58Sleeper Samba Member
Posted: Wed Mar 14, 2018 9:03 am Post subject: Engine removal |
I am trying to remove the top two bolts on my engine, but as they are loosened, it seems the bolts keep winding. Does that mean the screw stem is not properly mounted into the case of the transmission?
Has anyone dealt with this problem before and how to remove the engine in this case? |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Wed Mar 14, 2018 9:09 am Post subject: Re: Engine removal |
They are a nut and bolt depending on which engine you have in there so you need to put a wrench on the other side to hold it.
There is a tool to make it easier
_________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Zundfolge1432 Samba Member
Posted: Wed Mar 14, 2018 9:33 am Post subject: Re: Engine removal |
I saw a guy use vise grips once |
Sharp64 Samba Member
Joined: August 27, 2015 Posts: 5304 Location: Central Florida
Posted: Wed Mar 14, 2018 9:44 am Post subject: Re: Engine removal |
Or wedge a 15 box end wrench on the tranny side. When you get it out put a D bolt in its place. _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
1985 Westy Money Pit
“...some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn.” - Michael Caine |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31362 Location: Hot Arizona
Posted: Wed Mar 14, 2018 9:52 am Post subject: Re: Engine removal |
Get a helper or the fancy tool or use a Vise-grips or box wrench to keep the one side from turning.
Once 1971 year engines arrived, those had a threaded boss on the upper left and a bolt from the front side. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Wed Mar 14, 2018 9:59 am Post subject: Re: Engine removal |
What is this tool called? I have a 36hp in a 59 beetle.
Everything seems to be original besides all the rust and fuel pump..
60ragtop wrote: |
Posted: Wed Mar 14, 2018 10:00 am Post subject: Re: Engine removal |
Duh, it is written right on the too. I found it.
-M
58Sleeper wrote: |
60ragtop wrote: |
Posted: Wed Mar 14, 2018 10:23 am Post subject: Re: Engine removal |
Sharp64 wrote: |
Or wedge a 15 box end wrench on the tranny side. |
Real VW mechanics make sure it is a 17 mm head in there
Here's one place that sell the 17mm tool
https://www.handsontools.com/SIR-Tools-P222-Magnetic-Box-V-Wrench-17mm-for-Porsche_p_19097.html
Drill a hole in it and put a small chain that dangles down so you don't leave it on ther car. I've found and lost a lot of this tool over the years _________________ Rick
tasb wrote: |
sb001 wrote: |
Posted: Wed Mar 14, 2018 11:38 am Post subject: Re: Engine removal |
Ma' Man! Thank you for the link. The prices I was finding was over $60.00.
-58Sleeper
Posted: Wed Mar 14, 2018 12:08 pm Post subject: Re: Engine removal |
That’ll teach me to go off memory. Lol. _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
6T5 square Samba Member
Joined: September 15, 2005 Posts: 1083 Location: Dover, DE
Posted: Wed Mar 14, 2018 12:11 pm Post subject: Re: Engine removal |
I know this is going to seem ghetto but it has been working for me for years
I took a 1 1/2" piece of a sturdy wire coat hanger. Cleaned it off real good and then welded it across the top of the bolt. When the bolt spins, the wire hits the side of the trans housing and it wont turn. This allows me to tighten the nut without having to go under the car.
like I said- ghetto but you cant beat the price _________________ John
65 square 1500S (weezer) sold but always on my mind
60 beetle (Ned)
Quoting John Muir -- Open the rear boot. Get out the stool and sit down. Contemplate the air-cooled beauty before you. - How to Keep Your Volkswagen Alive -- Step-By-Step Procedures for the Compleat Idiot |
Posted: Wed Mar 14, 2018 12:27 pm Post subject: Re: Engine removal |
My choice method is once off, clean up the threads, oil and use dum-dum putty aka strip putty on the trans side to hold the bolt in, works like a charm. _________________ Rick
tasb wrote: |
sb001 wrote: |
