YDBD Samba Member
Joined: February 25, 2017 Posts: 891 Location: Bavaria, Germany
Posted: Sun Mar 18, 2018 9:35 pm Post subject: Brake Drum Stud Spins |
I have early brake drums that have been drilled and studs with splines were pressed in. One of the studs is spinning, don't really want to re do a new drum.
Can I pull the drum off and just tack weld the stud?
Thanks, _________________ '56 pan Dune Buggy since '69
don't live in the past...but when I did:
'67 bug
'64 baja
'60 dune buggy
'73 Personenkraftwagen Type 182 "Thing" |
Vanapplebomb Samba Member
Joined: November 03, 2010 Posts: 5417 Location: Holland, MI
Posted: Mon Mar 19, 2018 7:36 am Post subject: Re: Brake Drum Stud Spins |
I did that. Tack weld it down in a couple places near the inside perimeter of the drum. The steel doesn’t like to weld to the cast iron super well, so at some point it will likely pop off the drum. If you tack weld near the inner perimeter of the drum, the stud won’t spin on you even if the weld pops off the drum. _________________ 1800 Type 4 Berrien 295
http://www.thesamba.com/vw/forum/viewtopic.php?t=487021 |
Dale M. Samba Member
Posted: Mon Mar 19, 2018 7:44 am Post subject: Re: Brake Drum Stud Spins |
You can tack it... But first I would pop it out and see if just replacing stud may fix problem.... It could be the splines on stud are just thrashed...
Boolean Samba Member
Joined: January 19, 2012 Posts: 1712 Location: Stockholm
Posted: Mon Mar 19, 2018 8:12 am Post subject: Re: Brake Drum Stud Spins |
Tighten the stud with a socket or something between the lugnut and the drum so it sits square before tacking. Don't do a weld all around the stud, just one or two tacks. _________________ I strive for perfection. Excellence will not be tolerated!
Build thread here:
http://www.thesamba.com/vw/forum/viewtopic.php?t=529379 |
HotStreetVw Samba Member
Joined: October 03, 2004 Posts: 871 Location: Wild West
Posted: Mon Mar 19, 2018 10:29 am Post subject: Re: Brake Drum Stud Spins |
I don't recommend welding a hardened stud to a cast drum. I would replace the stud and red loctite it in. or replace the drum _________________ 4inBhore
50 Split - 2724cc NA. Haltech injected
62 Notchback - 2542cc Turbo WIP |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15309 Location: Deep in the 405
Posted: Mon Mar 19, 2018 11:45 am Post subject: Re: Brake Drum Stud Spins |
Dorman makes hundreds of press in studs. Find one with the next size larger splines area with the same thread size and press it in. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Posted: Mon Mar 19, 2018 12:55 pm Post subject: Re: Brake Drum Stud Spins |
Section 10 pages around 160+ ...
https://www.dormanproducts.com/flipbook/dorman/automotive-hardware/2006-Automotive-Hardware.pdf
If you really need to you can order 1 to 100 with Dorman part number through places like Rockauto.com or any distributor that handles Dorman parts...
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Mon Mar 19, 2018 2:48 pm Post subject: Re: Brake Drum Stud Spins |
Yes OK to weld. We used to weld them in on the circle track ghia. Handled the abuse of constant left turns real well _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
rs58rag Samba Member
Joined: August 22, 2010 Posts: 419 Location: riverside,ca
Posted: Mon Mar 19, 2018 4:25 pm Post subject: Re: Brake Drum Stud Spins |
What vwracerdave said^ |
YDBD Samba Member
Posted: Mon Mar 19, 2018 9:46 pm Post subject: Re: Brake Drum Stud Spins |
thanks for the help/info/feedback!
I will pull the drum and do a closer inspection. Won't be on the road for a while as it's 10 degrees outside....wtf March? _________________ '56 pan Dune Buggy since '69
'67 bug
'64 baja
'60 dune buggy
modok Samba Member
Posted: Mon Mar 19, 2018 9:49 pm Post subject: Re: Brake Drum Stud Spins |
loctite 620 |
YDBD Samba Member
Posted: Tue Apr 03, 2018 9:30 am Post subject: Re: Brake Drum Stud Spins |
Took it across the street to my landlords construction business, the Geschaftsmeister shot two welds on it in about 20 seconds. Perfect! _________________ '56 pan Dune Buggy since '69
'67 bug
'64 baja
'60 dune buggy
earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
Posted: Tue Apr 03, 2018 9:34 am Post subject: Re: Brake Drum Stud Spins |
I prefer to tack weld them with a TIG welder and Silicon Bronze wire in 3 places around the stud flange.
Casey _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
