RHD ‘67 Notch
Mid West Dubber
Mid West Dubber is offline
PostPosted: Fri Feb 23, 2018 8:42 pm    Post subject: Re: Aussie ‘67 Notch Reply with quote
Since changing the brake master cylinder to a dual circuit system I needed to mount a new brake fluid reservoir. I made a bracket to hold the reservoir and also fitted the hoses to the top of the master cylinder. .
Mid West Dubber
PostPosted: Fri Feb 23, 2018 8:43 pm    Post subject: Re: Aussie ‘67 Notch Reply with quote
Gearbox and brakes are coming along nicely...
Mid West Dubber
PostPosted: Fri Feb 23, 2018 8:45 pm    Post subject: Re: Aussie ‘67 Notch Reply with quote
Fitted hard brake lines from a late type 3.
Few odd jobs left to do under here (clean back the surface rust on the steering column, replace a few rubbers, etc.)
Mid West Dubber
PostPosted: Sat Feb 24, 2018 10:07 pm    Post subject: Re: Aussie ‘67 Notch Reply with quote
Gearbox back in and also got the shift rod back in with a new bush and coupling. Bolted the shocks on, connected the handbrake cables, spring plates with new bushes, etc.
Mid West Dubber
It has come a long way since these pics were taken...
Mid West Dubber
PostPosted: Sat Feb 24, 2018 10:08 pm    Post subject: Re: Aussie ‘67 Notch Reply with quote
Had the drums machined and painted them with brake paint. Put the drums back on and got the notch back on the ground.
Mid West Dubber
PostPosted: Sat Feb 24, 2018 10:10 pm    Post subject: Re: Aussie ‘67 Notch Reply with quote
Was never really 100% happy with having 4 stud on this notch, so I had been collecting parts and made a start on putting it back to wide 5.
Tried to track down a pair of OG rear drums but ended up going with a pair of new ones. Got the rear all sorted and back on the ground.
Mid West Dubber
PostPosted: Sat Feb 24, 2018 10:11 pm    Post subject: Re: Aussie ‘67 Notch Reply with quote
Some original front drums cleaned back and painted...
Mid West Dubber
Stubs were stripped back and given a fresh coat of paint...
Mid West Dubber
PostPosted: Sat Feb 24, 2018 10:12 pm    Post subject: Re: Aussie ‘67 Notch Reply with quote
Assembling the front brakes onto fresh black backing plates. NOS wheel cylinders and original parts all cleaned and given a freshen up...
Mid West Dubber
PostPosted: Sat Feb 24, 2018 10:13 pm    Post subject: Re: Aussie ‘67 Notch Reply with quote
Back on wheels with wide 5 on all corners.
MonT3
MonT3 is offline
PostPosted: Sun Feb 25, 2018 5:55 am    Post subject: Re: Aussie ‘67 Notch Reply with quote
Nice work there. Keep at it!
MonT3
67 Squareback
64 Squareback
63 Squareback
Engine rebuild
Trailer rebuild
andybla
andybla is offline
PostPosted: Wed Feb 28, 2018 11:40 am    Post subject: Re: Aussie ‘67 Notch Reply with quote
nice!
Bobnotch
Bobnotch is offline
PostPosted: Thu Mar 01, 2018 11:31 am    Post subject: Re: Aussie ‘67 Notch Reply with quote
Very nice. Cool Amazing what a little clean up and paint can do. Very Happy
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
Mid West Dubber
PostPosted: Mon Mar 05, 2018 1:44 pm    Post subject: Re: Aussie ‘67 Notch Reply with quote
Had a set of early type 3 rims re-hooped into safety rims. Hoping to get these painted soon and some fresh rubber on them
andybla
andybla is offline
PostPosted: Tue Mar 06, 2018 4:14 am    Post subject: Re: Aussie ‘67 Notch Reply with quote
i really like the idea of the dual circuit mount. maybe i will give that a try when i do mine.
Mid West Dubber
PostPosted: Sun Mar 18, 2018 6:10 pm    Post subject: Re: Aussie ‘67 Notch Reply with quote
The engine needed a big tidy up, this is what I started with
Mid West Dubber
PostPosted: Sun Mar 18, 2018 6:11 pm    Post subject: Re: Aussie ‘67 Notch Reply with quote
The carbs needed a good clean and rebuild. The accelerator pumps on both carbs had an extreme amount of wear where the connecting link mounts. So I welded the holes up carefully and then re-drilled the holes.
I think they came up alright
Mid West Dubber
PostPosted: Sun Mar 18, 2018 6:13 pm    Post subject: Re: Aussie ‘67 Notch Reply with quote
Coming together nicely
HenrikL
HenrikL is offline
PostPosted: Mon Mar 19, 2018 12:26 am    Post subject: Re: Aussie ‘67 Notch Reply with quote
Nice work! Did Australian Type 3s use 6 or 12 volts in 1967?
Page 2 of 6
