Rocky Mountain Westy Bumpers
Page: Previous  1, 2, 3  Next
eruiz91
eruiz91 is offline
PostPosted: Fri Mar 09, 2018 7:02 pm    Post subject: Re: Rocky Mountain Westy Bumpers Reply with quote
Hey All,
Looks like this forum hasn't been active for quite awhile but I was wondering if people would weigh in on their opinions of the Rocky Mountain Westy Twin Peaks Bumpers vs the GoWesty Plate Steel Bumpers. I'm trying to decided which ones to go with. Also, I like the idea of GoWesty's swing arm that attaches to the bumper instead of to the van's body itself, anybody out there have the GoWesty swing arm? What do you think of it? Pros and Cons? Last thing: Does anyone know if GoWesty's swing arm will work on Rocky Mountain Westy's Rear Twin Peaks Bumper?
Look forward to hearing what people think,
Cheers
michaelbteam
michaelbteam is offline
PostPosted: Fri Mar 09, 2018 9:09 pm    Post subject: Re: Rocky Mountain Westy Bumpers Reply with quote
No contest, IMO. I installed [easily] the Twin Peaks bumpers on my Westy two years ago and could not be happier.
Red Beard
Red Beard is offline
PostPosted: Sat Mar 10, 2018 7:57 am    Post subject: Re: Rocky Mountain Westy Bumpers Reply with quote
Cheers
I asked around about this maybe a couple of years ago. I canít remember the details but I concluded it probably wasnít going to work. At the time, I called RMW and asked if they were ever going to do another bumper mount swing away system and they said they were working on something. Of course I havenít seen or heard anything since.
1990 Vanagon, FAS Gen V 2.0T, AT w/ Peloquin diff, NAHT conversion
Royb
Royb is offline
PostPosted: Sun Mar 11, 2018 11:17 am    Post subject: Re: Rocky Mountain Westy Bumpers Reply with quote
I think the RMW bumper looks worlds better, and it comes with a built-in hitch. If only there was a parent discount....
1991 Westy
physast
physast is offline
PostPosted: Sun Mar 11, 2018 2:23 pm    Post subject: Re: Rocky Mountain Westy Bumpers Reply with quote
Installed mine last year and I love them. I was going through the same process. I ultimately decided on the RMW bumpers because of the looks and strength.
I was contemplating the GoWesty bumpers only because of the bolt on attachments, but eventually convinced myself that if I decide to do a swing away tray or tire carrier that the RMW design for that was also stronger.
1967 L633 VW beetle (currently being restored...slowly)
1991 Orly Blue Vanaru 2.5L
jimf909 Premium Member
jimf909 is offline
PostPosted: Sun Mar 11, 2018 8:51 pm    Post subject: Re: Rocky Mountain Westy Bumpers Reply with quote
Cheers
I believe the GW swing aways wonít work on the RMW bumpers b/c I believe the GW pieces mount outboard of where the RMW end caps attach to the bumpers. Plus a few other reasons that I donít recall when I was looking into this. Frankly, Iíve seen the GW units and it looks like they were designed to a low end price point. The hardware, fit and finish all look two steps down.
I do like my RMW bumpers! They work as a very solid step when climbing around on the van.
https://www.thesamba.com/vw/forum/viewtopic.php?t=650111&highlight=
Current: 1990 Westy Camper - Bostig RG4, 2wd, manual trans w/Peloquin, NAHT high-top, Flash Silver, seam rust, bondo, etc., etc.
eruiz91
eruiz91 is offline
PostPosted: Mon Mar 19, 2018 2:41 pm    Post subject: Re: Rocky Mountain Westy Bumpers Reply with quote
Thanks for your opinions everyone! Sounds like everybody loves their RMW bumpers. Anybody unhappy with the RMW swing away arm? was it difficult to install?
Thanks
erste
erste is offline
PostPosted: Mon Mar 19, 2018 3:13 pm    Post subject: Re: Rocky Mountain Westy Bumpers Reply with quote
I like the swing a lot. Really solid and well designed. Installation isn't "easy", but the instructions are thorough.
