Krmnnghia Samba Member
Joined: March 28, 2005 Posts: 797 Location: Michigan, Land of salty roads!
Posted: Sun Apr 15, 2018 5:18 pm Post subject: Trouble with new steering column bearing |
My 62's Steering wheel has had a little up and down play so I figured it was time to replace the bearing. Got the old one out and put the new one in. The new one is W.Zanoni brand. Not sure where I got it but it looks like this:
1. How in the heck do you guys get it to sit completely flush?
2. With it almost flush, I can already tell it has more play than the old one I took out. Did I get the wrong one for a 62 or is this a crappy part?
Thanks |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16754 Location: State College, PA
Posted: Mon Apr 16, 2018 5:41 am Post subject: Re: Trouble with new steering column bearing |
The shaft should fit pretty snug against the inside of the bearing. Does it? _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Mon Apr 16, 2018 5:43 am Post subject: Re: Trouble with new steering column bearing |
After looking into this part I have, it appears it is a part #5002 which is hard to look up but shows its for Type 1 66-77. Did they change the steering shaft in 66 to a slightly larger one? I thought 62-67 all had this same type of setup until they went to plastic in 68.
Here is the box:
