DoozerD Samba Member
Posted: Fri Jul 06, 2007 1:09 am Post subject: Whats the diff between a PICT 30 1 and a PICT30 2 Carb? |
Please and thank you....
Bonus question.
Are they fully interchangable on a 1500 single port H block? The PICT30 1 is the one coming out. |
25horseboxer Samba Member
Posted: Fri Jul 06, 2007 9:15 am Post subject: |
If I remember correctly... The Pict 1 has no Idle stop solenoid, and the pict 2 does. Either way, they will interchange. If you need to you can run a jumper from + side of coil to the solenoid. The difference also may be the # of adjustment screws. Still wont matter on a H case application. |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14271 Location: Casa de Oro, California
Posted: Fri Jul 06, 2007 11:14 am Post subject: |
From my recollection a 30 pict-1 is considered a round-body carb and ended in '67. It was used on the 1500cc engines. The 30 pict-2 is a square-body and came out in '68 with the 1600 single port. They act the same and have the same mounting flange but the square-body is not correct for a 1500 or '67 and earlier. The jets are probably wrong as is, too. I don't really like them as they just plain look wrong. You will find more of them at swaps, probably, and a tune up kit gives you all the gaskets for both. |
rlevans Samba Member
Posted: Fri Jul 06, 2007 11:56 am Post subject: |
Have you checked out the Rob and Dave site?
www.vw-resource.com
They have info on all the various carbs and which ones work best with each dizzy etc.
might help |
Posted: Sat Jul 07, 2007 1:13 am Post subject: |
Cheers all. I found that site after I posted. Its a cracking site and no mistake. Not as good as the Samba natch but... |
Posted: Sat Jul 07, 2007 11:38 am Post subject: |
In the US version Type 1, the 1500 was the only choice between 67 and 70. 1600 didn't arrive until the Dual port 71. As far as post 67 did they get 1600 singleports in type 2? |
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
Posted: Sun Jul 08, 2007 5:46 am Post subject: |
25horseboxer wrote: |
1970 model year was a 1600 single port engine in the united states. it used a large port inside the shroud oil cooler that is 1 year only and had a 30pict-3 carb. 1967 thru 1969 was a 1500 single port in usa while 1971 onwards was a dual port in type 1. _________________ Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617 |
BarryL Samba Member
Posted: Sun Jul 08, 2007 11:54 am Post subject: |
25horseboxer
The "B" block came on the first Bay windows starting in '68 and was a 1600 with a square body 30 pict-2 single port, inside cooler, till 71 came out with the dual-port and doghouse cooler. Those had 34 picts I think. |
swiss_bulli Samba Member
Joined: February 17, 2017 Posts: 123 Location: Switzerland
Posted: Tue Apr 17, 2018 1:00 am Post subject: Re: Whats the diff between a PICT 30 1 and a PICT30 2 Carb? |
Hi
According to the parts manual, the PICT30-2 carburator would be the correct for a 12V 1967 bus: http://oacdp.org/5867part/117.png
As I read on here that the PICT30-1 is the correct, I'm confused now . I'm trying to get my engine back to the factory specs. What is now "right"?
Thanks
Nick |
easy e Samba Member
Joined: May 28, 2008 Posts: 3931 Location: 1 hr north of Santa Barbara
Posted: Tue Apr 17, 2018 5:33 am Post subject: Re: Whats the diff between a PICT 30 1 and a PICT30 2 Carb? |
See the left side of this page.... from the "Technical" tab >> "Technical Bulletins" >> "Engine and Clutch (M Series)"
And if you really want to get nutty... paste this into a google search:
members.trainorders.com/android/temp/CarbBaseFlangeNumbersA.doc
_________________ aka: Evan
Searchable, click-navigable 1958 Bus Parts List |
Posted: Tue Apr 17, 2018 6:13 am Post subject: Re: Whats the diff between a PICT 30 1 and a PICT30 2 Carb? |
Thank you easy-e.
I thought, I can use the parts manual as reference for the things I need, but it looks like I can't. Does it mean, that VW mentions the newest revision in the list, which could be used with that combination and therefore it doesn't need to be the normally delivered equipment? So in this example, 30-2 is the latest part which fits on a 44hp engine, but normally it was delivered with a 30-1? |
easy e Samba Member
Posted: Tue Apr 17, 2018 7:31 am Post subject: Re: Whats the diff between a PICT 30 1 and a PICT30 2 Carb? |
I usually look as many different places as I can, when I'm trying to find something out. Then, see what makes the most sense.
Andy (member Glutamodo) is a well respected member and has put a lot of time into developing two valuable resources.
1) members.trainorders.com/android/temp/CarbBaseFlangeNumbersA.doc
2) https://www.thesamba.com/vw/archives/manuals/Bosch_Tune_Up_Parts/Bosch_Tune_Up_Parts.pdf
Both of these resources (and the parts list) point to a 44 bhp '67 bus having a distributor of 131905205.
The carburetor that is designed to work well with this distributor is the 30 PICT-1.
Sometimes there are details in the parts list that are difficult to discern and not always applicable 100% of the time. _________________ aka: Evan
Posted: Tue Apr 17, 2018 9:56 am Post subject: Re: Whats the diff between a PICT 30 1 and a PICT30 2 Carb? |
That‘s awesome information, thank you! |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Tue Apr 17, 2018 6:00 pm Post subject: Re: Whats the diff between a PICT 30 1 and a PICT30 2 Carb? |
Carburetor distributor
Solex 30 PICT 1 131 905 205
113 905 205 K
Solex 30 PICT 2 113 905 205 M
You could also run a Garbe Lahgmeyer distributor with either
of those carburetors and be correct. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
