WW Okrasa air filters
MeeferMadness
MeeferMadness is offline
PostPosted: Fri Apr 13, 2018 4:45 pm    Post subject: WW Okrasa air filters Reply with quote
Finally got to the stage of construction on my 59 bug that I could install the deck lid. The engine is a 36 with the WW Okrasa kit. What I have found is that the air cleaner in the right side of the engine will not clear the decklid. I have not heard of any issues from others who have installed this kit. Are both air cleaners the same? Is one supposed to be offset to help clear the lid?
Any advice would be very helpful!!
Thanks
Bruce
mkbug
mkbug is offline
PostPosted: Mon Apr 16, 2018 9:41 am    Post subject: Re: WW Okrasa air filters Reply with quote
I just checked mine again. There isn't a difference the filters opening. Both are centered. My friend Tom is a Denzel guy and he said the bolt on the clamp should be on the outside side. Not that it matters much. I do like that the seam in the mesh is towards the back and you can read the wording on the top.
When installing you do have to bring the decklid down a little to fit the filter in the area.
I'm Martin
My Build: https://www.thesamba.com/vw/forum/viewtopic.php?t=667183
MeeferMadness
PostPosted: Mon Apr 16, 2018 10:30 am    Post subject: Re: WW Okrasa air filters Reply with quote
Thanks. For the reply! Right now the only option I can see is to see if I can raise the decklid a little higher. Not sure if I can without scraping some paint. Judging from the replies I must be the only one that cannot raise the decklid without hitting the aircleaner
Bruce
60ragtop
Bonneville Belt Bitch
60ragtop is offline
PostPosted: Mon Apr 16, 2018 1:28 pm    Post subject: Re: WW Okrasa air filters Reply with quote
Post a pic of engine bay and right carb. My 60 had no problems other than installing the filter, I had to pull close the lid a little as stated to get it on.
Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote:
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote:
maybe he just snapped cause his car sucked Wink
MeeferMadness
PostPosted: Mon Apr 16, 2018 3:13 pm    Post subject: Re: WW Okrasa air filters Reply with quote
A picture of how the right carburetor interferes with the decklid.
Mr. Okrasa Premium Member
Original Old Speed
Location: Eastside, Costa Mesa. So. Califas...Loco's ;-)
Mr. Okrasa is offline
PostPosted: Mon Apr 23, 2018 10:46 am    Post subject: Re: WW Okrasa air filters Reply with quote
I built this engine https://www.thesamba.com/vw/forum/viewtopic.php?t=698240 for a customers 1959 VW Cabriolet and was concerned about deck lid / rain catch clearance.
I modified / offset the passenger side air cleaner and is almost un-noticeable unless you look. Cheers. Mr. Okrasa
See my Instagram: https://www.instagram.com/okrasa/
1959 VW Karmann Ghia Coupe / Bamboo-Green / Denzel 1300cc / OG. owner, paint Wink
Denzel engine running. See this link: https://youtu.be/DgUlsQDTXTE
VW www.Okrasa.com
356 www.PreA356.com
MeeferMadness
PostPosted: Mon Apr 23, 2018 10:51 am    Post subject: Re: WW Okrasa air filters Reply with quote
Can you tell me exactly what you did to modify the air cleaner???
That would be very helpful!
Thanks
Bruce
Original Old Speed
PostPosted: Mon Apr 23, 2018 11:16 am    Post subject: Re: WW Okrasa air filters Reply with quote
Thanks
Bruce
I cut 1/8" around the base/neck of the air cleaner, filled in the rest with same gauge sheet metal, relocated neck and brazed it.
Modification cannot be seen when looking at engine. Simple! Very Happy
VW www.Okrasa.com
356 www.PreA356.com
MeeferMadness
PostPosted: Mon Apr 23, 2018 11:19 am    Post subject: Re: WW Okrasa air filters Reply with quote
VERY HELPFUL! Thank you!
I need just a small offset
Bruce
Braukuche
Braukuche is offline
PostPosted: Wed Apr 25, 2018 12:39 pm    Post subject: Re: WW Okrasa air filters Reply with quote
You can also use elbows.
Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now
