My 1966 Fastback build up
Page: Previous  1, 2, 3 ... , 18, 19, 20  Next
W1K1
W1K1 is offline
PostPosted: Mon Jul 17, 2017 8:51 am    Post subject: Re: My 1966 Fastback build up Reply with quote
That's a whole lot better start than the other body you were working with.
http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap
Evilgtiguy
Evilgtiguy is offline
PostPosted: Mon Jul 17, 2017 8:56 am    Post subject: Re: My 1966 Fastback build up Reply with quote
Absolutely!
66 sunroof Fastback http://www.thesamba.com/vw/forum/viewtopic.php?t=590530
84 Rabbit GTI (gone and missed)
80 Rabbit (gone and missed)
92 Nissan 240SX turbo
Evilgtiguy
PostPosted: Sun Nov 19, 2017 3:16 pm    Post subject: Re: My 1966 Fastback build up Reply with quote
Hey, it's been a while since I've posted and I've been working on the car here and there but now that the snow is flying I'm starting to get back into the grove of things. I have a question; are the couplers that go from the heat exchangers to the exhaust manifold absolutely necessary and if so where can I get them from? I don't plan on driving the car in cold weather or even wet weather if I can avoid it. Thoughts?
Donnie strickland
Donnie strickland is offline
PostPosted: Sun Nov 19, 2017 3:25 pm    Post subject: Re: My 1966 Fastback build up Reply with quote
Which parts do you mean?
71 Elm Green FI A/T Squareback
Evilgtiguy
PostPosted: Sun Nov 19, 2017 4:44 pm    Post subject: Re: My 1966 Fastback build up Reply with quote
Im talking about this connection between the heat exchanger and heat box
ataraxia
ataraxia is offline
PostPosted: Sun Nov 19, 2017 5:08 pm    Post subject: Re: My 1966 Fastback build up Reply with quote
All that goes there is a wide clamp - there's no rubber.
Even if you don't use the heat - it's a good idea to get the clamp on it to help keep the exhaust stench out of the car.
It's #46 on the pic:
Evilgtiguy
PostPosted: Sun Nov 19, 2017 5:13 pm    Post subject: Re: My 1966 Fastback build up Reply with quote
Ok that makes sense the fan would blow all those fumes in. I have that clamp on my bench somewhere. Thanks for the info.
Evilgtiguy
PostPosted: Sun Mar 04, 2018 3:52 pm    Post subject: Re: My 1966 Fastback build up Reply with quote
It's been a while since I've posted. No I haven't abandoned my project, I've been chipping away at some small parts of the project through the winter. We've had a brutal winter over here and working in the cold garage hasn't been a priority.
The plan is to set the end play on the crankshaft, mate the engine to the transaxle, mount the body to the pan and then send it to the body shop this summer. Here are a couple of pics.
Bobnotch
Bobnotch is offline
PostPosted: Mon Mar 05, 2018 1:02 pm    Post subject: Re: My 1966 Fastback build up Reply with quote
Yeah, I know it's been cold this winter. I haven't been doing much on the TA this winter either. Kind of hard to get motivated when the high's for the day are still below 32*F. Doesn't help when you get 2 nice days, followed by 3 days of near zero temps.
Nice job on what you got done though. Very Happy
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
Mike Fisher
Mike Fisher is offline
PostPosted: Mon Mar 05, 2018 1:54 pm    Post subject: Re: My 1966 Fastback build up Reply with quote
I think I would leave the engine out when it goes to the body/paint shop to avoid overspray on the engine. They should paint the engine compartment too.
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
bobnorman
Samba Newfoundlander
bobnorman is offline
PostPosted: Mon Mar 05, 2018 5:06 pm    Post subject: Re: My 1966 Fastback build up Reply with quote
Good to see you back at it. Looks like you're making good progress. I know what you mean about heading out to the cold garage. Tough to stay at it with the weather as cold as it's been.
Air does not freeze. Air does not boil.
http://www.thesamba.com/vw/forum/viewtopic.php?t=289807
Evilgtiguy
PostPosted: Mon Mar 05, 2018 5:40 pm    Post subject: Re: My 1966 Fastback build up Reply with quote
Thanks guys! I've started to lurk at everyone's projects to see how things are going. So I should leave the engine out and just put the pan and body together and send it off to the body shop eh? I could mask the transaxle easily enough. If not I'd have to use a flat trailer and put the body on it I suppose. What would be better? With the flat deck I'm worried about transport and the body being damaged being put on and taken off etc. I have to go about 20km to the shop when I do make that trek.
Mike Fisher
PostPosted: Mon Mar 05, 2018 6:12 pm    Post subject: Re: My 1966 Fastback build up Reply with quote
I'd strap the body back on the chassis & tow it on a flatbed trailer. Tie your wood body dolly on the back of the trailer for the Body Shop to use.
andybla
andybla is offline
PostPosted: Tue Mar 06, 2018 4:12 am    Post subject: Re: My 1966 Fastback build up Reply with quote
Careful, that's asbestos Wink
Evilgtiguy
PostPosted: Tue Mar 06, 2018 5:33 am    Post subject: Re: My 1966 Fastback build up Reply with quote
Asbestos?
andybla
andybla is offline
PostPosted: Tue Mar 06, 2018 5:51 am    Post subject: Re: My 1966 Fastback build up Reply with quote
https://en.wikipedia.org/wiki/Asbestos
That stuff wrapped around the heat exchangers Wink
Known to cause cancer...
Also found in other things like older brake pads
Evilgtiguy
PostPosted: Tue Mar 06, 2018 6:45 am    Post subject: Re: My 1966 Fastback build up Reply with quote
Oh yes. I’ll make sure that doesn’t become airborne! All my brake Bada are new now and I wore a respirator when I took the old ones off. Thanks for the heads up.
Bobnotch
Bobnotch is offline
PostPosted: Tue Mar 06, 2018 11:18 am    Post subject: Re: My 1966 Fastback build up Reply with quote
Since the pan looks done (or is it?), then I put a new seal in place and bolt it on, then send it to the body shop. That way you know ALL of the bolt holes line up. Ask Steve about that one. Wink
Tram wrote:
Tram wrote:
Evilgtiguy
PostPosted: Tue Mar 06, 2018 1:15 pm    Post subject: Re: My 1966 Fastback build up Reply with quote
The pan is done and I have a new seal. Oddly enough I’m missing a bracket that goes from the pedal assembly to the pan. Gotta dig around for that but I can always do that later.
Donnie strickland
PostPosted: Tue Mar 06, 2018 6:30 pm    Post subject: Re: My 1966 Fastback build up Reply with quote
I wouldn't worry about that. In that form, it's not friable, and even if it was, it would take years of exposure to cause health problems, and there's not enough material there to do that.
Asbestos is still allowed in brake pads, as explained specifically by the EPA:
https://www.epa.gov/asbestos/us-federal-bans-asbestos
Page 19 of 20
