Body lift welding
Buzzfagan
Buzzfagan is offline
PostPosted: Fri Apr 20, 2018 9:04 pm    Post subject: Body lift welding Reply with quote
Anyone have any suggestions as to how to fill these metal voids back in. Making a body lift kit that I had to make some bends in the steel for a dune buggy and using 11 ga steel tubing and cut 2” x 1 /1-2”, 2” x 1” and going to have to do some 2” x 2” for the main frame.
What would be the best way to mend these seams back together? Just can’t imagine doing it without some sort of filler. Any recommendations? Using a Lincoln Mif 180 for the work.
Dale M.
Dale M. is offline
PostPosted: Fri Apr 20, 2018 9:14 pm    Post subject: Re: Body lift welding Reply with quote
You could lay a piece of flat stock along outside edge of bend and just weld each "leg" to flat stock and seal any gaps up with RTV....
Dale
“Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
slalombuggy
slalombuggy is offline
PostPosted: Fri Apr 20, 2018 9:56 pm    Post subject: Re: Body lift welding Reply with quote
I would tack weld them near the bottom of the "V" of each cut to hold the curved shape. Then I would cut some 20ga sheet metal to cover the wide outside of the curve and cap the sides.
Or you could burn a spool of wire and a couple bottles of mig gas and weld them all up. The might hold their shape.......
brad
cdnltded
cdnltded is offline
PostPosted: Sat Apr 21, 2018 12:07 am    Post subject: Re: Body lift welding Reply with quote
Turn the pieces owner so you collapsed the cuts not expand them.
I did as above on mine and didn’t use to much wire.
Check it out on my build thread. My project doom buggy
gtrplyr
gtrplyr is offline
PostPosted: Sat Apr 21, 2018 6:49 am    Post subject: Re: Body lift welding Reply with quote
I concur with cdnltded, not that it is required, but the piece will be stronger than with the cuts being on top. Good luck on your build.
Dale M.
Dale M. is offline
PostPosted: Sat Apr 21, 2018 6:57 am    Post subject: Re: Body lift welding Reply with quote
Forget what I said earlier, this makes more sense....
Dale
vwracerdave
vwracerdave is offline
PostPosted: Sat Apr 21, 2018 8:08 am    Post subject: Re: Body lift welding Reply with quote
I'd throw that hodge-podge piece of shit pie in the trash. I'd get a piece of cardboard and make a templet of the curve then cut two sections out of sheet metal. Cut two more straight pieces, bend them to match the curve and weld the four pieces together into a box shaped curve. The body doesn't weigh 20 tons. A 6" length of straight tubing on each side of the curve will be plenty to support the weight of the body.
joemama
joemama is offline
PostPosted: Tue Apr 24, 2018 10:54 pm    Post subject: Re: Body lift welding Reply with quote
I did what Racer Dave said. Worked for the front and the rear of the body lift.
