Olli from NJ Samba Member
Posted: Sun Mar 11, 2018 4:21 am Post subject: rain tray |
I just installed a new rain tray on my new to me '71 and couldn't help but wonder if it would impair airflow. Does it? I would think that the VW engineers would not design a part that would negatively effect cooling.
Olli |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32987 Location: Reading Pennsylvania
Era Vulgaris Samba Member
Joined: August 22, 2012 Posts: 1913 Location: Raleigh, NC
Posted: Sun Mar 11, 2018 2:46 pm Post subject: Re: rain tray |
I highly doubt the late plastic style would impede the airflow requirement for a stock engine.
Although a different car and engine, but also air-cooled...I did an experiment on one of the 914's I used to own. I had a 4 channel digital head temp gauge that monitored all 4 head temps in real time, as well as an analog style oil temp gauge. I spent several week running with and without the rain tray, and there was zero impact on head or oil temps.
The 914 rain tray is a similar, albeit much larger, plastic design as the late Ghia rain trays. I would imagine the results for a similar test on a late Ghia would be the same.
Now the early metal rain tray that was part of the decklid...that one probably does impede airflow somewhat, and it's probably why the design was changed as displacement increased on the later cars. _________________ Currently own:
66 Karmann Ghia, L390 Gulf Blue, under construction, here: www.thesamba.com/vw/forum/viewtopic.php?t=760505&highlight=
99 Mazda MX-5 10AE, Sapphire Blue Mica, 6 speed, LSD
Previously owned:
98 Porsche Boxster, silver, 2.5L -- 67 Karmann Ghia, Black, 1500sp -- 98 BMW Z3, Atlanta Blue Metallic, 2.8L I6 -- 75 Porsche 914, Laguna Blue, 2270cc -- 72 Porsche 914, Signal Orange, 1.7 FI -- 74 Karmann Ghia, Black, 1600dp -- 74 Triumph TR6 with O.D., sapphire blue |
bnam Samba Member
Joined: July 02, 2006 Posts: 3457 Location: El Dorado Hills CA/ Bangalore, India
Posted: Sun Mar 11, 2018 6:21 pm Post subject: Re: rain tray |
What should one do to the deck lid when putting a 1600 in a 65 or older KG?
Byas _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
1952 Citroen TA 11BL |
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 4111 Location: In Molinya Orbit
John Moxon  Samba Moderator
Joined: March 07, 2004 Posts: 14193 Location: Southampton U.K.
Posted: Mon Mar 12, 2018 5:24 pm Post subject: Re: rain tray |
Just to add....I wasn't implying that the early design was inadequate for the engines VW was supplying. Just that VW saw a way to improve the design, so they did. Porsche did a similar thing on the 356, going to a dual vent grill on the late T6 bodies.
A 1600 is only 0.1 liters larger than the 1500 that ran with the early deck lid from 67-69. That would be totally fine with the early lid. Now if you had, say, a 2332 under there then you might want to think about increasing the ventilation. _________________ Currently own:
Previously owned:
Posted: Mon Mar 12, 2018 6:40 pm Post subject: Re: rain tray |
I actually am having CB build a 2332 for my '71. Heads will NOT be wild, with reduced fins. They will be Panchitos. Cooling will be dog house, with all the tin, including the sled tins. A venturi ring will be added to the fan inlet. Full flow case, external filter with an external cooler(with fan), 4 qt extra sump.
I just couldn't help myself for asking the question when I installed the rain tray, am I restricting the air flow? Somehow, I don't think so. The VW engineers wouldn't design a part that would be detrimental to cooling IMHO. The more I looked at the tray, the more I could see that there was a great deal of opening through and around the tray. What I might do just for fun is a very unscientific visual smoke test and just watch how the smoke gets drawn in. With vs without the tray. At the present time, the engine is a '71 1600. But that wouldn't change the amount of air that the fan draws.
Olli |
Volswagon Samba Member
Joined: December 29, 2009 Posts: 303 Location: Knoxville, TN
Posted: Mon Mar 12, 2018 10:39 pm Post subject: Re: rain tray |
My thought is when you restrict the flow, you get more vacuum thus cooling the incoming air more. I have often wished for a leaf catcher on my Ghia because it gets old reaching in there to get leaves out of the fan. They can sound pretty strange in there.
I used to stand-off the hood on the Beetle in summer but found the extra drag to be a...drag in winter. _________________ I know the pieces fit, cos I watched them fall away.
Wanna hear God laugh? Just talk about your plans.
'75 Bus https://www.thesamba.com/vw/forum/viewtopic.php?t=697183&highlight= |
swavananda Samba Member
Joined: February 14, 2009 Posts: 889 Location: Can o' Scruz
Posted: Wed Mar 14, 2018 1:18 am Post subject: Re: rain tray |
I remember hearing about a simple vacuum test to determine this. Idea is to run a length of vinyl tubing from inside engine bay to inside the car and have the end of the tube sit in a container of water. . Take the car out for a run and do a third gear red line . If the motor is sucking in more air than available, water will get drawn in due to the vacuum affect being created. |
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 4141 Location: Georgia
Posted: Sun Mar 08, 2020 10:07 am Post subject: Re: rain tray |
Even though I never intend to drive it in the rain, I’m contemplating installing one in my ‘70.
I removed the old one many years ago because of a Weber Progressive. No telling what I did with it so I’ll have to get a repop.
Anyone know if they fit with dual carbs? _________________ Volkswagen!
(Compression 8.7:1) |
myghiarocks Samba Member
Joined: June 02, 2009 Posts: 144 Location: DFW area Texas
Posted: Sun Mar 08, 2020 10:54 am Post subject: Re: rain tray |
Yes, mine fits fine with dual carbs, is there any in classifieds? |
Posted: Sun Mar 08, 2020 10:58 am Post subject: Re: rain tray |
Good to know, thanks
Only a few broken ones in the classifieds. _________________ Volkswagen!
