ConcreteAce Samba Member
Joined: May 19, 2005 Posts: 856 Location: Spring, Texas
Posted: Sat Mar 31, 2018 8:06 pm Post subject: Re: ConcreteAce's '51 build |
Made a little more progress with help from some of my fellow club members. Cut and buffed the old paint. She shined up nicely. enjoy the photos..
and after 11 hrs its almost done
and a couple of high speed video's
_________________ Ethan Dunlap
Spring, Texas
'51 Deluxe
'61 Build
'68 Turbo Diesel Baja
'64 Ghia Vert
'61 Baja Build |
Oldman64 Samba Member
Joined: January 02, 2015 Posts: 8 Location: In the desert, SoCal
Posted: Mon Apr 02, 2018 10:34 am Post subject: Re: ConcreteAce's '51 build |
you guys somehow make this stuff look easy...really cool car and great to see guys rallying around and getting stuff dialed. |
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Mon Apr 02, 2018 6:18 pm Post subject: Re: ConcreteAce's '51 build |
Did you guys start with 1000 or 2000 grit? Or use compounds only?
Looks great! |
Posted: Mon Apr 02, 2018 7:08 pm Post subject: Re: ConcreteAce's '51 build |
txoval wrote: |
Looks great! |
started with 1000 dry and then moved to 1500 wet , 3000 wet, 5000 wet
wool pad with 3M Cutting
foam pad with 3m Polish _________________ Ethan Dunlap
Spring, Texas
'51 Deluxe
'61 Build
'64 Ghia Vert
'61 Baja Build |
Two Glove Boxes Samba Member
Posted: Mon Apr 02, 2018 7:37 pm Post subject: Re: ConcreteAce's '51 build |
Looks great are you taking it to the Classic? |
Posted: Mon Apr 02, 2018 7:49 pm Post subject: Re: ConcreteAce's '51 build |
German Krew wrote: |
LOL you must have missed my answer last time. Yes as long as it makes it , Plan is to drive it there.
ConcreteAce wrote: |
Nice work will you have it at The Classic? |
That is my plan as long as everything does well in the next couple of weeks during shake down trips. |
Spring, Texas
'51 Deluxe
'61 Build
'64 Ghia Vert
'61 Baja Build |
Posted: Mon Apr 02, 2018 7:52 pm Post subject: Re: ConcreteAce's '51 build |
Good luck and hope to see it there. |
Posted: Mon Apr 02, 2018 7:55 pm Post subject: Re: ConcreteAce's '51 build |
I will need it , I am going to take a few trips that are at least an hour these next weeks to see how she handles. _________________ Ethan Dunlap
Spring, Texas
'51 Deluxe
'61 Build
'64 Ghia Vert
'61 Baja Build |
Posted: Wed Apr 04, 2018 8:50 pm Post subject: Re: ConcreteAce's '51 build |
Well it is always the little things, I am not sure what is going on here, no visible cracks in the plug wires, no nicks, but it darn sure is jumping from the plug wires to the braided oil filter line.
Spring, Texas
'51 Deluxe
'61 Build
'64 Ghia Vert
'61 Baja Build |
johnshenry Samba Member
Joined: September 21, 2001 Posts: 9364 Location: Northwood, NH USA
Posted: Thu Apr 05, 2018 5:16 am Post subject: Re: ConcreteAce's '51 build |
Disconnect a plug wire one at a time at the head, let it limp on 3 cylinders and see if you can narrow it down to one bad wire, then replace it. _________________ John Henry
'57 Deluxe
'56 Single Cab |
sunroof Samba Member
Joined: October 06, 2006 Posts: 1773 Location: Winnipeg
Posted: Thu Apr 05, 2018 7:58 am Post subject: Re: ConcreteAce's '51 build |
Just read through this whole thread for the first time, so fun! Great job, thanks for taking the time to post all your great work.
Don _________________ Better and better mistakes! |
western auto Samba Member
Posted: Thu Apr 05, 2018 9:51 am Post subject: Re: ConcreteAce's '51 build |
check your plug gap if its too wide spark will follow the path of least resistance |
txoval Samba Member
Posted: Thu Apr 05, 2018 7:52 pm Post subject: Re: ConcreteAce's '51 build |
Same thing happened to me...replaced wires
Sometimes you can’t see the fractures |
djfordmanjack Samba Member
Joined: June 15, 2009 Posts: 2176 Location: Graz, Austria, Europe
Posted: Wed Apr 25, 2018 10:21 pm Post subject: Re: ConcreteAce's '51 build |
Well I took the old girl on a ten hour trip this past weekend. Drove it from Houston to Fredericksburg TX for the Texas VW classic. I ran her 640 miles the entire weekend. I did get a new set of plug wires installed before the trip, adjusted the valves and put a final tune and sync on the carbs. She hummed the whole way only stopping for fuel. I averaged 28.6 miles per gallon. She is a little slow climbing hills but she ran a steady 55-60 mph (GPS verified).
