4118thing Samba Member
Posted: Sun Mar 25, 2018 6:41 am Post subject: 74 engine in a 73 Thing |
My 73 came with a 74 AH motor, complete with a 74 fan shroud. Obviously the heater hose to the heater box (for a real 74) have now where to go. What should I do? Is it worth trying to find a 73 fan shroud? What do others do? Is it ok to leave the snorkels, on the shroud open? Do I cap them off?
Planning on leaving the heater boxes attached, as it has no effect, that I can see.
This forum has been very helpful, for my newbie questions.
PS I致e tried to find other threads, but either I知 using the wrong search words, or this topic does not exists. |
Arkansauced Samba Member
Joined: November 11, 2014 Posts: 52 Location: Colleyville, TX
Posted: Sun Mar 25, 2018 8:09 am Post subject: Re: 74 engine in a 73 Thing |
An original 73 shroud will set you back $300. I would suggest the plugs below.
http://www.jbugs.com/product/9151.html
You could also buy an aftermarket 36hp style doghouse shroud, but samba knowledge base will tell you that the OEM shroud cools better due to internal vanes (although I think the Scat shroud has these as well)
I recently saw a 73 Thing style shroud that is being remanufactured very similar to the original, anyone have a link to that? |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76939 Location: Sneaking up behind you
Posted: Sun Mar 25, 2018 8:27 am Post subject: Re: 74 engine in a 73 Thing |
Arkansauced wrote: |
I make no personal recommendation since i've not seen/tested one personally. From the picture, it's missing the mounts for the coil and the fitting in the upper right for the charcoal canister. Also the indent for the air cleaner.
http://usstore.concept1.ca/Fan-Shroud-W-OHeat-W-Holes-COOLED.1.2-62217/
Real 73 Type 181 (Thing) shroud.
_________________ Glenn
Member #1009
#BlueSquare |
Posted: Tue Mar 27, 2018 7:58 pm Post subject: Re: 74 engine in a 73 Thing |
If you think you will ever drive your vehicle during cold weather then figure out how to hook up the exhaust heat. I had a '73 which I added the heater boxes to and all the rest of the heater related pieces. I dumped one heater box under the rear seat and routed the other up through the rear deck. This made for a very toast ride when combined with the gas heater.
I didn't have any controls up front for the heater, just a jury rigged system to open the flappers come late fall and close them again when warmer weather arrived in the spring. I intend to do the same to my present '73 someday. |
Posted: Wed Mar 28, 2018 7:14 pm Post subject: Re: 74 engine in a 73 Thing |
I live in the mountains of Western North Carolina, so I知 not planning on driving in the Winter. If I do, it値l be just several layers of clothes, and some warm gloves. Heck, I知 not even thinking about a top for the summer. |
Joined: February 21, 2003 Posts: 868 Location: Clifton Park NY Saratoga County
Posted: Sun Apr 08, 2018 7:54 am Post subject: Re: 74 engine in a 73 Thing |
FYI
racquetballs fit perfect in the heater hose holes on a fan shroud _________________ Michael Basso
http://www.thingparts.com
New and Used VW Thing Parts Free advice
CALL 518 630 0173 |
Posted: Sun Apr 08, 2018 8:37 am Post subject: Re: 74 engine in a 73 Thing |
[email protected] wrote: |
FYI
racquetballs fit perfect in the heater hose holes on a fan shroud |
I cut soda cans in two and used screw clamps to hold the bottoms of the cans over the outlets. |
Posted: Sun Apr 08, 2018 11:06 am Post subject: Re: 74 engine in a 73 Thing |
What about the holes on the tins leading to the heater boxes? And along those lines, does it make sense to eliminate tha heater boxes, and/or replace the j-tubes? |
Posted: Sat Apr 14, 2018 3:04 pm Post subject: Re: 74 engine in a 73 Thing |
Ok, I think it been determined that I have a 74 Beetle, or Super Beetle (if there is a difference), iengine in my 73 Thing. Since I have no use for the forced air heat, of a 74 engine, my question is this:
Do I cap off the the fan shroud snorkel and holes in the engine tin to the heater manifold, or do I leave it alone and run flexible heater hoses, to the exhaust heaters? Obviously, any airflow to the heater would just exhaust into open.
I have read that closing the snorkel can have an adverse effect on cooling.
Thanks for everyone痴 help. The information I知 getting is quite informative. |
Posted: Sat Apr 14, 2018 7:23 pm Post subject: Re: 74 engine in a 73 Thing |
4118thing wrote: |
I have mine blocked at present. Is this the best? I do not know. Maybe blocking 1/2 of the area of the opening would be better? Without some testing there is no way to know for sure. One would need both a Cylinder Head Temperature Gauge and a properly located Oil Temperature Gauge to be able to determine what is best here. |
