Soon to be the second owner of this oval vert
Page: Previous  1, 2, 3, 4, 5, 6, 7
grailoc
grailoc is offline
PostPosted: Fri Dec 29, 2017 8:42 am    Post subject: Re: Soon to be the second owner of this oval vert Reply with quote
I got from a friend a front beam from March 56 which is the same month as my beetle, so I started the restoration process. it is my winter project.
Thet plan is to put it on the vert once complete because the one I have in place is 4" narrow.
My 59 low light ghia: http://www.thesamba.com/vw/forum/viewtopic.php?p=7852268
My 56 beetle convertible: http://www.thesamba.com/vw/forum/viewtopic.php?p=7796259
My 60 SO23 westy: http://www.thesamba.com/vw/forum/viewtopic.php?t=341539
Check my blog: http://us-road-trip-vw-bus.skynetblogs.be/
and my garage build thread: http://www.garagejournal.com/forum/showthread.php?t=199438
My other vehicles
KG 64
vespa 1961 Acma & spanish GT 160
2 Lambretta LI 150
2 1971 Honda CT70
BulliBill
BulliBill is offline
PostPosted: Thu Jan 04, 2018 10:06 am    Post subject: Re: Soon to be the second owner of this oval vert Reply with quote
I am so glad you are dumping that narrowed front beam for a return to a stock front end. I was quiet about it, but for me it was glaringly annoying that someone did that to an otherwise incredibly original old vintage Kabriolett. Nice move! That Kab will finally be PERFECT!
I have a long-stored "project" USA spec 1957 Kabriolett awaiting a full restoration, also black with the red interior. You Kab is an inspiration to me, and my Kab is almost at the top of my "to do" list...
Bill Bowman
Cape Girardeau - Adams Volkswagen
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help!
grailoc
grailoc is offline
PostPosted: Thu Jan 04, 2018 12:34 pm    Post subject: Re: Soon to be the second owner of this oval vert Reply with quote
Bill Bowman
Thanks for the words!
It was a matter of time for me to find a front beam with the correct numbers stamped on it between February / early march 1956 production.
I was lucky enough to get it from a friend which did not cost to me that much and was just 2.5 hours away from home to pick-up.
I took the christmas break to put it appart and start degreasing the old stuff.
I was afraid about the rust on it put it just had a little hole on the side that i started work on and needed attention.
I have also made few holes on the arms that receive the top of the chock and the inside structure showed fresh unrusted metal. yeah...!!
it will receive a full sanblast and rust treatmant before patching the little hole I made intentionaly.
Paint should be satin black at the end.
I will post pictures and progress time to time !!
Stay tuned.
/Jerome
My other vehicles
KG 64
2 Lambretta LI 150
2 1971 Honda CT70
grailoc
grailoc is offline
PostPosted: Sat Jan 06, 2018 6:03 pm    Post subject: Re: Soon to be the second owner of this oval vert Reply with quote
Here is clearer pictures of the engine with those great cyclone filters.
So happy to be able to get a set in my hands.
My other vehicles
KG 64
2 Lambretta LI 150
2 1971 Honda CT70
grailoc
grailoc is offline
PostPosted: Sat Jan 06, 2018 6:04 pm    Post subject: Re: Soon to be the second owner of this oval vert Reply with quote
and a picture of the garage:
My other vehicles
KG 64
2 Lambretta LI 150
2 1971 Honda CT70
grailoc
grailoc is offline
PostPosted: Sun Jan 07, 2018 6:18 pm    Post subject: Re: Soon to be the second owner of this oval vert Reply with quote
The bug is on the stand, while rebuilding an original front beam I am going to redo all brakes and drums, sandblast the surface rust and paint what has to be painted satin black.
Wheel bearing will also be changed as well as link pin and king pin.
I also built those custom wood beams that fit the wheel dolies, so I will be able to move the car around.
My other vehicles
KG 64
2 Lambretta LI 150
2 1971 Honda CT70
grailoc
grailoc is offline
PostPosted: Sun Jan 07, 2018 8:47 pm    Post subject: Re: Soon to be the second owner of this oval vert Reply with quote
The beam is now desassembled, and all of the grease inside the tubes has been removed.
My other vehicles
KG 64
2 Lambretta LI 150
2 1971 Honda CT70
grailoc
grailoc is offline
PostPosted: Sun Jan 07, 2018 8:51 pm    Post subject: Re: Soon to be the second owner of this oval vert Reply with quote
the small hole at the top of the arm was to check the inside of the structure and make sure there is no bad corrosion. By chance the metal is still fresh inside but I will inject a treatment to keep it preserved and weld it.
My other vehicles
KG 64
2 Lambretta LI 150
2 1971 Honda CT70
grailoc
grailoc is offline
PostPosted: Sun Jan 07, 2018 8:54 pm    Post subject: Re: Soon to be the second owner of this oval vert Reply with quote
However the portion in between the 2 tubes had more corrosion so I cut a bigger hole I order to remove the rust and get the sandblast gun blast inside it.
