A few more onboard laps...Who needs more than 1300cc?
hrsr
hrsr is offline
PostPosted: Wed May 29, 2013 3:24 pm    Post subject: A few more onboard laps...Who needs more than 1300cc? Reply with quote
rlmartinez
rlmartinez is offline
PostPosted: Wed May 29, 2013 3:39 pm    Post subject: Reply with quote
Great Video,
How about posting some pics of the car?
54 Bug
hrsr
hrsr is offline
PostPosted: Wed May 29, 2013 10:15 pm    Post subject: Reply with quote
rlmartinez wrote:
Great Video,
No probs!
[/img]
djway3474
djway3474 is offline
PostPosted: Wed May 29, 2013 11:59 pm    Post subject: Reply with quote
Very Happy Shocked Cool Wink Very Happy
tatersgravy
tatersgravy is offline
PostPosted: Thu May 30, 2013 9:56 am    Post subject: Reply with quote
"Top Shelf" is it possible to tell a bit more about the engine build?
Thanks!
hrsr
hrsr is offline
PostPosted: Thu May 30, 2013 12:03 pm    Post subject: Reply with quote
Here's the basic spec:
Car Spec: 1965 swing axle Beetle, CSP disc brakes all round, 1285cc, 44 Webers, Engle FK10 cam, reworked stock heads with stock sized valves, cooling by 12 inch electric fan and ram air pipes, approx [email protected] 8000rpm. Bears close ratio gearbox with a Quaife ATB diff, Dunlop historic crossply tyres, weight around 740kg with driver. Front suspension: Stock beam, springs and rubber bushes, adjustable Formula Vee anti-roll bar, 2.5" dropped spindles, Quantum double adjustable motorsport dampers. Rear suspension: Stock springs and rubber bushes, lowered 2 splines, custom made heavy duty adjustable Z-bar, Quantum double adjustable motorsport dampers.
64vdub
64vdub is offline
PostPosted: Thu May 30, 2013 12:43 pm    Post subject: Reply with quote
Very Nice! That's what it looks like when I go to work Smile
64' Pearl White beetle, type 113 sedan. Purchased in Hamburg Germany, driven for a year via vw tourist program, shipped to CA in 1965.
Founding member of Derkaferklub, Southern Cal. since 2008
Q: Would you consider a trade? What do you collect?
A: I collect money Smile
GO SF GIANTS!
tatersgravy
PostPosted: Sat Jun 01, 2013 11:47 am    Post subject: Reply with quote
Thanks!
Those are very solid numbers for a 1285cc engine!
SparksLP
SparksLP is offline
PostPosted: Thu Mar 15, 2018 7:45 pm    Post subject: Re: A few more onboard laps...Who needs more than 1300cc? Reply with quote
What size tires are you running? I am assuming some version of a 165r15 or 155r15?
Tom
1966 VW Beetle Sunroof Sedan
Teeroy Premium Member
Teeroy is offline
PostPosted: Fri Mar 16, 2018 10:36 am    Post subject: Re: A few more onboard laps...Who needs more than 1300cc? Reply with quote
what are the gear box specs? Seems very well sorted for a swingaxle car! Little loose in the real tight corners.
Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org
JeeWee
JeeWee is offline
PostPosted: Sun Mar 18, 2018 1:49 pm    Post subject: Reply with quote
It is more what it looks like when I am driving home from work Wink
Very respectable numbers for a 1285! What compression ratio are you running? Which venturi size are you running on those mighty 44's?
1192CC WW okrasa
48,2 DIN PS (58SAE HP)@4430rpm - [email protected]
boxkiteflyer
boxkiteflyer is offline
PostPosted: Wed Mar 28, 2018 6:13 pm    Post subject: Re: A few more onboard laps...Who needs more than 1300cc? Reply with quote
The Cortina seemed to have the upper hand in the straight sections but you definitely had the cornering and acceleration in command! Very cool! Thanks for posting and look fwd to more!
boxkiteflyer
PostPosted: Thu Mar 29, 2018 5:49 pm    Post subject: Re: A few more onboard laps...Who needs more than 1300cc? Reply with quote
Do you have any pics of the electric fan/ ram air pipes, please, or is that proprietary? I love watching this vid! It's pretty funny but I find myself leaning into the turns! Laughing
