Neonist Samba Member
Joined: March 24, 2016 Posts: 98 Location: San Antonio, TX
Posted: Thu Apr 19, 2018 7:33 pm Post subject: Re: 65 Single Cab revival. Purist You may want to stay away.. |
Mother In Law coming for a few days so I had to move these out of the back room..
Posted: Sat Apr 28, 2018 7:51 pm Post subject: Re: 65 Single Cab revival. Purist You may want to stay away.. |
This is the AC condenser and one of the intercooler heat exchangers. These will be covered by the backside of the air ductwork.
A nice shot of the under side
Another shot of the underside and the Oil pan.
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 3439 Location: San Diego
Posted: Sat Apr 28, 2018 9:07 pm Post subject: Re: 65 Single Cab revival. Purist You may want to stay away.. |
Looks good, how soon before U can drive it? |
Posted: Sun Apr 29, 2018 7:03 pm Post subject: Re: 65 Single Cab revival. Purist You may want to stay away.. |
chrisflstf wrote: |
Its getting closer.. More than likely will take me a month to wire. It needs some paint rework on the cab. If I had to put a date on it I'd put it late July to early August. It does have to go to Vegas for SEMA in late October so any out and about will be minimal. Any shows it goes to before that will be loaded in an enclosed trailer. |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14257 Location: Casa de Oro, California
Posted: Mon Apr 30, 2018 9:31 am Post subject: Re: 65 Single Cab revival. Purist You may want to stay away.. |
Neonist wrote: |
This is...one of the intercooler heat exchangers. |
Nice thick cool air to ram down it's throat.
Neonist wrote: |
...shot of the underside and the Oil pan. |
Did you cast that? Looks bulletproof. |
Posted: Wed May 02, 2018 4:24 pm Post subject: Re: 65 Single Cab revival. Purist You may want to stay away.. |
BarryL wrote: |
Neonist wrote: |
Neonist wrote: |
Pan Is From Small Car. Apparently the EG33 is a popular Vanagon swap.
I had planned on going dry sump but once I calculated it all up would be over 4K to make it all work.
I went liquid intercooler because I could drop the charge air temps 5deg below ambient. With the intake I built the intercoolers are built inside of it allowing me to run two small bar and plate intercoolers, one for each bank. Very low pressure drop and heat soak is dramatically reduced due to a cooled intake. |
Posted: Sat May 12, 2018 8:03 pm Post subject: Re: 65 Single Cab revival. Purist You may want to stay away.. |
This is my replacement for the factory defroster tube. This pipe has been split in half and a divider welded in so that both air for the dash vents and defrost ducts can be fed from the VintageAir unit. On the underside the ductwork moves thru an cavity built into the floor.
tootype2crazy Samba Member
Joined: October 08, 2007 Posts: 1276 Location: St. Louis Missouri
Posted: Sun May 13, 2018 6:05 am Post subject: Re: 65 Single Cab revival. Purist You may want to stay away.. |
Very very cool project. Can I ask where you sourced that bevel box for your steering set up? I'm thinking about doing something similar on my sc and can't find a good option. _________________ air-cooled or nothing for me
1978 Sunroof Deluxe Bus (daily driver)
1978 Transporter (mom's, making into a camper)
1970 Single Cab 2.1 turbo/EFI 6 Rib, 78 front beam, vanagon backing plates on rear (project)
2001 GTI VR6 (wife's) |
Posted: Sun May 13, 2018 8:07 am Post subject: Re: 65 Single Cab revival. Purist You may want to stay away.. |
tootype2crazy wrote: |
Very very cool project. Can I ask where you sourced that bevel box for your steering set up? I'm thinking about doing something similar on my sc and can't find a good option. |
This box came from a honda passport. The steering shafts came from a honda s2000. I had to weld a joint onto the shaft to mate up to the Appleton rack. There is a VW variant of this if you can find them. I found one in the UK from a mid 2000s van. Had it shipped over and ended up being bad. |
swharris Samba Member
Joined: September 10, 2010 Posts: 496 Location: N. Orange County
