Barter_Builder 69 FI/AC
Posted: Fri Mar 23, 2018 2:38 am Post subject: How tall are shorty manifolds |
And if you could buy any carb kit today what would it be for a 1600. |
Sqrbckguy38 Samba Member
Joined: December 21, 2004 Posts: 415 Location: Tooele, ut
Posted: Fri Mar 23, 2018 5:46 am Post subject: Re: How tall are shorty manifolds |
If by "shorty" manifolds, you mean the idf and ida style carb manifolds, they are only about four inches tall. As far as what carb kit, I'd say the ict kit is about the least expensive, and easiest setup and tuning. Though I've become more partial to the Fi setup in recent years. _________________ It's not the fall that hurts, it's the sudden stop at the bottom.
69 Square needs love, even after 15 years
70 Fasty former dd, now my daughter's
67 Beetle, Opal |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22422 Location: Kimball, Mi
Posted: Fri Mar 23, 2018 1:05 pm Post subject: Re: How tall are shorty manifolds |
Depends on which engine, and what size it is. For an 1800 or smaller, the 34 ICT is hard to beat, and the 32 PDSIT Solex (stock for 66 and 67 in the USA) are about equal. Above the 1800, you want dual throat dual carbs. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13278 Location: Tejas!
Posted: Fri Mar 23, 2018 3:03 pm Post subject: Re: How tall are shorty manifolds |
I'd rather have dual throat even on a 1600. 36 dells on a type 3 is really nice with the jets on top. Dual DCNF is really compact choice that works great as well, you'll have to choke them down _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
Posted: Sun Mar 25, 2018 2:08 pm Post subject: Re: How tall are shorty manifolds |
I'm racking my brains with this FI and don't want to convert but the frustration is making me want to make it easy... |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Sun Mar 25, 2018 2:27 pm Post subject: Re: How tall are shorty manifolds |
Barter_Builder wrote: |
Tram keeps my fuel injection running good! Read in the Fuel Injection Sticky & post your symptoms there for the expert help. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Mon Mar 26, 2018 1:01 pm Post subject: Re: How tall are shorty manifolds |
You won't be the first, nor the last. On my old 71 Notch, I went with carbs for a while as I kept having FI issues with it. I did about a month of real world driving and constant testing before putting the carbs on (I had already lost 1/2 a summer to the FI). I tested all of the parts of the FI system (they were ALL good), and even replaced the FI wiring harness, but still had issues (it should have ran great, but didn't). Put the carbs on, and the car was good to go. Then later that year, I talked in person with Russ and Jim. Jim suggested I put the FI back on, and ran some more tests and found I had a slowly dieing Voltage Regulator. It would start out at 14.5V, and slowly drop to 13 volts after 5 miles, causing my running issues. Replaced the VR, and all was good. Never saw the problem with carbs, as the engine would run fine on 13 to 12 volts, but the FI ran crappy below 13.4 volts.
I talked to the guy who bought it about a year after I sold it, and found he put carbs back on it, so he could drive it trouble free as the FI started acting up again. I don't know what it was doing for him, but I think it was generator of VR related (or both) for him, as he replaced both before he went to carbs. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4921 Location: Southern AB
