craigw125 Samba Member
Posted: Thu Mar 15, 2018 12:12 pm Post subject: Possible baja project |
I am kinda new to vw was looking into a beetle for a baja build and came across this roller shell for $300. Has rust on rear passenger floor but the rest of the body looks good and it has all the interior parts. I was just wondering if it was worth 300 or if I should run away from it. Also alot of the others Ive seen are way more and are in worse condition.
-Thanks,
Craig |
Bock Samba Member
Joined: September 18, 2004 Posts: 158 Location: Tennessee
Posted: Thu Mar 15, 2018 2:38 pm Post subject: Re: Possible baja project |
300.00 is a steal for any car that is not wrecked and able to get a title.
The question is more of what is your budget and Baja bug expectations. 9 out of 10 times you will be further ahead buying a car with work already done to it. |
Vanillagurilla Samba Member
Joined: November 21, 2017 Posts: 1061 Location: California
Posted: Thu Mar 15, 2018 3:15 pm Post subject: Re: Possible baja project |
For $300 I'd buy it, transfer the title, clean it up and sell it lol |
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4407 Location: Stuck in Ohio
Posted: Thu Mar 15, 2018 4:35 pm Post subject: Re: Possible baja project |
By roller I'm reading as no motor or trans. It's a good bet that you'll be able to unload it for your 300 if you want to. It's also a good bet that you'll have a bunch of money to put into it if you are buying parts for it one piece at a time. You might look for a rusted out wreck of a donor vehicle with a running drivetrain to strip for the things you'll need for this one.
Make sure it has a title that matches the numbers on the body and the pan. Title work can be an expensive and a nightmarish way to appreciate the unfairness and ineptitude of bureaucracy. Not always successful either. It usually involves inspections.
If it had a clean title, I would not be able to resist the temptation and would drag it home on a lark.
However, if you have a couple grand put together and are set on a baja, a work in progress or abandoned project often has a bigger bang for the buck.
Either way, for 300 bucks it would be giving my neighbors another reason to call city hall. Speaking of cities... where did you say this bug was? Lmao, jk. Good luck!!!
Edit: from your other threads I see you have a pinto engine from your uncle's sandrail or whatever so a roller is what you are looking for. If it is as you describe, and has a title, you won't beat this one for 300. Start a build thread so we can follow along. _________________ 1966 Sportsmobile Camper https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
72 Super Duper http://www.thesamba.com/vw/forum/viewtopic.php?t=672387
(adopted out) 61 Turkis Pile https://www.thesamba.com/vw/forum/viewtopic.php?t=728764
SnowDaySyncro wrote: |
Every setback is an opportunity to learn stuff and to buy new tools. |
