Am I Missing Something Here? - Vent Window Latches
carnut63
carnut63 is offline
PostPosted: Wed Apr 18, 2018 2:54 pm    Post subject: Am I Missing Something Here? - Vent Window Latches Reply with quote
Original 55 frames but the latches are 56+ CIP repros. The latches seem too wide for the frame.
I would get them from WW but I'm afraid they are probably the same supplier.
Tyson
---> Mar 2 1955 Strato Silver Oval <---
---> July 1957 ragtop project <---
---> May 5 1966 Ghia <---
---> 1962 Ruby Red Deluxe (sold)
Zwitterkafer
Zwitterkafer is offline
PostPosted: Wed Apr 18, 2018 3:31 pm    Post subject: Re: Am I Missing Something Here? - Vent Window Latches Reply with quote
IIRC the pre-56 frames are indeed narrower than the '56 and up frames, at the latch positions. To assess the repro latch, can you test fit it into a later frame to see if it fits there?
- Zeuxius, 400 BC
carnut63
carnut63 is offline
PostPosted: Wed Apr 18, 2018 5:06 pm    Post subject: Re: Am I Missing Something Here? - Vent Window Latches Reply with quote
Well that's lame because everything I read said they were interchangeable.
Tyson
carnut63
carnut63 is offline
PostPosted: Thu Apr 19, 2018 2:23 pm    Post subject: Re: Am I Missing Something Here? - Vent Window Latches Reply with quote
Well nothing a little grinding and a rubber mallet couldn't fix.
Tyson
janerick3
janerick3 is offline
PostPosted: Thu Apr 19, 2018 6:45 pm    Post subject: Re: Am I Missing Something Here? - Vent Window Latches Reply with quote
The '56-up latches are thicker because the '53-'55 latches tend to break just by looking at them. The thicker bases fit the earlier frames without any alterations. You may need thinner gaskets between the base and the glass, though. The earlier and later handles can be swapped, as the tangs are quite different, as well as the handle (ribbed vs non-ribbed) and the push button (rounded vs squared off).
Thanks,
Jan K.
