67ctbug Samba Member
Posted: Tue Apr 11, 2017 11:33 am Post subject: Pan/ Napoleon hat to Body Bolts |
I'm making progress in the resto. I'm trying to bolt the body together and every one of the new bolts fit except the front ones that go through the napoleons hat. They seem way to big to fit and I can't even bolt them done so I'm having trouble getting the body to sit flat. Any one else have this problem? What should I do. They are the deluxe channels from CIP1 and the bolts are new from Johns Car Corner. _________________ '67 Beetle L41
'74 Westfalia
'69 Plymouth "Adam-12"
'63 Ragtop
'73 914
'73 Dodge W200
'72 Dodge Wrecker
Go Cubs!
World Series Champions 2016
KentPS wrote: |
mukluk wrote: |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17962 Location: Eugene, OR
Posted: Tue Apr 11, 2017 2:41 pm Post subject: Re: Pan/ Napoleon hat to Body Bolts |
Weld or braze new nuts inside the new heater channels in the correct locations to match John's bolts? _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Tue Apr 11, 2017 2:47 pm Post subject: Re: Pan/ Napoleon hat to Body Bolts |
How would I go about doing that? Is there anything else I could do? _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'73 Dodge W200
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Dodgy Samba Member
Joined: January 30, 2006 Posts: 513 Location: Leicester, UK
Posted: Wed Apr 12, 2017 3:59 am Post subject: Re: Pan/ Napoleon hat to Body Bolts |
It's a '67 standard. _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'73 Dodge W200
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
beetlenut Samba Member
Posted: Wed Apr 12, 2017 5:02 am Post subject: Re: Pan/ Napoleon hat to Body Bolts |
First, during repair, did you test fit the bolts into their captive nut plates to ensure they were the correct ones for that nut plate? Did you secure the nut plates in such a way as they could move side to side, but not move up and down? It should just be a matter of inserting the bolts up through the Napoleon's hat, and locating the threaded nut plates, and getting them started. You may have to jack the front of the car slightly to give you room to move the bolts around to locate the nut plate threads. _________________ scrapyards are for quitters
Wetstuff wrote: |
... I spend more time shaking it than directing it?! I get a pretty decent blast for 8sec. then have to shake it again. |
- Words to live by right there!
My 74 Super rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6507104#6507104 |
Posted: Wed Apr 12, 2017 10:18 am Post subject: Re: Pan/ Napoleon hat to Body Bolts |
Beetlenut, if you are talking about the nuts in the heater channel then they are too small to accept the bolt. The bolts came in a box and the only ones that aren't the 13 mm ones go fine trough the napoleons hat , but they can't go through the nuts in the channel. Currently the channel is bolted to the pan only because I'm replacing them so th old one is gone and the channel is free to move. _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'73 Dodge W200
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Posted: Wed Apr 12, 2017 11:46 am Post subject: Re: Pan/ Napoleon hat to Body Bolts |
67ctbug wrote: |
Beetlenut, if you are talking about the nuts in the heater channel then they are too small to accept the bolt. The bolts came in a box and the only ones that aren't the 13 mm ones go fine trough the napoleons hat , but they can't go through the nuts in the channel. Currently the channel is bolted to the pan only because I'm replacing them so th old one is gone and the channel is free to move. |
The nut plate for those two Napoleon's hat bolts looks like this:
For the Supers, that nut plate lives in the bottom corners of the front firewall. For the standard beetles, I think it lives in the front part of the heater channel, or in the space forward of the end of the heater channel. What's directly above the two holes in the end of the Napoleon's hat? _________________ scrapyards are for quitters
Wetstuff wrote: |
Posted: Wed Apr 12, 2017 11:48 am Post subject: Re: Pan/ Napoleon hat to Body Bolts |
When the body is not on, there is nothing above the two holes. When the body gets set down then its the bottom plate of the heater channel and then inside the channel is the nut plate. The nut plate is unable to be removed without cutting though. _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'73 Dodge W200
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Posted: Wed Apr 12, 2017 12:12 pm Post subject: Re: Pan/ Napoleon hat to Body Bolts |
67ctbug wrote: |
When the body is not on, there is nothing above the two holes. When the body gets set down then its the bottom plate of the heater channel and then inside the channel is the nut plate. The nut plate is unable to be removed without cutting though. |
Yes the nut plate lives up in the body, like the pic below.
