4118thing Samba Member
Posted: Sat Apr 07, 2018 6:23 pm Post subject: Numbers matching Thing? |
I’ve got to admit, I’m a newbie on this and really need some help, quick. I’ve got my Thing at the body shop ready to paint, and I was planning on changing colors, but the more I look, the more it looks like it might be a numbers matching Thing, and I should not change colors.
The VIN# is a 183, but the sticker on the post shows a 10/73 build date. I know if this were a beetle, a 10/73 build, would make it after August year change. But Things May have been different.
The motor number is AH359087. From what I can tell is this is a Ca emission motor, and if I look at the Beetle engine decoder, shows a late 73 production date.
Originally, I thought that since it had heater snorkels on the fan shroud, and heater boxes, it was a replacement. But if this is a Ca engine, it might have been configured that way even though I have a gas heater.
As you can see, I’m confused as to numbers matching, and ready to paint. Please HELP. |
Al Capulco Samba Member
Joined: October 31, 2005 Posts: 532 Location: Northridge, CA.
Posted: Sat Apr 07, 2018 10:04 pm Post subject: Re: Numbers matching Thing? |
Your motor number should start with AM, if not then it's not an original motor for a Thing. You have a '73 model and someone replaced the motor. Not uncommon. |
Deckard Samba Member
Joined: April 07, 2012 Posts: 296 Location: Knoxville, TN
Posted: Sun Apr 08, 2018 4:26 am Post subject: Re: Numbers matching Thing? |
Do you mean the silver sticker in the post between the driver and the rear passenger's seat? There are also two other VIN number locations: On the front trunk's left side and on the transmission tunnel under the rear seats. The silver sticker is notoriously difficult to read.
Posted: Sun Apr 08, 2018 5:10 am Post subject: Re: Numbers matching Thing? |
Yes, I’m referring to the perforated sticker. Mine is basically the same as yours.
What confuses me is that Beetle years changed in August. My engine is an AH, which from what I can determine is a California engine. I don’t know if California required a different engine, to conform with their emissions.
I guess Mexico years changed with the calendar, and did not follow the German production year. |
Posted: Mon Apr 09, 2018 5:40 am Post subject: Re: Numbers matching Thing? |
The engine case should still be AM. As far as I know the '74 California/Emissions engines had an EGR valve in the manifold. Attached pic is not my car
Posted: Mon Apr 09, 2018 9:26 am Post subject: Re: Numbers matching Thing? |
Do you have muffs (intake air ducts) on the sides of your engine compartment? No muffs would indicate it came without exhaust heat.
My first Thing was a 183*** with a post 8/73 build date and had a gas heater. It was originally registered as a '73, but when it was in a wreck the adjuster gave me credit for it being a '74. |
