128vw Samba Member
Joined: April 05, 2006 Posts: 222 Location: Western Massachusetts
Posted: Sat Mar 17, 2018 12:25 pm Post subject: master cyl push rod |
I am going to put a dual master cyl in my 65. What push rod do I use?
One for a 65 or one for a 66 -68? I am going to use a master from a 67. _________________ 56 Jungle green restored w/orig interior
65 Ruby red w/ 1600 single port
building 66vert on 69pan w/ 2332 |
turbotype1 Samba Member
Posted: Sat Mar 17, 2018 1:20 pm Post subject: Re: master cyl push rod |
The one you have... Just make sure you have free play once installed. _________________
117harv wrote: |
This new fad of get it the lowest, or run it with the worst looks, (patina) isn't cool, it's for the hey everyone look at me crowd, i'm driving a beat down ratty, unsafe, VW, how cool am I ???...your not....
Pissing off the purists since 1997
Wanted: Boyd Motors plate frame
57 Turbo Oval Sliding rag
67 13 window delux walk-thru- now 21
64 all original for the misses
83 Sinka m-TDI diesel |
KTPhil Samba Member
Posted: Sun Mar 18, 2018 9:27 am Post subject: Re: master cyl push rod |
Once you have chosen you pushrod, search for the correct SAFE procedure to adjust the pedal stop for longer throw, and then the pushrod length for proper freeplay.
If you don't, you won't get the benefit of the dual, and you may cook your brakes. |