So when the body is not on, can you thread the two new bolts into that nut plate? If so, then you just need to do that through the bottom of the Napoleon's hat when the body goes back on. If the nut plate is damaged, or those new bolts will not fit, you'll need to replace that nut plate with something new by cutting an access hole into that area from the wheel well side, and welding up once replaced. Those are really your only two options to affect that repair. _________________ scrapyards are for quitters
Wetstuff wrote: |
Posted: Wed Apr 12, 2017 12:14 pm Post subject: Re: Pan/ Napoleon hat to Body Bolts |
I can't get the bolt to fit even when the channel is disconnected. I guess i'll have to cut it. Is this a normal problem with these channels? _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'73 Dodge W200
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Posted: Wed Apr 12, 2017 12:30 pm Post subject: Re: Pan/ Napoleon hat to Body Bolts |
67ctbug wrote: |
I can't get the bolt to fit even when the channel is disconnected. I guess i'll have to cut it. Is this a normal problem with these channels? |
Can you see the nut plate up in there when the body is raised up? Can you see the threaded holes? Yes, usually everything up in there rusts and fuses together into one big blob. Once you cut an access in to that area and get the old nut plate out, you'll more clearly see what you're dealing with. Cut a square opening with the top still attached, and bend the door up to access that area. I ended up making my own nut plates for my problem area.
Wetstuff wrote: |
Posted: Wed Apr 12, 2017 12:34 pm Post subject: Re: Pan/ Napoleon hat to Body Bolts |
It's not exactly easy getting under the car now that I've put if back on the chassis, but if I put the bolt through the nap hat, I can find the nut plate. The nap hat and channels are new so no rust. When you say door, do you mean cut the square only on three sides and bend it? _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'73 Dodge W200
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Posted: Wed Apr 12, 2017 1:31 pm Post subject: Re: Pan/ Napoleon hat to Body Bolts |
Well I feel like an idiot. I just got the bolts in by lining it up better _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'73 Dodge W200
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Posted: Wed Apr 12, 2017 6:36 pm Post subject: Re: Pan/ Napoleon hat to Body Bolts |
67ctbug wrote: |
Well I feel like an idiot. I just got the bolts in by lining it up better |
Better to feel like an idiot and have success, than having another chore standing in your way preventing success. Those floating nut plates can be a pain to locate to get the first bolt started. _________________ scrapyards are for quitters
Wetstuff wrote: |
Posted: Wed Apr 12, 2017 7:26 pm Post subject: Re: Pan/ Napoleon hat to Body Bolts |
beetlenut wrote: |
Better to feel like an idiot and have success, than having another chore standing in your way preventing success. |
Very true, now to solve my body sitting on the pan issue... _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'73 Dodge W200
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Posted: Mon Apr 09, 2018 12:22 pm Post subject: Re: Pan/ Napoleon hat to Body Bolts |
Resurrecting my thread after nearly 1 year dead, the bolts are actually not fitting... I think I'm going to go to the hardware store and get new bolts. _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'73 Dodge W200
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Nickgreen949 Samba Member
Joined: January 29, 2013 Posts: 32 Location: Laguna Beach
Posted: Tue Apr 17, 2018 9:30 am Post subject: Re: Pan/ Napoleon hat to Body Bolts |
Sounds like you’re having the same problem I had with my Klassicfab heater channel. The front ‘captive nut/plate’ was too small to accept the 10mmx1.50 bolts. The smaller 8mm bolts for the rest of the pan were too small and the 10mm bolts were too big. It seemed like it was taped for a 9mm bolt. I ended up drilling them out and taping them to accept the 10x1.50 bolts like the originals. Luckily I caught this before anything was welded so I was able to do it on the bench. Much easier! Especially since you have to hold the plate still while drilling and taping.
Good luck! |
BIGMIKEY Samba Member
Joined: September 24, 2007 Posts: 1102 Location: North East Pennsylvania
Posted: Tue Apr 17, 2018 2:55 pm Post subject: Re: Pan/ Napoleon hat to Body Bolts |
To make it easier to start the bolts try threading the stub end of an old bolt into the nut plate. This provides a guide as well as a handle to hold the nut plate steady while you thread in the other bolt.
Mike T _________________ BIGMIKEY
Deserter Series 1 project.
https://www.thesamba.com/vw/forum/viewtopic.php?t=787047&highlight=
1973 Beetle Driver, Marina Blue. |
Posted: Wed Apr 18, 2018 11:21 am Post subject: Re: Pan/ Napoleon hat to Body Bolts |
67ctbug wrote: |
Resurrecting my thread after nearly 1 year dead, the bolts are actually not fitting... I think I'm going to go to the hardware store and get new bolts. |
So the captive nuts were probably not tapped for 10x1.5 bolts. You can either try and figure out what they are tapped for, and get bolts for that size, or cut out the nut plate and get or make the correct one and put it in. That's why I made mine. I just got some bolts with corresponding nuts. That way I knew they would go together when the time came. _________________ scrapyards are for quitters
Wetstuff wrote: |