After I will put a corrosion treatment and weld a small patch of metal.
My other vehicles
KG 64
2 Lambretta LI 150
2 1971 Honda CT70
grailoc
grailoc is offline
PostPosted: Sat Jan 13, 2018 6:29 pm    Post subject: Re: Soon to be the second owner of this oval vert Reply with quote
I am restauring all of the brake, and the rear right plate seems to be missing the little metal pins that keep the 2 screw in place.
Does anoene know how I can make a repair for that or find this little piece ?
thanks for help.
My other vehicles
KG 64
2 Lambretta LI 150
2 1971 Honda CT70
ProjectX
Accessory Nut
ProjectX is offline
PostPosted: Sun Jan 14, 2018 8:23 am    Post subject: Re: Soon to be the second owner of this oval vert Reply with quote
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=211609185A
Wink
Even my nuts are plated.....
195? Project "X"
1954 Oval Convertible
grailoc
grailoc is offline
PostPosted: Mon Jan 15, 2018 10:54 am    Post subject: Re: Soon to be the second owner of this oval vert Reply with quote
Wink
Thanks I was not aware these little pieces were reproduced.
By the time I just found a set of really good used backing plates with minor rust and complete.
I will post pictures when I get them.
/Jerome
My other vehicles
KG 64
2 Lambretta LI 150
2 1971 Honda CT70
grailoc
grailoc is offline
PostPosted: Sun Feb 04, 2018 8:30 pm    Post subject: Re: Soon to be the second owner of this oval vert Reply with quote
Here are new upates,
today I started to remove the front beam bushing.
Here are some picture of the little tools I have built for that. It did work pretty well.
and after some times:
My other vehicles
KG 64
2 Lambretta LI 150
2 1971 Honda CT70
grailoc
grailoc is offline
PostPosted: Tue Feb 20, 2018 7:44 pm    Post subject: Re: Soon to be the second owner of this oval vert Reply with quote
Here is a collection of few nos parts I put my hands on to redo the link pin king pin and rear backing plates.
Wheel cylinder are NOS with ATE stamping on them, just to it has surface rust while staying on the shelf for years.
My other vehicles
KG 64
2 Lambretta LI 150
2 1971 Honda CT70
grailoc
grailoc is offline
PostPosted: Tue Feb 20, 2018 8:09 pm    Post subject: Re: Soon to be the second owner of this oval vert Reply with quote
I also removed the fuel tank and will perform complete clean up of the front end compartment.
I will probably redo the pading by using horseair in order to keep things clean and as original as possible.
My other vehicles
KG 64
2 Lambretta LI 150
2 1971 Honda CT70
grailoc
grailoc is offline
PostPosted: Sat Feb 24, 2018 2:50 pm    Post subject: Re: Soon to be the second owner of this oval vert Reply with quote
Since the front beam is out I decided to redo the wheel arch protection.
Nasty job to remove the old protection. I am not fully done, but not rust issues so far !!
My other vehicles
KG 64
2 Lambretta LI 150
2 1971 Honda CT70
grailoc
grailoc is offline
PostPosted: Sun Feb 25, 2018 4:33 pm    Post subject: Re: Soon to be the second owner of this oval vert Reply with quote
the wheel arch is now to ground metal.
No rust issue at the end.
Here are the tools I used:
1 and 2 were the most efficient tools without grinding to much the og metal::
My other vehicles
KG 64
2 Lambretta LI 150
2 1971 Honda CT70
grailoc
grailoc is offline
PostPosted: Sun Apr 15, 2018 6:24 pm    Post subject: Re: Soon to be the second owner of this oval vert Reply with quote
some progress guys still removing tar in the front end, I addressed the nose of the frame and the front kick wall:
My other vehicles
KG 64
2 Lambretta LI 150
2 1971 Honda CT70
grailoc
grailoc is offline
PostPosted: Sun Sep 16, 2018 7:46 am    Post subject: Re: Soon to be the second owner of this oval vert Reply with quote
Hi everyone, a long time I do not posted in my thread.
I am looking to continue into the frontend resto and decided to replace the front half of the quarter panel that was damaged somewhere in its life:
Here are picture showing what I am dealing with:
no rust at all just the wraped front end panel that I need to replace.
I have opened a specific thread for that and looking for some advices into finding the proper replacement sheet metal.
https://www.thesamba.com/vw/forum/viewtopic.php?t=706977
thanks in advance anyone for help !!
My other vehicles
KG 64
2 Lambretta LI 150
2 1971 Honda CT70
motofly196
motofly196 is online now
PostPosted: Sun Sep 16, 2018 9:02 am    Post subject: Re: Soon to be the second owner of this oval vert Reply with quote
Are you talking about the wrinkle right underneath where the headlight conduit bolts in, and the buckles above the front beam shock tower area? Looks like hammer and dolly time, maybe a little time with a shrinking file to me. I'd need to see better pictures of what you're talking about, maybe it's worse than what I see?
Page 7 of 7
