Too many dual carb choices help me out please
newt374
newt374 is offline
PostPosted: Fri Mar 16, 2018 8:59 am    Post subject: Too many dual carb choices help me out please Reply with quote
Hi I have a 68 bay I rebuilt the engine with W-110 cam, mofoco 040 dual port heads, 1641 cylinder kit, and an empi 4 tip gt exhaust that I had to cut and creatively fab my heat exchanges in to but there is no mount for the heat riser tube on the left side so choke wants to stay on and the intake starts to ice up on me. I need / want to put dual carb on it because that and the performance upgrade. But there are so many options if anyone could shed some light on this for me it would be very much appreciated.
Thank you
richparker
richparker is offline
PostPosted: Fri Mar 16, 2018 9:19 am    Post subject: Re: Too many dual carb choices help me out please Reply with quote
Weber IDF40s with the CB linkage. They will work well with your 110 cam, they’ll produce good power and good millage. You might want to look into changing that exhaust to a merged header and a quite pack, that will also produce more power for you and keep the exhaust fumes out of the inside of the bus. Good luck.
__________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build
Xevin Premium Member
Xevin is offline
PostPosted: Fri Mar 16, 2018 9:24 am    Post subject: Re: Too many dual carb choices help me out please Reply with quote
I was thinking the same as Rich. Matter of fact I was thinking of Riche’s Bus when you asked the question. Email John at aircooled.net
Really good guy. After speaking to him about my 1641 bug build I bought my cam from him. He had the cam at more doorstep in 3 days. His customer service is tip top.
http://www.aircooled.net/vw-carburetor-options-selection-101/
Keep on Busin'
67rustavenger wrote:
Clatter wrote:
skills@eurocarsplus wrote:
SGKent wrote:
Hikelite
Hikelite is offline
PostPosted: Fri Mar 16, 2018 10:15 am    Post subject: Re: Too many dual carb choices help me out please Reply with quote
x3
Weber 40IDFs
fyi, aircooled.net has them back ordered right now. I have a set coming on Monday directly from CB performance.
They are also going into a '68, but my motor is 1915cc w/hydraulic lifters.
~Kevin
My 1968 Campmobile
sethpat
sethpat is offline
PostPosted: Fri Mar 16, 2018 10:36 am    Post subject: Re: Too many dual carb choices help me out please Reply with quote
I'm running some baby Weber's and definitely think I could bump it up to the 40's. Go with the 40's
Unnamed 1986 Syncro
Frankenbus (sold)
https://www.thesamba.com/vw/forum/viewtopic.php?t=674133&highlight=
1975 Westfalia
914 IV 1.7
93mm pistons
Weber 34 ICT's
Cam 264* .402 lift
vwdave33
vwdave33 is offline
PostPosted: Fri Mar 16, 2018 8:24 pm    Post subject: Re: Too many dual carb choices help me out please Reply with quote
Rebuilt dellorto drla 36 mms would work awesome!
They have 5 progression ports instead of 4 like the webers.
Also you can change out idle and main jets from the top which makes jetting easier.
skills@eurocarsplus
Samba Peckerhead
PostPosted: Fri Mar 16, 2018 8:30 pm    Post subject: Re: Too many dual carb choices help me out please Reply with quote
X2 for the dells....
more money but man, are they nice. either weber or dells....REAL DEAL no china junk....
your combo with 40's will be like flushing a toilet. you have a warmed over 1600, lets be real. bigger isn't always better here
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
[email protected]
roy@mofoco.com is offline
PostPosted: Mon Mar 19, 2018 7:11 am    Post subject: Re: Too many dual carb choices help me out please Reply with quote
Thank you
Dual 40 IDF's. I order directly from Weber and install their steel cross bar linkage on every motor I build, works perfect.
I can get a set shipped out by tomorrow for you.
Please "LIKE" us on facebook to see what we are working on.
https://www.facebook.com/mofoco?ref=ts&fref=ts
www.mofoco.com
Cylinder Head Reference Sheet
