Installing tin
jmacgreg
jmacgreg is offline
PostPosted: Sat Mar 24, 2018 9:03 am    Post subject: Installing tin Reply with quote
A question: Is it possible to install the lower cooling tins (sleds) and J-tube shields while the motor is in the car (1966 Type 1)? I know that the "recommended" way is to pull the motor. It's a pretty major effort for me. I have to remove the carbs, linkage, oil filters and cooler as well as the associated plumbing and I don't have any help. Just wondering. The "trick" would be to access the front four screws on the tin pieces. If I'm dreaming, please don't sugarcoat the answer. Thanks in advance.
Brian
Brian is offline
PostPosted: Sat Mar 24, 2018 9:15 am    Post subject: Re: Installing tin Reply with quote
How many curse words do you know? You'll need a lot of them for that job.
Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter
SRP1
SRP1 is offline
PostPosted: Sat Mar 24, 2018 9:29 am    Post subject: Re: Installing tin Reply with quote
Not going to happen. The front plate (apron) that seals the engine bay to the cylinder covers sits directly over the screw holes for the sleds. It would be a hack job trying to force the sleds in. Just run it as is until you have to pull the engine.
Eaallred
Eaallred is offline
PostPosted: Sat Mar 24, 2018 10:30 am    Post subject: Re: Installing tin Reply with quote
We just did this on my friends 65 the other night. Engine in the car, doghouse tin. It sucked, but is possible. We had to take the heater boxes off.
Eric Allred
You have to remember something: Everybody pities the weak; Jealousy you have to earn.
vwjetboat
vwjetboat is offline
PostPosted: Sat Mar 24, 2018 10:36 am    Post subject: Re: Installing tin Reply with quote
An average Mechanic with average skills can pull a vw motor in under 30 minutes.. taking their time.. a very skilled one can R&R motor .. clutch and rear seal in half that time.. I know saw it done..and he answered phone 2 times... lol pull the motor.. inspect everything.. do it right..
128vw
128vw is offline
PostPosted: Sat Mar 24, 2018 6:37 pm    Post subject: Re: Installing tin Reply with quote
When I was younger and doing vw work every day I could pull a motor, replace the frt seal and clutch and install the motor in 1/2 hour by myself. Now it's a 2hour job. I'm 73 now, been doing this since I was 16. Did a valve job,2 heads, in an hour once because I had to.
56 Jungle green restored w/orig interior
65 Ruby red w/ 1600 single port
building 66vert on 69pan w/ 2332
Cusser
Cusser is offline
PostPosted: Sun Mar 25, 2018 8:41 am    Post subject: Re: Installing tin Reply with quote
I never time myself or try for a speed record. Except in bed.
Now that I'm getting old, I try to make sure to drag all the needed tools underneath (17mm combination wrench, ratchet with 8mm socket, screwdrivers for heater tubes, screwdriver/golf tee for fuel line, etc). I need to try to minimize the number of go-unders.
SBD
SBD is offline
PostPosted: Sun Mar 25, 2018 12:08 pm    Post subject: Re: Installing tin Reply with quote
Think I think I want to add this to my signature line! Very Happy
"Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
mark tucker wrote:
I wouldent waste $ or thyme on building a small motor. build it big so it dosent have to work hard.remember it's only as fast as your foot alows it to be unless you build a small turd then it just stinks as it squishes up through your toes when you step on it.
andk5591
andk5591 is offline
PostPosted: Sun Mar 25, 2018 12:12 pm    Post subject: Re: Installing tin Reply with quote
The one thing that helps....a little...is replacing the screws with hex head bolts....It can be done...not easy.
D-Dubya Manx clone - 63 Short pan,1914.
There's more, but not keeping them...
60ragtop
Bonneville Belt Bitch
60ragtop is offline
PostPosted: Sun Mar 25, 2018 12:28 pm    Post subject: Re: Installing tin Reply with quote
And pissing cusser off when he has all the right tools except for when someone decides to deviate from stock and he has to get his sore body up once again Wink
Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote:
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote:
maybe he just snapped cause his car sucked Wink
jmacgreg
jmacgreg is offline
PostPosted: Mon Mar 26, 2018 7:30 am    Post subject: Re: Installing tin Reply with quote
Thanks for the replies. If the engine were a stocker, I would pull it - no questions asked. It has big carbs and a lot of external plumbing that would need to be disconnected and likely messy as well. I will drive it "as is" until I have a better reason to take the motor out. I'm 70 years old and not as agile as I once was. The car is a good weather "weekend" driver and doesn't have a cooling problem. I just felt nervous about the push rod tubes being "exposed." I spent about 6 hours under my Jeep last week and relearned an entire dictionary of cuss words. I don't wish to repeat the pleasure.
bnam
bnam is offline
PostPosted: Mon Mar 26, 2018 8:56 am    Post subject: Re: Installing tin Reply with quote
If you don't have the tins now, why not install the tins without removing installing the front screws? The 4 screws on the bottom - 2 to each heater and 2 to the case on each side should hold up the tin I think. There will be a gap at the front, you can seal with some foam to stop leak and minimize rattling. Should this not be possible?
Just thinking out loud.
Click to view image
1952 Citroen TA 11BL
jmacgreg
jmacgreg is offline
PostPosted: Mon Mar 26, 2018 9:27 am    Post subject: Re: Installing tin Reply with quote
Yeah, I'd thought about only securing the tins with the bottom screws. However, The motor does not have heater boxes (header with J-tubes) and I also planned to add the industrial tin shields as well. I don't know if this would be feasible without ending up with a whole lot of rattling around.
neil68
neil68 is offline
PostPosted: Mon Mar 26, 2018 2:32 pm    Post subject: Re: Installing tin Reply with quote
When I installed a new header in my Beetle, I swapped the sled tins for new ones, without removing the engine. You just have to think about how best to reach the front tin screws with long screwdrivers depending which carbs you have.
Neil.
Der Kleiner Rennwagens
68 Beetle 2332 cc, 204 WHP
12.5 seconds @ 107 mph
Dynojet Test: https://www.youtube.com/watch?v=M9B_H3eklAo
