Okie Adam Samba Member
Joined: November 07, 2003 Posts: 1151 Location: OOOOOOOOOOOOOOOOOklahoma
Posted: Mon Dec 11, 2017 8:16 am Post subject: Re: Adam's 1955 Wolfsburg Semaphore Kombi Build |
I'll have to check them out, thanks! _________________ Oil Capital Air Cooled
55 Wolfsburg Kombi
60 Walkthrough Kombi
62 Single Cab
66 21window
67 so42
76 Westy
64 Karmann Ghia |
tyzel Samba Member
Mr. OGPaint Samba Member
Joined: September 24, 2010 Posts: 704 Location: Oregon
Posted: Mon Dec 11, 2017 1:29 pm Post subject: Re: Adam's 1955 Wolfsburg Semaphore Kombi Build |
That sounds like them but that stock photo is way off! _________________ Oil Capital Air Cooled
55 Wolfsburg Kombi
62 Single Cab
66 21window
67 so42
76 Westy
64 Karmann Ghia |
Posted: Tue Feb 20, 2018 12:55 pm Post subject: Re: Adam's 1955 Wolfsburg Semaphore Kombi Build |
Well it's been a while since I've updated and I have no good excuse for that but I've got some progress to report.
I cleaned everything out of the bus in preparation for dragging it out to work where I can get it indoors to work on it. The bus has been a storage for parts I've collected over the years for this project. I reduced it down to only the parts I'm going to be welding in or parts I need to bolt on to line stuff up.
Unfortunately the original 6 leg floor is pretty wavy.
Before the corner went in I had to do a little filling where I'd gotten a little aggressive removing what was left of the old corner. I clamped a piece of aluminum angle back there to prevent blow through.
The first tac of many!
I was able to get the rear corner welded in. I still need to put the battery tray in and replace the lower corner but it was a huge step to get this done. I've looked at this bus for years with the corner hacked out.
With a little time to spare Sunday evening I decided to get one of the front signal holes filled in. I think I've mentioned that this bus has had a nose job at some point in its life. Needless to say, those bullets have to go when you have original semaphore posts.
55 Wolfsburg Kombi
62 Single Cab
66 21window
67 so42
76 Westy
64 Karmann Ghia |
Travis Woodard Samba Member
Posted: Tue Feb 20, 2018 1:23 pm Post subject: Re: Adam's 1955 Wolfsburg Semaphore Kombi Build |
The patina on that bus is great. And that corner made it look so different. _________________ 55 Double door panel
56 PGSG OG paint Wilson Avenue church bus
57 deluxe 23 window OG paint
59 mango
69 bay deluxe bay
66 beetle |
62DoKaGuy  Samba Member
Joined: May 22, 2011 Posts: 1153 Location: Sacramento/Phoenix
Posted: Tue Feb 20, 2018 1:55 pm Post subject: Re: Adam's 1955 Wolfsburg Semaphore Kombi Build |
Okie Adam wrote: |
Don't know about anyone else, but I love these "peek-a-boo" pictures, when a project is moving forward (literally) from one phase to the next. Love the discoloration too! Keep it going! _________________ Wenige Menschen denken, und doch wollen alle entscheiden.
EverettB wrote: |
...I went at it from both ends but going from the rear didn't seem to do anything, although I did spray some rust breaker in there... |
4/62 Double Cab
4/59 Single Cab |
LAGrunthaner Samba Member
Joined: March 18, 2007 Posts: 4786 Location: 1st Coast
Posted: Tue Feb 20, 2018 3:50 pm Post subject: Re: Adam's 1955 Wolfsburg Semaphore Kombi Build |
OMG yes my favorite shot too! Keep up the good work.
62DoKaGuy wrote: |
Okie Adam wrote: |
Don't know about anyone else, but I love these "peek-a-boo" pictures, when a project is moving forward (literally) from one phase to the next. Love the discoloration too! Keep it going! |
_________________ American Red Cross Safe And Well link:
https://safeandwell.communityos.org/cms/index.php?...OSmeUzh8l4
Maui Roadsters
www.mauiroadsters.com
Lind wrote: |
Posted: Tue Feb 20, 2018 3:56 pm Post subject: Re: Adam's 1955 Wolfsburg Semaphore Kombi Build |
I’m excited to just see that bus has moved. Adam is making some tracks now. _________________ 55 Double door panel
59 mango
69 bay deluxe bay
66 beetle |
mandraks Samba Member
Joined: November 28, 2004 Posts: 5903 Location: Lawrenceville, Ga
Posted: Tue Feb 20, 2018 8:05 pm Post subject: Re: Adam's 1955 Wolfsburg Semaphore Kombi Build |
completely on board with the blinker delete. Semaphores rule.
From the back it won't make a difference and up front you can see what is going on, even if the people can not _________________ regards
Uli
Posted: Wed Feb 21, 2018 10:14 am Post subject: Re: Adam's 1955 Wolfsburg Semaphore Kombi Build |
Thanks for the encouragement, everyone! _________________ Oil Capital Air Cooled
55 Wolfsburg Kombi
62 Single Cab
66 21window
67 so42
76 Westy
64 Karmann Ghia |
Posted: Tue Mar 13, 2018 12:23 pm Post subject: Re: Adam's 1955 Wolfsburg Semaphore Kombi Build |
Well, once again some time has passed but I have some work to show for it. I sent some time working on the dash this weekend.
This is where I was starting from. It was real close from when I fit it years ago but definitely lacking final fit.
I went ahead and got the steering column and heater tube out of the way.
