WAoval Samba Member
Joined: March 13, 2018 Posts: 8 Location: Western Australia
Posted: Tue Mar 13, 2018 7:02 pm Post subject: Help with 56 Trans number |
Hey guys, I'm trying to date my transmission to check if it's original for the car. 56 Oval.
No letters on there just numbers.
1277935
VW number is 113 301 103
C
so It's def a bug. It's swing axle. I've checked the list on the samba but they all suggest there should be an A in front of the numbers. There's nothing.
Also (this is the first oval I've done) The bolt pattern on the rear drums is not wide five but a four bolt. So this is confusing me as I thought all ovals were wide five bolt patterns?
Any help appreciated |
EverettB Administrator
Joined: April 11, 2000 Posts: 69829 Location: Phoenix Metro
WAoval Samba Member
Posted: Wed Mar 14, 2018 2:08 am Post subject: Re: Help with 56 Trans number |
Hey, thanks for the response. No It doesn't have a split case. another reason why I'm unsure of the model?
WAoval Samba Member
Posted: Wed Mar 14, 2018 4:22 am Post subject: Re: Help with 56 Trans number |
From everything I can find and the fact that it's a four bolt pattern, makes me think it's a 61 - 68.
But I can't make the number match up. I was hoping it was the original box but it's not making much sense. |
wimkever Samba Member
Joined: July 16, 2004 Posts: 412 Location: Holland (the Netherlands)
Posted: Wed Mar 14, 2018 5:42 am Post subject: Re: Help with 56 Trans number |
WAoval wrote: |
A four bolt pattern was introduced at the '67 model.
So I wonder what makes you think it's a 61 - 68. _________________ a beetle is like a cocker spaniel, always funny but sometimes not listening |
WAoval Samba Member
Posted: Wed Mar 14, 2018 6:24 am Post subject: Re: Help with 56 Trans number |
As I pointed out
'Also (this is the first oval I've done) The bolt pattern on the rear drums is not wide five but a four bolt. So this is confusing me as I thought all ovals were wide five bolt patterns?'
So I have no idea when the four bolt pattern came in. But thanks for the 'help'
As I also pointed out my first thoughts in looking at the number was that it was a 56/57 ID. This car is totally bare rolling shell - has had a ball joint beam hacked in and has no engine. So I'm trying to figure out what I have - to make the decision on what to ditch and what to keep.
So based on my limited knowledge and the question from @EverettB are all 56/57 original boxes split cases? In which case it's easy to rule it out as being the original box anyway. |
Mark Evans Samba Member
Joined: April 21, 2004 Posts: 1931 Location: Alsea,Oregon
Posted: Wed Mar 14, 2018 7:12 am Post subject: Re: Help with 56 Trans number |
With also having a ball joint front end, is it on a later pan? The rear seat belt receivers look to be later style... _________________ '63 Ragtop |
WAoval Samba Member
Posted: Wed Mar 14, 2018 7:28 am Post subject: Re: Help with 56 Trans number |
no pan is matching numbers and all signs are its original. Frame head has been hacked at to fit ball joint beam ( they cut the bottom mounts off).
But happy to hear if there's any other way of identifying the pan year
And transaxle |
Posted: Wed Mar 14, 2018 9:17 am Post subject: Re: Help with 56 Trans number |
WAoval wrote: |
Yes, the tunnel-case (later) transmission didn't exist in 1957 _________________ How to Post Photos
OvalinAz Samba Mini Tech
Posted: Wed Mar 14, 2018 9:20 am Post subject: Re: Help with 56 Trans number |
WAoval wrote: |
And transaxle |
whats the pan number? that will ID the pan for you. trans definitely isnt original _________________ Dad's 4/55 Oval
8/56 Oval
5/64 French Notchback
12/62 French 11 Window Bus
Wedge VW
Pandraggers C.C. |
Riff Raff Shivering Sambian
Joined: October 25, 2004 Posts: 3097 Location: Alberta
Posted: Wed Mar 14, 2018 12:08 pm Post subject: Re: Help with 56 Trans number |
As has been mentioned, the trans is definitely not original to an oval window Beetle.
That trans looks like it has been with that pan a long time though.
The VIN on the pan matches the VIN on the body?
If the frame head has been hacked to install a ball joint beam, that is pretty strong consideration for trashing that pan.
Dependent, of course, on how important it is to you to have matching numbers. _________________ The greatest obstacle to discovery is not ignorance, but the illusion of knowledge
- Daniel Boorstin |
Posted: Wed Mar 14, 2018 12:39 pm Post subject: Re: Help with 56 Trans number |
I would not trash a matching numbers pan, I would repair it correctly. _________________ '63 Ragtop |
WAoval Samba Member
Posted: Wed Mar 14, 2018 9:00 pm Post subject: Re: Help with 56 Trans number |
The body is pretty good apart from a few hacks that I can fix - but it's really solid. As is the pan - apart from the O/S rear section it's mostly just surface rust and compared to others I've seen on here it's like new
The vin numbers all match on the plates so I don't want to lose that.
So the only thing I need to figure out now is do I keep it to the later swing axle/upgrade or go stock and do I replace the frame head back to OG and source an early Beam or fit a later ball joint Frame head and use what I have.
Thanks for the all the info - been really helpful |