I only had two small issues the ISP reproduction pulley is leaking. I did run into a thread shortly after I bought the pulley https://www.thesamba.com/vw/forum/viewtopic.php?t=...;start=100
I wish I had read that before I spent 100 bucks on the pulley. I plan on switching it out with a stock pulley to see if that stops the leak. The other issue I have is that it is harder to start after you have been on the road for some time. It does start every time but it takes way longer than normal. I found if I start it with the throttle pushed to the floor it starts faster then if you just pump it once and push the button. I plan on tackling that issue in the next week or so.
One thing I did notice and I am not sure if this is an issue because I have never had a stock height car. It seems that the car is a little stiff and bouncy up front. I installed new kings, links and shocks so I am not sure if it is stiff just because everything is new or if there is an issue that I need to address. Before I left I aired the fronts up to 17 lbs and the rears to 25 lbs. on the highway it seemed fine but at lower speeds on normal roads and you feel everything. (that was the only complaint the wife had on the entire trip, she said the girls were sore from all the bouncing...lol if you get the point)
here are a couple of video's
and here are some pictures from the weekend and at the show. It is hard to believe but I got Best Engine at the show. Kind of a shocker since there were tons of beautiful 2 ltr's out there.
Spring, Texas
'51 Deluxe
'61 Build
'64 Ghia Vert
'61 Baja Build |
pastellgreen Samba Member
Joined: January 06, 2012 Posts: 1049 Location: Germany
Posted: Thu Apr 26, 2018 1:21 am Post subject: Re: ConcreteAce's '51 build |
The other issue I have is that it is harder to start after you have been on the road for some time. It does start every time but it takes way longer than normal. I found if I start it with the throttle pushed to the floor it starts faster then if you just pump it once and push the button. I plan on tackling that issue in the next week or so. |
I would state this to be normal, one time pump before getting started is the rule for a cold start of a 40hp engine with automatic choke system. For an already warmed up split the rule is to push the pedal slowly towards its end during cranking. There will be the point, where the engine will find enough fuel to start. For a very hot engine after only a short stop pushing directly the pedal to the end of its way during cranking is also my experience.
One thing I did notice and I am not sure if this is an issue because I have never had a stock height car. It seems that the car is a little stiff and bouncy up front. I installed new kings, links and shocks so I am not sure if it is stiff just because everything is new or if there is an issue that I need to address. Before I left I aired the fronts up to 17 lbs and the rears to 25 lbs. on the highway it seemed fine but at lower speeds on normal roads and you feel everything. (that was the only complaint the wife had on the entire trip, she said the girls were sore from all the bouncing...lol if you get the point) |
Welcome driving a stock spilt! The stiffy front axle is one of the caracterisitc points of the spilt eara! You might think there is no front suspension, but of course it is. They wanted the front axle to improve the car to corner well. A normal front suspension was spend up from the oval eara by expanding also the spring travel.
Your car sonds so nice during running! |
Posted: Thu Apr 26, 2018 9:27 am Post subject: Re: ConcreteAce's '51 build |
Great finally meeting you Ethan and the DLK guys.
Car looked great and I was glad to finally see it in person.
Here are some of my paparazzi pics.
Two angles.
I had to make them hit the brake lights, it always looks so good!
ScottyG Samba Member
Joined: November 25, 2008 Posts: 75 Location: Orange, TX
Posted: Thu Apr 26, 2018 12:52 pm Post subject: Re: ConcreteAce's '51 build |
.... It is hard to believe but I got Best Engine at the show. Kind of a shocker since there were tons of beautiful 2 ltr's out there.
Disagree... I'm not shocked at all! That engine is beautiful _________________ 59 DC Chiny Bus... but not too Chiny
50 Beetle 11A Standard Hoffman
57 Beetle Aussie RHD CKD
60 Beetle OG Survivor
84 DOKA 2WD Road-Tripper! |
Posted: Thu Apr 26, 2018 10:19 pm Post subject: Re: ConcreteAce's '51 build |
[size=18][b]Great finally meeting you Ethan and the DLK guys.
Great pics! It was good meeting you as well. I'm looking forward to seeing your split.
ScottyG wrote: |
Disagree... I'm not shocked at all! That engine is beautiful |
Thanks man! LOL glad you didn't blow my doors off on the highway in your DC that cop would have got you for sure. _________________ Ethan Dunlap
Spring, Texas
'51 Deluxe
'61 Build
'64 Ghia Vert
'61 Baja Build |
