AS41 cylinder cut out dimension
Wayne S. Johnson
Wayne S. Johnson is offline
PostPosted: Wed Mar 07, 2018 11:58 pm    Post subject: AS41 cylinder cut out dimension Reply with quote
I have a new AS41 case, the cylinder cut out is 87.13mm. The AA cylinder (VW 8550T1, STD 85.5mm) is 89.40 at the bottom and 89.90 at the step. Measured the cylinder ID at 85.38mm and they fit in the 043 heads.
From CIP1 VWC-311-198-069-B:
Our 1600cc piston & cylinder kit slips right into place of the stock P&Cs in any air-cooled 15-1600cc engine.
Which dimension is off?
Additional products https://www.thesamba.com/vw/classifieds/search.php?username=Wayne+S.+Johnson
Additional products with Bluetooth http://www.thesamba.com/vw/classifieds/detail.php?id=2097231
Last edited by Wayne S. Johnson on Thu Mar 08, 2018 12:52 am; edited 1 time in total
Slow 1200
Slow 1200 is offline
PostPosted: Thu Mar 08, 2018 12:20 am    Post subject: Re: AS41 cylinder cut out dimension Reply with quote
None, you have a 1200 case
Wayne S. Johnson
PostPosted: Thu Mar 08, 2018 12:56 am    Post subject: Re: AS41 cylinder cut out dimension Reply with quote
I have seen 1600 cases AS41 043 101 102 A for sale, I have the same part number on my cases.
The 1200 part number is 113 101 102 B and they look different at the cylinder cut out.
It would be helpful if someone can masure 1600 cases AS41 043 101 102 A, or any 1600 cases AS41 and 85mm cylinder at the bottom step.
Thanks,
Wayne
Slow 1200
PostPosted: Thu Mar 08, 2018 7:57 am    Post subject: Re: AS41 cylinder cut out dimension Reply with quote
1200 cases have 87mm cylinder registers, 1300/1500/1600 cases have a 90mm register
The exception are some 70s 1200 german cases which do have the large 90mm register,