Posted: Mon May 14, 2018 9:28 am Post subject: Re: 65 Single Cab revival. Purist You may want to stay away.. |
Neonist wrote: |
chrisflstf wrote: |
Its getting closer.. More than likely will take me a month to wire. |
What ECU are you going to run? Subbi or a stand-alone? What type of boost and hp to you expect? |
Posted: Mon May 14, 2018 12:52 pm Post subject: Re: 65 Single Cab revival. Purist You may want to stay away.. |
swharris wrote: |
Neonist wrote: |
chrisflstf wrote: |
I am running a Haltech elite 2500. With a WB-2 to run dual wideband O2 sensors. Planning on starting with 5 to 6lbs of boost and working up from there. Bottom end should be able to handle 14 to 15 and with the engine protection the haltech has it shouldn't be a problem. At 5lbs I should see around 375 at the rear and 450 at the 12lbs mark. I'm thinking 375 should be plenty for this truck. But it does give me room to move if the truck will handle power. Boost control is also handled by the haltech. Turbos are good for 385 each so more than enough turbo. |
Posted: Fri May 25, 2018 12:15 am Post subject: Re: 65 Single Cab revival. Purist You may want to stay away.. |
Sounds great! Yes that should be plenty of power lol. |
Pacmanfever Samba Member
Posted: Fri May 25, 2018 7:55 am Post subject: Re: 65 Single Cab revival. Purist You may want to stay away.. |
Amazing fabrication and problem solving displayed, looking forward to seeing it all finished. |
rustybus Shasta Snow Trip Newt
Joined: November 24, 2002 Posts: 919 Location: Arizona
Posted: Fri Jun 29, 2018 9:04 am Post subject: Re: 65 Single Cab revival. Purist You may want to stay away.. |
The engineering on this thing is badass! I'm a purist for the most part, but appreciate a good custom when it is made from something that is already messed up, not a good original paint car, and that was exactly the case here, nice job taking a parts car and making something cool. I have a bunch of bus parts, an SVX engine, and an idea for what I'd like to build out of it all, but it won't be anything like this, that's for sure and at the snail's pace I work at, best case scenario won't be done in the next decade. But who knows, threads like this inspire me to get out and work on stuff. I just got a bus back on the road in two weeks that had been parked for over 20 years. Went through all the stock systems on that, so maybe there is hope.
Can't wait to see this on the road. If you make it to Arizona shoot me a message, I'd love to shoot a feature on this.
Richard _________________ Richard
www.rustybus.com www.shastasnowtrip.com |
Posted: Mon Jul 02, 2018 6:44 pm Post subject: Re: 65 Single Cab revival. Purist You may want to stay away.. |
Wiring is so tedious. So the engine component is all finished as well as all the plumbing and mechanicals on the engine. Im hopeful that the rest of the truck goes smoothly.
Thank you all for the comments!! |
Posted: Tue Jul 03, 2018 6:52 am Post subject: Re: 65 Single Cab revival. Purist You may want to stay away.. |
With the addition of A/C I don't need the overhead fresh air system. I also didn't want to cut into the dash of this truck as it is one of the very few parts that was salvageable from the original truck. I utilized the area in the overhead fresh air system to build a custom LCD screen that will provide me with the gauges I wasn't going to be able to put in the dash. Below is what the display will show. The Haltech ECU has an interface that will push data onto this image and animate this gauge. I will post a video up once I have it up and going.
Black hound Samba Member
Posted: Sun Jul 29, 2018 12:13 pm Post subject: Re: 65 Single Cab revival. Purist You may want to stay away.. |
Looks and sounds epic sir! 10 out of 10 for this build. |
matthew henricks Samba Member
Joined: January 02, 2002 Posts: 1219 Location: So. Cal
Posted: Mon Jul 30, 2018 6:45 am Post subject: Re: 65 Single Cab revival. Purist You may want to stay away.. |
Nice. |
Posted: Tue Aug 07, 2018 11:56 am Post subject: Re: 65 Single Cab revival. Purist You may want to stay away.. |
Very cool, can't wait to see it on the road. _________________ Richard
