robert reese Samba Member
Joined: March 19, 2011 Posts: 51 Location: asheville n.c.
Posted: Sat Mar 17, 2018 6:58 pm Post subject: jack stand placement |
I have done the search, but still wonder where jack stand should go. sub frame ? where is the sub frame ? Any pictures of eurovan up on stands.I hope I am not sounding to dumb but I want to be safe not hunt or dead, thanks. |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22640 Location: NYC/Upstate/ROW
Posted: Mon Mar 19, 2018 11:15 am Post subject: Re: jack stand placement |
Ill shoot some today - give me a few minutes
PS - not really a topic you can ever ask a dumb question about. _________________ .ssS! |
pinetreeporsche Samba Member
Joined: June 11, 2009 Posts: 752 Location: Falls Church, VA
Posted: Wed Mar 21, 2018 12:52 pm Post subject: Re: jack stand placement |
As it's now a week since I bought my '97, I've scratched my head about jacking/jack stands, and lots of other odds or ends. IS THERE a copy of the basic owner's manual available online? I doubt it's protected by copyright, so if it isn't, could an owner either scan it or snap pics of all the pages, and make it available on this site or anywhere else on line? |
Joshwa Samba Member
Joined: November 18, 2015 Posts: 810 Location: North Seattle WA
Posted: Wed Mar 21, 2018 2:21 pm Post subject: Re: jack stand placement |
If you are using the stock jack that comes with the van, there are indentions just behind the front wheel and just in front of the rear wheel, that locate where you should be placing the jack on the pinch weld. I've used those positions without any issue. I've seen plenty of vans that have damage from jacking anywhere else on the pinch weld. If your van is completely sacked down with weight, I wouldn't jack on any part of the pinch weld.
Here's a poor picture that I've yellow boxed the spots I'm referring to.
I've often jacked the front end up on the frame similar to this picture. disregard the jack stands.
I haven't done it yet, but I like the idea someone said about just jacking the rear up from the hitch, if you have one. _________________ 93 Weekender TDI conversion (AHU)
93 MV TDI conversion (1Z)
Weekender rear cot
Late model cabin air filter on 93
Euro spec bumper install on 93 |
jonathannickel Samba Member
Joined: September 28, 2015 Posts: 38 Location: Saratoga Springs
Posted: Fri Mar 23, 2018 3:56 am Post subject: Re: jack stand placement |
I've jacked the camper up using the hitch, but on my GW-lifted van I needed a piece of wood on top of my floor jack because the hitch is so high.
Worked great. Be sure to chock your front wheels. |
Posted: Fri Mar 23, 2018 4:24 am Post subject: Re: jack stand placement |
Driveway lifting review
Hard level surface. No dirt or stone or grass
Block chock the opposite wheel To that being lifted, eg, if you lift the front left , block the rear right
Block means TWO chocks/blocks on each side of that wheel. Handbrake on hard, gear in or park.
I have two modes of safety
1. 1 wheel working where I’m not underneath....jack stand, and jack remains in contact with frame as safety near where I’m working
2. Underneath or heavy parts moving..I put a 4x4 under the frame on two more jack stands as a hard safety _________________ .ssS! |
