Major Woody Samba Enigma
Joined: December 04, 2002 Posts: 9010 Location: Portland, OR
Posted: Wed Jun 10, 2009 10:32 am Post subject: |
Looked that way to me. |
Jung Restoration Samba Member
Posted: Thu Jul 30, 2009 7:58 am Post subject: Re: Westy faucet |
Major Woody wrote: |
Please forgive the stupid question. My 67 SO-42 was missing its faucet but I got two old ones in a bag with the bus. Which one of these is the correct faucet for the bus?
Thanks! |
Top picture -whale pump- is in my '66 and the chrome one is in a '67 I'm parting out. Problem is the wale pump spout is broken, but the other one is is great shape. I was thinking I could just swap the pumps but the tank filler holes are different in the table top. I would have to swap the pumps, table top, and water container? Does any place just sell the spout for the whale pump? _________________ Wanted : January '57 Palm Green Sand Green Bus Parts - Middle and Rear Seat Frames - flat back. I have original seat covers but would consider covered frames.
Jung Restoration - Jung is my last name and restoration is what I do for work. I restore antique windows and doors here in the Northeast. Check out my site www.antiquewindowrestoration.com |
JDGas Samba Member
Joined: June 23, 2004 Posts: 1233 Location: Escondido
Posted: Mon Oct 05, 2009 2:56 am Post subject: |
I just picked up a '67 so42 on saturday. My faucet looks like the chrome one but has a 3 hole mounting base instead of the 2 hole pictured. Anyone know the origin of this pump? I guess I will be ordering the pump and check valve from RVshop.com.
Only pictures I got, but you get the idea.
_________________ 1959 Ragtop Beetle - sold
1958 Danish Beetle
1967 SO-42 West. - sold
1961 Sunroof Beetle - sold
1969 Sunroof Beetle |
curtis4085 Samba Member
Posted: Fri May 01, 2015 1:58 pm Post subject: |
Need a little help please. I have a 66 Westy and I have what appears to be a Whale pump on it? I know nice seen this pump style before. It has the two hole pattern. What throws me is the sticker on the plastic portion that says made in Taiwan. Can anybody verify if its a whale? If so, I'm in desperate need of finding the barbed hose connection the screws into bottom of pump 3 picture down. I called North America Whale and the guy who knows anything is not in for a few. Any help is greatly appreciated. This fitting if whale is metric and I I can find is copper standard connections.
The part I need. My current is broken as you can see
I believe its 9mm female by ? 9,maybe8 or 3/8" barbed end. _________________ Special Thanks to:
Headflow Masters - Vista, CA
www.headflowmasters.com |
g3bill Samba Member
Joined: March 30, 2015 Posts: 247 Location: So. Cal usa
Posted: Fri May 01, 2015 3:49 pm Post subject: |
My '67 had the lower chrome one when i bought the camper in '82, doubt po changed it. Old one wouldn't pump well so replaced it with a new one. _________________ I have Dial-Up an a hole in my pocket:)......Where are the 3 Stooges when we need them:)
'67 Camper PT westfail w/tent, hammock, jump seat. uping the motor to 1900 w/88bore/78crank.
& will be using carb 34 pict 3 ....Someday?
'82 Toyota 4x4 5sp PU lb, daily driver
Many Corvairs /& 4 rag tops
'63 Chevy 20 Truck w/4sp 292
Want, white plastic end pieces for dash grab handle |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14258 Location: Casa de Oro, California
Posted: Sat May 02, 2015 9:06 am Post subject: |
Whale stuff usually says Whale on it somewhere. I work in the marine world and have always been able to find most stuff here http://www.westmarine.com/search?text=pipe+to+barb.
I don't recollect finding much metric threaded stuff. 3/8 pipe feels like it's metric as it is relatively uncommon. Most barb sizes end up being much larger on the actual barb. For example 1/2 barb is 5/8 hose unless you like fighting a 1/2 inch hose over it.
Peruse West' stuff and see what you might find. |
velvetgreen Samba Member
Posted: Sat May 02, 2015 9:45 am Post subject: |
All the early North American SO 42's I have seen came with Whale pumps (Made in Ireland of all places)
No idea how an Irish pump became standard issue on early north amercian so42's. As far as replacement parts I would head to a marine supply shop that offers accessories etc for yachts/ sailboats and that sort of thing. West marine is probably a good place to try too |
BarryL Samba Member
Posted: Sat May 02, 2015 9:49 am Post subject: |
velvetgreen wrote: |
All the early North American SO 42's I have seen came with Whale pumps... |
Right but post up a picture of one; they are different looking from his aren't they? |
this is what the original whale pump looked like
Posted: Sat May 02, 2015 12:16 pm Post subject: |
your pump looks like a knock off of an early bay pump- although I thin kback in the day they were sourced from us manufacturers not made it Taiwan
that one on the amazon site looks like it has an octangonal base as compared to yours which looks circular? |
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Wed Mar 14, 2018 8:14 pm Post subject: Re: Westy faucet |
I'm going to take a stab at getting this Whale pump working and back in my SO44.
I thought y'all might like to see the different parts
In mine the brown base was broken so I made a form and used some JB Weld to rebuild the ears on it. I'm contemplating also making a metal collar that distributes the clamping pressure around the entire base. |
Posted: Wed Mar 14, 2018 8:32 pm Post subject: Re: Westy faucet |
^^looking fwd to progress pics! i have one that is in pieces too. not to rain on your parade but the cutout for the other style of pump is wider so if you might want to try a test fit on your cabinet before going to the bother of the rebuild- you can probably guess how i know |
Posted: Wed Mar 14, 2018 8:37 pm Post subject: Re: Westy faucet |
The SO44 has a sink (unlike the SO42) and the empty original hole with the four screw holes is right next to it. |
BarryL Samba Member
Posted: Thu Mar 15, 2018 3:14 pm Post subject: Re: Westy faucet |
missed the SO44 part- i have an SO42
Anyway look fwd to seeing progress! |
Posted: Thu Mar 15, 2018 5:51 pm Post subject: Re: Westy faucet |
Thanks Barry, I'll have a look. |
