Chrome torsion plate covers
Leanna
Leanna is offline
PostPosted: Sat Mar 24, 2018 12:07 pm    Post subject: Chrome torsion plate covers Reply with quote
I've owned a 66 sears rascal on a 61pan been going thru fixing and redoing things that were half done or just wrong wanting to put a set of the chrome torsion covers how big a deal is this
jsturtlebuggy
jsturtlebuggy is offline
PostPosted: Sat Mar 24, 2018 2:05 pm    Post subject: Re: Chrome torsion plate covers Reply with quote
You are going to more than likely needs some round pry bars, even a large Philips screw driver will work as a pry bar. The torsion bars are under tension and to get the cover back in place it need to be pried back into place so bolt hole line up. Sometimes it is easy other not so.
CB Performance makes aluminum covers #6231 that are better made.
Joseph
Fair Oaks/Orangevale, CA
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960
Leanna
Leanna is offline
PostPosted: Sat Mar 24, 2018 4:51 pm    Post subject: Re: Chrome torsion plate covers Reply with quote
Thanks
BL3Manx
BL3Manx is offline
PostPosted: Sun Mar 25, 2018 8:27 am    Post subject: Re: Chrome torsion plate covers Reply with quote
It also sometimes helps to start with longer bolts and then switch out to the correct length bolts one at a time after all the bolts are started
If you pull the torsion bar out(which you don't need to just changing the cap) put anti-seize on both ends
Wolfgangdieter
Wolfgangdieter is offline
PostPosted: Sun Mar 25, 2018 8:49 am    Post subject: Re: Chrome torsion plate covers Reply with quote
Easy job provided old bolts are not rusted and snap off! Apply PB Blaster for a few days before doing job. No need to touch the torsion bars at all. You may find the 50 year rubber bushings have perished. That makes the job harder as the new ones require some compression (can using longer bolts to bring together and the replace with strong OEM bolts). Remember though the quality of the Asian chrome plates is NOT good. Why not blast/sand repaint the original ones that are there?
CMC '57 Porsche Speedster Replica and Dolphin boat tailed full pan VW MOD-T Street Buggy
Q-Dog
Q-Dog is offline
PostPosted: Sun Mar 25, 2018 12:42 pm    Post subject: Re: Chrome torsion plate covers Reply with quote
It took about 3 whole weeeks for the chrome to start rusting on the covers I installed on my buggy. Evil or Very Mad
Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle
57BLITZ
57BLITZ is offline
PostPosted: Sun Mar 25, 2018 1:42 pm    Post subject: Re: Chrome torsion plate covers Reply with quote
Those look COOL! Almost makes me wish my buggy has swing-axles so I could use them!
On my '62 Bug . . . P.O. put those cheap chrome torsion covers on . . . chrome is rusted . . . and the metal seems thinner than the stock covers!
Jesucristo es mi Seņor y Salvador!