I ended up having to wallow out some of the holes because they didn't line up exactly. I also cross threaded more than a few of the captive square nuts, but they sent out replacements for free with the rest of my order (spare tire mounts were out of stock). It's kind of a pain in the ass trying to bolt that inner brace in place since you're trying to work through the vent, but it's not that bad.
porterbrown
porterbrown is offline
PostPosted: Mon Mar 19, 2018 5:58 pm    Post subject: Re: Rocky Mountain Westy Bumpers Reply with quote
I love the swing away, and it was a fun install. Brilliant design with the hand-hold that allows you to maneuver the vent bracket into place.
'90 Westfalia GL Automatic
eruiz91
eruiz91 is offline
PostPosted: Thu Mar 22, 2018 12:33 pm    Post subject: Re: Rocky Mountain Westy Bumpers Reply with quote
Anybody out there with the GoWesty Steel Bumpers and the bumper mount swing away arm? Whats your opinion?
dobryan
dobryan is offline
PostPosted: Thu Mar 22, 2018 1:07 pm    Post subject: Re: Rocky Mountain Westy Bumpers Reply with quote
Since this is a RMW topic you likely will not reach much of your desired audience.
Try a search on gowesty bumper,, topic title.
https://www.thesamba.com/vw/forum/search.php?searc...=titleonly
Dave O
Join the Vanagon Rescue Squad on the VanAlert app.
http://vanalert.com/
Building a bus for travel in Europe
Bills85Westy
Bills85Westy is offline
PostPosted: Wed Jul 11, 2018 10:30 pm    Post subject: Re: Rocky Mountain Westy Bumpers Reply with quote
I'm curious if anyone has had problems with the finish on their Twin Peaks bumpers. I have a front and rear and the finish on the front bumper is rusting from underneath. The rear bumper which sees the most physical abuse is fine.
These are five years old so I have absolutely no complaints with these bumpers or with RMW. I
I was just surprised because they are powder coated. I'm not really sure what the acceptable life span for powder coating that lives outside is supposed to be.
What shows up as white in this flash photo is the finish bubbled up.
I promise that my Doka is not as dirty as this flash photo makes it look!
85 Westfalia Syncro (conversion)
SAH 1.8T Conversion - 2005 AWP
Engine Conversion Thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=612144&highlight=
85 Doka L345 Grey - 1.9L
iliketowalk
iliketowalk is offline
PostPosted: Thu Jul 12, 2018 10:29 am    Post subject: Re: Rocky Mountain Westy Bumpers Reply with quote
Looks like the rust may have started at the speedclips and migrated under the finish from there?
1984 Westfalia Camper "Westy Pete" - ARB/Solar [Sold but still in the family]
1987 Westfalia Weekender "Big Blue" - EJ22/Burley UCA,Bumper/CLK/215.70.16s [Sold]
1985 Vanagon "Frank" - AAZ/NAHT/Westy [RIP #CarrFire]
1990 Carat "SportVan" [RIP #CarrFire]
1987 Syncro "Miles" [RIP #CarrFire]
1987 Syncro "Boz" - Bostig/FrontRunner/Decoupler/BFG/LED/LMNOP [Sold]
1989 Delica L300 4x4 [Sold]
1986 Weekender "Birch"
MsTaboo
MsTaboo is offline
PostPosted: Thu Jul 12, 2018 11:27 am    Post subject: Re: Rocky Mountain Westy Bumpers Reply with quote
The problem with powder coating is it's like a skin and when rust starts at any scratch or chip it spreads under that skin and is very hard to remedy without totally stripping all the pc off. Seems to be more of a problem with flat flexible parts or parts with sharp edges. Unlike regular paint you can't really sand pc very well, it won't feather like paint.
Manufacturers like pc because it's fast and easy. However the surfaces need to be super clean for the stuff to bond properly to the steel.
