ChapinBusDude Samba Member
Joined: June 25, 2013 Posts: 131 Location: South Carolina
Posted: Sun Apr 15, 2018 8:23 pm Post subject: '73 Thing Brakes Question |
Can anyone send me a link to a diagram of the front and rear brakes? I'm especially looking for the position of the big spring and the little spring that go between the shoes.
Does anyone know which bolt is correct for attaching the wheel cylinders to the backing plates? |
JayC Samba Member
Posted: Mon Apr 16, 2018 11:24 am Post subject: Re: '73 Thing Brakes Question |
Hope these help:
Front
Rear
As far as bolts, I believe they are M8x1.5.
If you don't have it, the VW Thing Service Manual and parts manual under the Technical Section of the site is a huge help!
jay |
Posted: Mon Apr 16, 2018 12:50 pm Post subject: Re: '73 Thing Brakes Question |
Thanks Jay! |
germanbilly Samba Member
Joined: October 18, 2013 Posts: 378 Location: Victorville
Posted: Mon Apr 16, 2018 2:41 pm Post subject: Re: '73 Thing Brakes Question |
In the book How to Keep your VW Alive and in the Type 181 parts manual they show the Big Spring going under the Brake Cylinder. Here is a picture showing the correct placement.
GB
[/img] |
Posted: Mon Apr 16, 2018 3:12 pm Post subject: Re: '73 Thing Brakes Question |
Hmmm, the bigger spring on the wheel cylinder side. Higher tension on that side. That kind of makes some sort of sense. It has to push the brake fluid back into the MC. |
74 Thing Samba Member
Posted: Mon Apr 16, 2018 7:22 pm Post subject: Re: '73 Thing Brakes Question |
Yes, larger spring by the wheel cylinder. |
Joined: February 21, 2003 Posts: 868 Location: Clifton Park NY Saratoga County
Posted: Tue Apr 17, 2018 3:40 am Post subject: Re: '73 Thing Brakes Question |
The bolt size for the wheel cylinder is actually m8X1.25 _________________ Michael Basso
http://www.thingparts.com
New and Used VW Thing Parts Free advice
CALL 518 630 0173 |
Posted: Tue Apr 17, 2018 6:35 am Post subject: Re: '73 Thing Brakes Question |
Thanks guys! |
Posted: Tue Apr 17, 2018 6:50 am Post subject: Re: '73 Thing Brakes Question |
Posted: Fri Apr 20, 2018 3:34 pm Post subject: Re: '73 Thing Brakes Question |
Another question about the rear brakes this time guys, well it actually a general VW brakes observation and question.
The connecting bar that levers the hand brake. When I install it with the "dimple" down, it makes contact with the backing plate retention bolts. When I try to center the shoes to make clearance for the drum to fit, when I tap the shoe that is messing up the clearance down (tap, tap, tap), the connecting bar levers the other shoe up because it is touching the backing plate bolts. This makes the other side keep the drum from fitting on. Does the connecting bar "dimpled" side go up or down?
Looks like I have two connecting bars from the same side. One ends up with the dimple pointing up and clears the backing plate bolts while the other side has to have the dimple pointing down and gets in the way like this. I guess I could grind off the dimple enough to make things work, or I could find another one that is situated for the clearance. What is right?
Picture coming next...... |
Posted: Fri Apr 20, 2018 3:37 pm Post subject: Re: '73 Thing Brakes Question |
Posted: Fri Apr 20, 2018 9:13 pm Post subject: Re: '73 Thing Brakes Question |
Here is a picture of the Rear Brake installed, hope this helps.
GB
