ARTDECODON Samba Member
Posted: Fri Mar 16, 2018 6:41 pm Post subject: Transmission ID help please |
I pick up what I think is a barn door early trans with reduction gears. It is complete gland nut to gland nut. Can someone help me ID for year??
EmpiGT Samba Member
Posted: Fri Mar 16, 2018 7:25 pm Post subject: Re: Transmission ID help please |
That is not a barndoor trans. that is a big nut splitty trans. I'm sure someone can narrow down the year by the numbers, but it will be somewhere between 64-67 |
Posted: Fri Mar 16, 2018 7:46 pm Post subject: Re: Transmission ID help please |
What vehicle does a big nut splitty trans go to. Hell....never even heard of that. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69830 Location: Phoenix Metro
Posted: Fri Mar 16, 2018 9:38 pm Post subject: Re: Transmission ID help please |
Big Nut is named for the larger 46mm nut on the brakes.
Big nut transmissions are 1964-67
Your transmission also has the circle on there for the rear rubber bumpers, I believe this is mid-1965-67 but someone can correct me if that is wrong.
With rubber
_________________ How to Post Photos
Clara Samba Member
Posted: Sat Mar 17, 2018 8:02 am Post subject: Re: Transmission ID help please |
It came new in a mid 65-mid 67 split bus. (I don't see a reverse light switch which would make it later 67)
Splitty= split bus = 67 & earlier VW bus
It can easily be bolted into a mid 59 through 67 bus.
To fit it in an earlier bus takes some nose cone mount mods.
There are some trannies in the classifieds now for $150:
https://www.thesamba.com/vw/classifieds/search.php...ds_time=90
It may be worth more if you are in Alberta, evidently. |
Posted: Sat Mar 17, 2018 8:21 am Post subject: Re: Transmission ID help please |
Thanks so much. |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14271 Location: Casa de Oro, California
Posted: Sat Mar 17, 2018 10:25 am Post subject: Re: Transmission ID help please |
Does it have an "H" in front of the serial numbers? Below the input shaft inside the bellhousing are some tiny circles like this.
Can you do a photo of those close up? |
easy e Samba Member
Joined: May 28, 2008 Posts: 3931 Location: 1 hr north of Santa Barbara
BarryL Samba Member
Posted: Sat Mar 17, 2018 11:14 am Post subject: Re: Transmission ID help please |
easy e wrote: |
What are in those circles again? |
Cast on. They are upside down.
First circle: day of month.
Second circle: month.
Third circle first character: shift.
Third circle last character: year.
If his is a bus H serial number I'm going to guess late '65 early '66 ish. |
Posted: Sat Mar 17, 2018 1:16 pm Post subject: Re: Transmission ID help please |
Hi...There is no Alpha code in front of the numerical numbers. I could not find any marking like described in the previous post. Only what I took the picture of...hopefully you can see what is stamped. This is what I think it says:
1
5s30
These look to be hand stamped.
BarryL Samba Member
Posted: Sat Mar 17, 2018 6:42 pm Post subject: Re: Transmission ID help please |
Look inside the opposite end of the big middle part below where the shaft with the splines on it goes inside. You're at the other end. |
Posted: Sat Mar 17, 2018 7:17 pm Post subject: Re: Transmission ID help please |
Are you telling me to remove the nose cone? Could you send a pic that shows more of the tranny so I can get a reference point? |
Posted: Sun Mar 18, 2018 4:36 am Post subject: Re: Transmission ID help please |
OK....I found the data. 24 9 15 |
RWK Samba Member
Posted: Sun Mar 18, 2018 6:44 am Post subject: Re: Transmission ID help please |
I have an H 0xxx I took it out of a 67 years ago, it was the original,
have a 5 something in my 62 _________________ 73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530 |
Posted: Sun Mar 18, 2018 6:47 am Post subject: Re: Transmission ID help please |
I wonder why this one does not have a Alpha code. Interesting. |
RWK Samba Member
Posted: Sun Mar 18, 2018 6:55 am Post subject: Re: Transmission ID help please |
like the engines, they were all numbers for a while then the letter prefix.
as above posted probably 65-66? I posted about this before doesn't seem to be a list anywhere. _________________ 73 Type 181
63 Type 113
Posted: Sun Mar 18, 2018 6:59 am Post subject: Re: Transmission ID help please |
It is dated to 1965...I guess they got lazy or ran out of numbers. Thanks for you input it really helped. |
BarryL Samba Member
Posted: Sun Mar 18, 2018 9:54 am Post subject: Re: Transmission ID help please |
ARTDECODON wrote: |
Your center section is from a Beetle that has had the ring gear flipped to become a bus with reduction boxes. The reduction boxes reverse the axle rotation so in essence the third motion differential turns backwards to make the wheel stub axle turn forward. In a Beetle the axles would be straight to the wheels and turn forward already. |
cru62 Samba Member
Joined: December 31, 2002 Posts: 4117 Location: Margaritaville.....24/7
Posted: Sun Mar 18, 2018 1:57 pm Post subject: Re: Transmission ID help please |
I was under the impression that all the Tunnel-case castings were 113 xxx xxx because the case itself was the same. It is possible (and done frequently) to flip the R & P in a bus trans when doing a SAK. _________________ "My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
BarryL Samba Member
Posted: Sun Mar 18, 2018 6:48 pm Post subject: Re: Transmission ID help please |
cru62 wrote: |
I was under the impression that all the Tunnel-case castings were 113 xxx xxx because the case itself was the same. |
Bus tunnel case would most likely have an H before the serial number. |
