KCh30allener Samba Member
Joined: January 25, 2015 Posts: 6 Location: Meadville PA
Posted: Wed Apr 18, 2018 10:08 am Post subject: Rewiring '73 Super |
New wiring harness does not have grey with black stripe wire from dash (fuse number 10?) and brown with black stripe running to dash and to mid car???? I cannot locate either on wiring diagram. ? Rear window defrost? Also need relay for rear window defrost (old one drown). |
sb001 Samba Member
Posted: Wed Apr 18, 2018 11:30 am Post subject: Re: Rewiring '73 Super |
I think these wires are for intermittent wipers. Take a look at the "additional wiring" diagram for 1973 here:
The diagram shows two gray/ black stripe wires coming off fuse #10, one goes to the wiper motor and the other to the intermittent wiper switch.
The brown/ black stripe wire also pertains to the intermittent wipers, it goes from the intermittent wiper switch to the intermittent wiper relay. _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
green1303 Samba Member
Joined: February 04, 2014 Posts: 748 Location: Alexandria, VA
Posted: Thu Apr 19, 2018 4:15 am Post subject: Re: Rewiring '73 Super |
The Wiring Works wiring harness does not have wires for the seat belt warning system (brown/black to front seats and small red/black to transmission). After replacement, the large wiring connector in your dash will have six wires on the main harness side rather than eight. The gray wires are tail lights, although the stripes may not match.
Here’s the OEM defrost relay for under the rear seat.
https://www.bughaus.com/relay_0332019150.htm _________________ 1973 green Super Beetle |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15987 Location: North Florida, USA
Posted: Thu Apr 19, 2018 9:40 am Post subject: Re: Rewiring '73 Super |
Actually, the two black/grey wires coming from the fuse have two slightly different purposes:
1) wire to wiper switch controls low/high or intermittent speed and this current is passed to the wiper motor to control the speed.
2) this wire that runs directly to the wiper motor allows the motor to continue running even after the switch is turned OFF. The power coming from the switch stops immediately when turned OFF but the motor will continue to operate until the arms return to the parked position. In the park position the current from this second wire is disrupted so the motor stops with the wiper arms parked. Without this wire the wipers will stop in the middle of the windscreen! _________________ AshMan40
79bugman Samba Member
Joined: February 06, 2010 Posts: 279 Location: NEW JERSEY, USA
Posted: Thu Apr 19, 2018 6:02 pm Post subject: Re: Rewiring '73 Super |
KCh30allener
you got ASHMAN40.....
do as he says and all will be fine my friend. |
Posted: Fri Apr 20, 2018 10:18 am Post subject: Re: Rewiring '73 Super |
KCh30allener wrote: |
New wiring harness... |
Obvious question... did you buy the correct wiring harness for your car? Check the description on the packaging to make sure you weren't sent the wrong harness. If you bought it online can you post the link?
The harness for a SB will be different from a STD Beetle.
... does not have grey with black stripe wire from dash (fuse number 10?) |
Did your new harness come with the wiper switch plug that connects to the wiper switch pegs under the steering column? '73 SB would have come w/ a steering column wiper switch. What are the wire colors for the plug? Maybe your new harness is using different colored wires?
I find it strange that you are asking about a colored wire that your new harness DOES NOT have? Normally I'd expect a question like, "I have an extra pink/yellow wire and I don't know where it goes?" Or something like, "Nothing connects to my wiper switch. Which of these extra colored wires goes to the wiper switch?"
You mentioned grey/black wires from fuse #10, sb001 assumed your were asking about wiper switch/motor wiring based on the fuse and wire colors. If your harness has other colored wires dedicated for the wiper switch/motor we should be focusing on getting these correctly connected.
... and brown with black stripe running to dash and to mid car???? |
Again, you are asking about a wire that you DON'T HAVE. Should we be instead chasing a wire you DO HAVE and trying to figure out how it should be connected?
Please confirm which wiring diagram you are using? The one from this site (below)?
Or are you using a diagram provided with the wiring harness? Have you compared the diagrams? Many of the ones that come with the harness are very basic and may not actually match the OE harness and colors may be different. I saw one that was clearly hand drawn. Nothing wrong with hand drawn as long as the diagram correctly wires things together. Using the wrong colored wirers can make its VERY difficult to communicate what connects to what and later troubleshoot problems because you have not common diagram to work from. _________________ AshMan40
Posted: Tue May 01, 2018 10:34 am Post subject: Re: Rewiring '73 Super |
Thanks to all. It was seat belts and taillights....wipers were fine _________________ 1968 Beetle
1973 Super beetle Sedan x 2
1973 Thing
1979 Super Beetle CVT |
Posted: Tue May 01, 2018 10:44 am Post subject: Re: Rewiring '73 Super |
TO answer a few questions:
Yes, the harness was for a super, and came from JBUGS. Their technical folks tried to help, to no avail. I believe the wiring harness was original in the car, based on the appearance, coating, and connectors. And yes, it was missing wires. One for the block under the dash and one to the fuse panel. Seat belt alarm is off. Rear defrost was on new harness. Wiring diagram under the seat was helpful. Thanks to green1303. The wiring diagram provided was hand drawn and less than helpful. I do have the factory color drawing, but it is difficult when the wires are not present.
I have everything working, but waiting on a new relay for the rear defrost and I need to wire seat belts. Thanks again! _________________ 1968 Beetle
1973 Thing