When you tighten down the hardware onto the pc it can crack and if it doesn't have a tight bond then moisture gets under the skin and away goes rust.
When I assembled my RMW bumpers I sprayed all the hardware and overlapping joints with Fluid Film as a barrier to help prevent rust from starting. I also try to "bandage" any chips with a dab of paint so rust can't get a toehold.
I love my RMW Twinpeak bumpers but wish they had used regular paint, it's so much easier to repair or repaint.
Currently:
90 Syncro Westy/Zetec
-Syncro, not just a sticker-
You can lead a person to reason but you can't make them think.
The internet is like a toilet, useful but full of crap.
kourt
kourt is offline
PostPosted: Thu Jul 12, 2018 2:21 pm    Post subject: Re: Rocky Mountain Westy Bumpers Reply with quote
Yes, my RMW Twin Peaks bumpers all have some sort of finish problem. In the case of the front bumper, I had it re-powdercoated last year. The rear bumper has been a little better. I camp at the beach, and that environment is really tough on steel of any sort.
The bumpers are so good at what they do, however, that I tolerate the finish problem. I can strip and repaint them someday, I guess, but my van is all about function over form, so a little rust doesn't bug me too much. I don't want to be driving a garage queen--my van must always show road grime and wear.
kourt
Bills85Westy
PostPosted: Thu Jul 12, 2018 4:54 pm    Post subject: Re: Rocky Mountain Westy Bumpers Reply with quote
Thanks all for the feedback.
I agree that the powder coating once damaged is difficult to maintain. These issues are contained to the center section over the hitch so I'm going to sandblast and paint this with an automotive finish.
I agree that these bumpers are good at what they do and my truck sees enough use that it will never be a show queen. I'm looking for tidy and functional!
Onward.
ragnarhairybreeks
ragnarhairybreeks is offline
PostPosted: Thu Jul 12, 2018 7:48 pm    Post subject: Re: Rocky Mountain Westy Bumpers Reply with quote
Iíve seen similar rust bubbling on another set of RMW bumpers. Itís a little disappointing.
I can only guess why the PC is not up to snuff on them.
- the bumpers were not blasted before PC
- if the steel had mill scale, ie wasnít oil pickled sheet, the mill scale was not removed.
- single coat PC
Iíve worked a bit with PC on aluminum, for off shore bouys, and the stuff was darned tough. For sure there have been electrolytic failures around fasteners, but on the whole itís impressive.
And parts Iíve had to modify that have been properly PC could be sanded and feathered.
Iíll guess with RMW, to keep costs reasonable, the bumpers werenít blasted and itís only one coat of PC.
Iím not meaning to be negatively critical, costs have to be kept in check.
Alistair
'86 7 passenger syncro, converted to westy pop top, project still in progress
https://shufti.blog/
Old address still works...
http://shufti.wordpress.com
BavarianWrench
BavarianWrench is offline
PostPosted: Fri Jul 13, 2018 7:34 am    Post subject: Re: Rocky Mountain Westy Bumpers Reply with quote
I liked my RMW rear bumper. I forget what material the washer was at this point? The stainless washers can spin into the PC and then a point of compromise has been made in the finish. Care while tightening or possibly a different washer material could be used to limit impact to the finish. Once tight if a bumper is bumped it will score the finish should it move slightly too. I don't see a better way around it unfortunately.
Maine
Maine is offline
PostPosted: Tue Jul 21, 2020 10:58 am    Post subject: Re: Rocky Mountain Westy Bumpers Reply with quote
Thinking about buying a set of RMW Twin Peaks bumpers, to anyone who has them do they still get high marks?
HeinleinTrooper
HeinleinTrooper is offline
PostPosted: Tue Jul 21, 2020 12:53 pm    Post subject: Re: Rocky Mountain Westy Bumpers Reply with quote
I like mine. I have not installed anything on them yet, though.
1990 Vanagon Multivan 2.1 WBX AT
Page 2 of 3