And this is what I ended up with after some grinding and cleaning and I'm real happy with it!
I still need to clean up the back side of the nose where i filled in the bullet turn signal holes and speaking of bullet holes, the donor dash came from a bus that had been used for target practice. Luckily the dash survived well enough but the parcel tray/dash support and heater Y-pipe didn't come out as clean. I heated the metal a bit and folded back what I could and I will weld them up from there.
I lifted the bus up when I needed a little brake and did some inspecting and I was really happy to see the lower shock bolts still had their lock tabs in place. It's the little things!
55 Wolfsburg Kombi
62 Single Cab
66 21window
67 so42
76 Westy
64 Karmann Ghia |
EmpiGT Samba Member
Posted: Tue Mar 13, 2018 6:17 pm Post subject: Re: Adam's 1955 Wolfsburg Semaphore Kombi Build |
I know the guy that used the bus the dash came from for target practice, if you want to return the favor to him..
Looking good! |
sgellis Samba Member
Joined: July 06, 2016 Posts: 1591 Location: SW Nova Scotia, Canada
Posted: Wed Mar 14, 2018 4:18 am Post subject: Re: Adam's 1955 Wolfsburg Semaphore Kombi Build |
I had not even considered that! There is a gap on each end but I assumed it was where I had maybe ground too much away and would have to fill it. I will measure my other buses that aren't cut apart and match the 55 to them. Thanks for the tip! _________________ Oil Capital Air Cooled
55 Wolfsburg Kombi
62 Single Cab
66 21window
67 so42
76 Westy
64 Karmann Ghia |
BATComm1 Samba Member
Joined: April 28, 2011 Posts: 152 Location: Broken Arrow,Ok.
Posted: Sun Mar 18, 2018 2:46 pm Post subject: Re: Adam's 1955 Wolfsburg Semaphore Kombi Build |
I'm watchin..... _________________ I support gay marriage...as long as both chicks are really HOT !!
1965 Beetle, 1966 13 window deluxe walk thru |
Posted: Mon Jul 02, 2018 1:23 pm Post subject: Re: Adam's 1955 Wolfsburg Semaphore Kombi Build |
So, I'm not great with these updates so here's some recent progress.
Before getting the dash in there was some patching that was necessary in the A pillars.
Both sides got the same treatment. It was mentioned that the nose might flex without the dash and parcel tray support in there so I measured a couple of my other buses and it looked as if it held its dimension. The dash was a little gaped at the pillar though so I did a little weld line to help bridge the gap at install.
I got the unnecessary holes filled in the dash too.
While fitting the dash and heater pipe and parcel tray support I ran into an unexpected obstacle. Things just were't fitting. Again, luckily I had other buses to measure and I found that the heater pipe had been installed almost an inch to high above the floor when the bus had a nose job. I later confirmed this when I found a donor heater pipe in my collection and could see that the one that came out had been shortened. So out it came! Probably for the better as I would soon find.
While I was down there, I decided to remove all four bumper bolts that were broken off in the frame.
My good friend Dewayne wanted to work on the dents in the buses nose a bit so I halted work on the dash install until we could schedule a time to get together on it. In the mean time I looked for other projects and decided to get on removing the decklid carrier that had been hacked. I had a donor that still needs some serious fitting and cleaning up but luckily it still had the backing piece on it which had been hacked on my bus also.
A couple weeks later Dewayne and I got together with a stud gun and a foot ball and made some serious progress on a nose that at first I had thought wasn't too bad LOL Some other friends joined in on the fun that day too.
Much much more to do to this old bus but I am making progress despite my lack of updates. _________________ Oil Capital Air Cooled
55 Wolfsburg Kombi
62 Single Cab
66 21window
67 so42
76 Westy
64 Karmann Ghia |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 22579 Location: Olympia Wash Rinse & Repeat
Posted: Mon Jul 02, 2018 2:51 pm Post subject: Re: Adam's 1955 Wolfsburg Semaphore Kombi Build |
Hopefully you have got those axle boots now turned properly. _________________ In Stereo, Where Available! |
Posted: Tue Jul 03, 2018 4:21 am Post subject: Re: Adam's 1955 Wolfsburg Semaphore Kombi Build |
Eric&Barb wrote: |
Hopefully you have got those axle boots now turned properly. |
That's the least of my worries right now!  _________________ Oil Capital Air Cooled
55 Wolfsburg Kombi
62 Single Cab
66 21window
67 so42
76 Westy
64 Karmann Ghia |
Posted: Tue Aug 07, 2018 8:12 am Post subject: Re: Adam's 1955 Wolfsburg Semaphore Kombi Build |
Got the chance to spend some time on the 55 recently. My good friend Dewayne offered to come help again. I think he is getting in some good old VW therapy while he waits to get started on the mole. His patience is something I long to learn. I really enjoy watching him pull the nose of the bus. The subtle tugs and use of the shrinking disc to get rid of tin canning is captivating for a BFH guy like me.
I think we were both surprised how good it looked once we shot primer on it. You'd expect it to look worse with a consistent color on it but I'm pretty pleased.
While he is working on the nose we decided to leave the dash out so I was back to working on the rear corner. The donor needs a little straightening but I got it cut down and started fitting it along with the OG battery tray. Nothing fits like OG metal even if it is a little worse for the wear I removed the pillar section from the skin and I plan to use it to repair the lower corner but decided it would produce a better outcome doing them as separate jobs.
Also go the decklid carrier trimmed and fit better before having to call it a day.
55 Wolfsburg Kombi
62 Single Cab
66 21window
67 so42
76 Westy
64 Karmann Ghia |
