mnakandala Samba Member
Joined: September 28, 2009 Posts: 245 Location: Sri Lanka
Posted: Sat Apr 21, 2018 7:36 am Post subject: 1988 Jetta MK2 Transmission Swap |
Recently bought a Jetta and the PO has swap 4 speed to 5 speed, the problem is its very hard to shift to Reverse and Fifth, going through the problem i have found out the shift linkage is missing parts
What are the things i can do to sort this out?
The part number in gearbox is 085301107A
- Any help/thoughts would be appreciated. _________________ 1964 bug
1983 mitsubishi Delica |
Joined: August 31, 2013 Posts: 12816 Location: North Carolina
Posted: Sat Apr 21, 2018 2:23 pm Post subject: Re: 1988 Jetta MK2 Transmission Swap |
The shift rod from the shifter has a longer relay arm, the shifter box has a wider gate , & the shifter selector rod has a dogleg in it instead of a 45* bend in it. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Sat Apr 21, 2018 2:53 pm Post subject: Re: 1988 Jetta MK2 Transmission Swap |
Never mind, you’re working with some stuff that we never got in the USA, that’s some crazy looking crap you got over there. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Sat Apr 21, 2018 6:20 pm Post subject: Re: 1988 Jetta MK2 Transmission Swap |
Haha okay, in a side note i believe the transmission i have now is from a VW Polo 6n1 , that means if i find a Polo shifter and trans linkage will i be fine? _________________ 1964 bug
mr. lang Samba Member
Posted: Mon Apr 23, 2018 2:26 am Post subject: Re: 1988 Jetta MK2 Transmission Swap |
mnakandala wrote: |
- Any help/thoughts would be appreciated. |
To me (owner of a almost similar 4 speed 084 gearbox) that looks perfect. No missing parts there.
Check for excessive play in the shift box and the shift stick.
Pull the shift stick boot from the center console and look into the box.
If no play, check, if enough material was removed from the plastic end stop at the right side in the shift box.
That end stop originally did prevent the stick to be moved further than 3th and 4th, but was already removed (broken off) from your box, since with it in place, it would be impossible to shift into 5th a all.
As far as I know, this end stop is the only modification necessary to the shift stick/linkage. Polo parts won't fit there.
EDIT, also look for left/right slop in the above pictured coupler. Take a pipe wrench to the left and right side of it to bend it narrower to remove any slop. Looks like yours did oval out, but could also be a visual illusion. _________________ 1966 Bus | 1969 Bug | 1976 Passat LX two-door | 1984 Golf 2 C (daily driver)
There are three kinds of people: those who can count and those who can't
Und läuft ... |
Posted: Mon Apr 23, 2018 5:59 am Post subject: Re: 1988 Jetta MK2 Transmission Swap |
mr. lang wrote: |
EDIT, also look for left/right slop in the above pictured coupler. Take a pipe wrench to the left and right side of it to bend it narrower to remove any slop. Looks like yours did oval out, but could also be a visual illusion. |
The problem that the OP is having is that the transmission has been exchanged for a 5-speed unit. The mkII cars that came to the US all had 5-speeds so we never saw this transmission. When swapping 5-speed into 4-speed mk1 cars, there were differences in the length of the relay arms to increase the throw at the transmission, perhaps you might be able to find a 5-speed mkII to compare for them. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Mon Apr 23, 2018 7:26 am Post subject: Re: 1988 Jetta MK2 Transmission Swap |
Thank you all for the valuable info, i will check on these things and update the forum _________________ 1964 bug
