BigPile Samba Member
Joined: September 03, 2009 Posts: 34 Location: Lancaster, CA
Posted: Sat Mar 17, 2018 4:36 pm Post subject: I need a 1600/1641 engine for my manx clone |
Hiya, I live up in Lancaster, CA. The engine on my Manx-clone went to crap (flywheel loose, dowel pins ovaled, etc). I need a replacement engine, but am not sure what I should be looking for. Are there any good resources for a simple 1600/1641 that does not cost $3k+. I was hoping in the <$1500 range, but it seems my core isn't worth crap, so everything online is $3k+.
Is it possible to buy something or build something from scratch in the $1000 to $1500 range that will get me up and running again?
Also, is my current engine worth anything?
If there is anyone up in the Antelope Valley area, I would love to talk with you. Thanks! -Rob
mukluk Samba Member
Posted: Sat Mar 17, 2018 7:45 pm Post subject: Re: I need a 1600/1641 engine for my manx clone |
If the engine case is still useable, your cheapest route is likely to just rebuild what you have. I'd recommend reading some of the engine rebuild threads on this site to get a feel for things if you haven't already; the "grapes of wrath" rebuild thread is pretty good for showing what can be done on a low budget. _________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Sat Mar 17, 2018 9:12 pm Post subject: Re: I need a 1600/1641 engine for my manx clone |
From consulting a couple of "craigslist" rebuilders, my case is "crap", and I don't have anything worth rebuilding. |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8700 Location: Sunset, Louisiana
Posted: Sun Mar 18, 2018 7:32 am Post subject: Re: I need a 1600/1641 engine for my manx clone |
The pictures of the outside of your engine don't help much in determining the fitness of the components on the inside of the engine. Someone needs to take it apart and inspect the parts to see what is reusable.
Try to find a rebuilder near you. Go there and talk to someone. They may have a used case or even a used engine that could be a good start.
And just to add a bit of realism, It will be difficult to build a $1000 engine when a new case alone is about $800. _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15309 Location: Deep in the 405
Posted: Sun Mar 18, 2018 8:54 am Post subject: Re: I need a 1600/1641 engine for my manx clone |
Stay the hell of craigslist. Find somebody here on the Samba where you can search their feedback and opinions of their work.
Take your engine to a VW shop and have them evaluate your engine. $1500 can get your engine a good quality rebuild. $1000 rebuild is butcher shop prices. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Sun Mar 18, 2018 9:36 am Post subject: Re: I need a 1600/1641 engine for my manx clone |
All of your peripherals can be transferred over - Did a fast look. Mofoco sells a rebuilt long block for 1899...Seeing rebuilders in classifieds from 1200 and up..... _________________ D-Dubya Manx clone - 63 Short pan,1914.
weasel_ugs Samba Member
Joined: March 16, 2012 Posts: 721 Location: Prescott Valley,Az.
Posted: Sun Mar 18, 2018 2:42 pm Post subject: Re: I need a 1600/1641 engine for my manx clone |
If the engine still runs good you can drill new holes to keep it 4 dowell.
Someone on here probably knows where you can get the tool to do this. |
Wolfgangdieter Samba Member
Joined: June 25, 2008 Posts: 1958 Location: FL Panhandle
Posted: Sun Mar 18, 2018 3:54 pm Post subject: Re: I need a 1600/1641 engine for my manx clone |
As weasel said - the crank may be savable. If not a used/checked out crank is $100 and flywheel only an added $50. Engine needs to be taken apart to really determine extent of damage. Find a local VW club and consult with member there. _________________ CMC '57 Porsche Speedster Replica and Dolphin boat tailed full pan VW MOD-T Street Buggy |
oprn Samba Member
Joined: November 13, 2016 Posts: 12740 Location: Western Canada
Posted: Sun Mar 18, 2018 4:00 pm Post subject: Re: I need a 1600/1641 engine for my manx clone |
I would suggest you figure out what caused the problem lest you spend the money and end up right back in the same boat pouring good money after bad! |
Posted: Sun Mar 18, 2018 4:20 pm Post subject: Re: I need a 1600/1641 engine for my manx clone |
weasel_ugs wrote: |
I suggested this to do while the engine was still together so you can run it until a later date to fix it right, unless the engine is totally dead now? |
