wink
1973 Wild Westerner
My Thing
www.thefosterdads.com
Lil Lulu
Lil Lulu is offline
PostPosted: Fri Feb 02, 2018 9:57 am    Post subject: Re: just an FYI for those with '72-74 indicator problems Reply with quote
Now THAT is cool.
'65 Beetle "Lil' Lulu"- Ruby Red
1600 stock from '71 bus
'72 Deluxe - Niagara Blue w/pastelwiess Camper Special 2L dual 40 Webers 002
'74 Hightop Weekender "Dixie" 1800 34 Del singles
nilza
nilza is offline
PostPosted: Fri Feb 02, 2018 12:49 pm    Post subject: Re: just an FYI for those with '72-74 indicator problems Reply with quote
Just one westyman,
And the 3rd part (which is less common) is the main part that the stalk is attached to. I dont have this modeled up yet.
We haven't got too much testing on these yet, but thought would make them available though shapeways for the brave to play around with.
alman72
alman72 is offline
PostPosted: Fri Feb 02, 2018 12:54 pm    Post subject: Re: just an FYI for those with '72-74 indicator problems Reply with quote
damnit, I will give it a another go with one of my cores. I will take a pic or two, as well. pieces ordered
vwwestyman
PostPosted: Fri Feb 02, 2018 12:55 pm    Post subject: Re: just an FYI for those with '72-74 indicator problems Reply with quote
Just one westyman,
Is the cancel hammer a part of the other? Or would I need to order both in order to complete a repair?
(I'm assuming all those plastic pieces need replacing!)
For 8ish bucks, I'm more than willing to give it a try!
Dave Cook
1973 Wild Westerner
My Thing
alman72
alman72 is offline
PostPosted: Fri Feb 02, 2018 2:33 pm    Post subject: Re: just an FYI for those with '72-74 indicator problems Reply with quote
both would be all new plastics in the unit.
nilza
nilza is offline
PostPosted: Fri Feb 02, 2018 2:53 pm    Post subject: Re: just an FYI for those with '72-74 indicator problems Reply with quote
Awesome! Thank you
Amskeptic
Amskeptic is offline
PostPosted: Fri Feb 02, 2018 3:02 pm    Post subject: Re: just an FYI for those with '72-74 indicator problems Reply with quote
nilza wrote:
Awesome! Thank you
The Beginning Of A New Day.
Colin
(hey, how about a set of Mercedes M117 timing chain guides?)
(heck, how about a helical spiral odometer gear set for a '90 Lexus LS400??)
www.itinerant-air-cooled.com
MikeyM73
MikeyM73 is offline
PostPosted: Fri Feb 02, 2018 6:25 pm    Post subject: Re: just an FYI for those with '72-74 indicator problems Reply with quote
Hi all,
So I have a '73 and was told (I have no idea) that '73 is a "one year only" part.. so would this work on mine (because it needs darn near everything)?
New guy, here, familiar with all things automotive but am learning every day about our newish (to us) resto bus.
Thanks,
Mikey
alman72
alman72 is offline
PostPosted: Sat Feb 03, 2018 6:38 am    Post subject: Re: just an FYI for those with '72-74 indicator problems Reply with quote
^yup. for 73. Saying one year only is kind of not correct, but it is the only year that is a full year. I have seen a few late 72 and early 74
vwwestyman
PostPosted: Sat Feb 03, 2018 8:50 am    Post subject: Re: just an FYI for those with '72-74 indicator problems Reply with quote
Alrighty, I just ordered both pieces. Excited to give this a try!
Dave Cook
1973 Wild Westerner
My Thing
ElSketchmobile
ElSketchmobile is online now
PostPosted: Sun Mar 04, 2018 4:20 pm    Post subject: Re: just an FYI for those with '72-74 indicator problems Reply with quote
Any updates/feedback?
'73 Campmobile
1.8 base, 2lt mod on reclaimed '74 engine, code CB
Dual Weber 34 ict's (worn, torn, leaky and searching for an economical replacement)
009 Distributor with electronic ignition
kaiisons
kaiisons is offline
PostPosted: Sun Mar 04, 2018 4:52 pm    Post subject: '72-74 Turn signal switch repair Reply with quote
I worked with @Nilza on this unit here in Australia and its currently operating perfectly in my 1973 bus.
'72-74 Turn signal switch repair parts
MikeyM73
MikeyM73 is offline
PostPosted: Wed Mar 21, 2018 9:52 pm    Post subject: Re: just an FYI for those with '72-74 indicator problems Reply with quote
Greetings all. Guys, how do I get one or all of these parts? Can anyone tell me if the stalk can be reattached to whatever it originally attached to? Ummm.... and how?
Thanks much,
Mikey
alman72
alman72 is offline
PostPosted: Thu Mar 22, 2018 11:16 am    Post subject: Re: just an FYI for those with '72-74 indicator problems Reply with quote
Thanks much,
Mikey
link in 1st post to order. And is sounds like you have other problems if your stalk is in your hand. What did your mother tell you about handling it too rough? I don't think you will know until you get in there. Units are rare, so you are prob just going to have to order the parts, and open up the indicator when it shows up and see hat you have going on. If you cant fix it, I can give you a stalk if you cover shipping. It wont be pretty.
alman72
alman72 is offline
PostPosted: Wed May 09, 2018 4:59 pm    Post subject: Re: just an FYI for those with '72-74 indicator problems Reply with quote
I just rebuilt 2 of these. what a nightmare, but they seem to be working. I will test them someday.
Page: 1, 2, 3  Next
