Lincolnlife Samba Member
Joined: January 24, 2018 Posts: 26 Location: Winston salem
Posted: Wed Apr 18, 2018 6:31 pm Post subject: 30 pict 2 question |
Just rebuilt my 30 pict 2 and it wont idle down when i turn the screw on the left with the spring around it. It does nothing. Sorry i dont know the name of it off hand but the internet has lead me to believe that it only has 2 screws and one is sealed so you cant change. It runs good just idles high. If i could idle it down id be happy. And no its not running crazy high where it seems like shes going to blow. Wondering if any one else has had this problem. Thanks |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24732 Location: Olympia Wash Rinse & Repeat
Posted: Wed Apr 18, 2018 7:49 pm Post subject: Re: 30 pict 2 question |
Could be the pilot or main jet are way TOO BIG. Also is the choke wide open?? _________________ In Stereo, Where Available! |
Posted: Thu Apr 19, 2018 5:06 am Post subject: Re: 30 pict 2 question |
Yes the choke is open. If i close it it just gets higher. Btw its on a 1600cc dual port. But idle is steady just high. Some one on the site posted about a way to adjust on top the bowl but i see no screw. Idk if you had any idea about that. But hey thanks for responding |
Sharp64 Samba Member
Joined: August 27, 2015 Posts: 5304 Location: Central Florida
tonys1pr Samba Member
Joined: September 03, 2015 Posts: 44 Location: Detroit, Michigan
Posted: Thu Apr 19, 2018 6:44 am Post subject: Re: 30 pict 2 question |
Just a thought, Is there enough slack in the accelerator cable to actually allow the throttle to close further and reduce the idle speed? |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31360 Location: Hot Arizona
Posted: Thu Apr 19, 2018 7:08 am Post subject: Re: 30 pict 2 question |
tonys1pr wrote: |
Yes - disconnect the attachment at the carb and make sure. Also - is the spring strong enough to close the throttle arm? How about some photos.
And what year is yours? Earlier models had different type of return spring design. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Thu Apr 19, 2018 8:02 am Post subject: Re: 30 pict 2 question |
I will get more pics when i get home. Im at work but yes the throttle cable is unhooked and ill check the spring tonight along with some pics. Thanks |
glutamodo The Android
Joined: July 13, 2004 Posts: 26307 Location: Douglas, WY
Posted: Thu Apr 19, 2018 2:27 pm Post subject: Re: 30 pict 2 question |
Sounds this could be the reason I won't use the 30PICT-2, it contained a new emissions modification of having locked-in-place metering screw that prevents proper cleaning and any gunk in will muck up the idle circuit. I'll take a 30PICT-1 any day over it. _________________ Andy T.
Posted: Fri Apr 20, 2018 5:07 am Post subject: Re: 30 pict 2 question |
I looked over the stuff sharp 64 gave me and i believe i have it fixed. The biggest help seemed to be actually turning the air correction jet. It is idling perfectly now. Fingers crossed tho. |
Posted: Sun Apr 22, 2018 4:03 pm Post subject: Re: 30 pict 2 question |
The air correction jet, really? Never heard of that one before, while it occupies the passenge that the fuel for the idle circuit is drawn, it should be centered and not affect the idle in any way (its function are more at higher RPM). Or did you mean the idle fuel (pilot) jet? Now that is a known problem, needing to loosen it to allow the idle circuit of flow, and an issue that I've certainly encountered but have never been able to understand why it happens. I'm well known for drawing diagrams illustrating technical details, but not for this, as I've never been able to figure out why a pilot jet could "pinch off" when properly tightened. But it does happen! _________________ Andy T.
